Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Segmentation Fault in fluent3DMeshToFoam
Old   September 8, 2008, 09:56
Default Hi, I have received the follow
John Wang
cwang5 is on a distinguished road
Hi, I have received the following error message when converting fluent 3d mesh using fluent3DMeshToFoam:
Dimension of grid: 3
Number of points: 702
PointGroup: 1 start: 0 end: 701. Reading points...done.
--> FOAM Warning : Found unknown block of type: "13"
Number of cells: 470
CellGroup: 2 start: 0 end: 469 type: 1
Zone: 2 name: fluid type: fluid. Reading zone data...done.
Zone: 3 name: inlet type: velocity-inlet. Reading zone data...done.
Zone: 4 name: outlet type: pressure-outlet. Reading zone data...done.
Zone: 5 name: floorceiling type: symmetry. Reading zone data...done.
Zone: 6 name: sidewall type: symmetry. Reading zone data...done.
Zone: 7 name: wall type: wall. Reading zone data...done.
Zone: 9 name: default-interior type: interior. Reading zone data...done.
FINISHED LEXING
--> FOAM Warning :
From function boundBox::boundBox(const pointField& points)
in file meshes/boundBox/boundBox.C at line 52
Cannot find bounding box for zero sized pointField, returning zero
Creating cellZone 0 name: fluid type: fluid
#0 Foam::error::printStack(Foam:stream&) in "/home/john/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/john/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe420]
#3 Foam::polyTopoChange::getFaceOrder(int, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&) const in "/home/john/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicMesh.so"
#4 Foam::polyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&) in "/home/john/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicMesh.so"
#5 Foam::polyTopoChange::compactAndReorder(Foam::poly Mesh const&, bool, bool, bool, int&, Foam::Field<foam::vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<foam::map<int> >&) in "/home/john/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicMesh.so"
#6 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) in "/home/john/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libdynamicMesh.so"
#7 main in "/home/john/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/fluent3DMeshToF oam"
#8 __libc_start_main in "/lib/libc.so.6"
#9 __gxx_personality_v0 in "/home/john/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/fluent3DMeshToF oam"
Segmentation fault
I tried converting the same .msh file using fluemtMeshToFoam and it worked fine. I'm wondering what might have caused it?
cwang5 is offline   Reply With Quote
Old   September 8, 2008, 11:09
Default Can you post or send the case?
Mattijs Janssens
mattijs is on a distinguished road
Mattijs
mattijs is offline   Reply With Quote
Old   September 9, 2008, 04:48
Default Umm...how do I post the file?
John Wang
Old   September 9, 2008, 05:25
Default Hello, I'm getting the same
Etienne Lorriaux
elorriaux is on a distinguished road
I'm getting the same kind of error with fluent3DMeshToFoam and OF-1.5. I did not try the fluentMeshToFoam yet.
My mesh is generated with gambit-2.2.
Mattjis, i can send you an http link with my .msh, but it's quite big (more than one million cells).
Regards,
Etienne.
elorriaux is offline   Reply With Quote
Old   September 9, 2008, 05:26
Default oh, checked the forum document
John Wang
oh, checked the forum documentation, here's the file.
Old   September 9, 2008, 05:43
Default file's too big, can't upload i
John Wang
file's too big, can't upload it, I'm uploading it to rapidshare, here's the link.
http://rapidshare.de/files/40430130/...id.msh.gz.html
let me know when you have received the file. Thanks
Old   September 9, 2008, 09:27
Default says the file does not exist w
Mattijs Janssens
says the file does not exist when I try to download it. Can you try again and send link to me? (m dot janssens at opencfd.co.uk)
Old   September 10, 2008, 08:55
Default Pushed a changed fluent3DMeshT
Mattijs Janssens
Pushed a changed fluent3DMeshToFoam.L to the 1.5.x git which reads your file. Let me know if it breaks anything else ;-)
Old   September 11, 2008, 05:26
Default I couldn't seems to access the
John Wang
I couldn't seems to access the git repository. The git update process is stuck at "Indexing 9605 objects... 0% (1/9605) done. Any idea how to fix that? Thanks
Old   September 11, 2008, 06:10
Default I have just pulled and pushed
henry is on a distinguished road
I have just pulled and pushed and it was fine. It looks like you have an unreliable connection, could you try again later?
H
henry is offline   Reply With Quote
Old   September 11, 2008, 06:52
Default humm...well, it never worked f
  #11
John Wang
humm...well, it never worked for me, I've tried updating it for a while, and was always stuck at the git clone step.
Old   September 16, 2008, 08:50
Default Have you examined the mesh in
  #12
Ameya Durve
ameya is on a distinguished road
Have you examined the mesh in gambit or fluent before exporing it to OpenFOAM? May be you hav some highly skewed elements.
I recoomend you not only peform grid check but also use hexahedral mesh as far as pssible
ameya is offline   Reply With Quote
Old   November 19, 2008, 04:27
Default Hi, I got the same sequence of
  #13
Radu Mustata
r2d2 is on a distinguished road
Hi, I got the same sequence of errors when using fluent3DMeshToFoam when using OF1.5 but it all went smooth with the OF1.4.1. Did anything change in-between, some lib somewhere?
Just for the record, if it helps:
In 1.5 it says:
Create time
Number of points: 119966
PointGroup: 1 start: 0 end: 119965. Reading points...done.
Number of cells: 93916
CellGroup: 2 start: 0 end: 54143 type: 1
CellGroup: 3 start: 54144 end: 93915 type: 1
Zone: 3 name: gdlH2 type: solid. Reading zone data...done.
Zone: 4 name: wall type: wall. Reading zone data...done.
Zone: 5 name: outletGDLH2 type: pressure-outlet. Reading zone data...done.
Zone: 6 name: outletH2 type: pressure-outlet. Reading zone data...done.
Zone: 7 name: inletH2 type: mass-flow-inlet. Reading zone data...done.
FINISHED LEXING
--> FOAM Warning :
Creating cellZone 1 name: gdlH2 type: solid
#0 Foam::error::printStack(Foam:stream&) in "/home/radu/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/radu/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::polyTopoChange::getFaceOrder(int, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int>&, Foam::List<int>&, Foam::List<int>&) const in "/home/radu/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#4 Foam::polyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&) in "/home/radu/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#5 Foam::polyTopoChange::compactAndReorder(Foam::poly Mesh const&, bool, bool, bool, int&, Foam::Field<foam::vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<foam::map<int> >&) in "/home/radu/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#6 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) in "/home/radu/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libdynamicMesh.so"
#7 main in "/home/radu/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluent3DMeshT oFoam"
#9 __gxx_personality_v0 in "/home/radu/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/fluent3DMeshT oFoam"
Segmentation fault
...and in 1.4.1
Number of faces: 309635
FaceGroup: 4 start: 0 end: 52438. Reading mixed faces...done.
FaceGroup: 5 start: 52439 end: 62381. Reading mixed faces...done.
FaceGroup: 6 start: 62382 end: 62413. Reading mixed faces...done.
FaceGroup: 7 start: 62414 end: 62445. Reading mixed faces...done.
FaceGroup: 9 start: 62446 end: 309634. Reading mixed faces...done.
FINISHED LEXING
--> FOAM Warning :
cannot find bounding box for zero sized pointFieldreturning zero
Creating patch 0 for zone: 4 name: wall type: wall
Creating patch 1 for zone: 5 name: outletGDLH2 type: pressure-outlet
Creating patch 2 for zone: 6 name: outletH2 type: pressure-outlet
Creating patch 3 for zone: 7 name: inletH2 type: mass-flow-inlet
patch 0 from Fluent indices: 0 to: 52438 type: wall
patch 1 from Fluent indices: 52439 to: 62381 type: pressure-outlet
patch 2 from Fluent indices: 62382 to: 62413 type: pressure-outlet
patch 3 from Fluent indices: 62414 to: 62445 type: mass-flow-inlet
Writing mesh to "/home/radu/OpenFOAM/radu-1.4.1/run/pila3D/pila10x10/cascada/simpleFoam/constant /region0"
End
r2d2 is offline   Reply With Quote
Old   November 19, 2008, 04:36
Default We have pushed a new version t
  #14
We have pushed a new version to the 1.5.x git repository, could you try that?
H
Old   November 19, 2008, 05:08
Default Will do that, as soon as I hav
  #15
Radu Mustata
Will do that, as soon as I have some spare time.
Thanks anyway,
Radu
Old   November 19, 2008, 11:01
Default Good morning, with the new
  #16
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Good morning,
with the new changes, fluent3DMeshToFoam does not compile for me :
fluent3DMeshToFoam.L: In function 'int main(int, char**)':
fluent3DMeshToFoam.L:932: error: expected `]' before ')' token
fluent3DMeshToFoam.L:933: error: expected `)' before '{' token
fluent3DMeshToFoam.L:936: error: expected primary-expression before '}' token
fluent3DMeshToFoam.L:936: error: expected `;' before '}' token
fluent3DMeshToFoam.L: At global scope:
fluent3DMeshToFoam.L:1340: error: expected unqualified-id before ']' token
Regards,
PO
podallaire is offline   Reply With Quote
Old   November 19, 2008, 12:43
Default Which version of flex are you
  #17
Which version of flex are you using?
H
Old   November 19, 2008, 13:26
Default I have just pushed a small cha
  #18
I have just pushed a small change which should keep old versions of flex happy.
H
Old   November 19, 2008, 18:20
Default Thanks ! I will give it a t
  #19
Thanks !
I will give it a try later tonight
-> flex 2.5.33
Regards,
PO
Old   November 20, 2008, 03:28
Default We are now using flex 2.5.35 w
  #20
We are now using flex 2.5.35 which comes with SuSE 11 and other recent Linux releases or can be downloaded and compiled from sources. There is a bug in the .skel file in version 2.3.33 (fixed in 2.5.35) which means that "]]" in the "C" code throws and error but "] ]" is OK. The fix I uploaded should solve the problem for you.
H
Segmentation fault. Nari Siemens 3 November 8, 2007 05:04
segmentation fault Suman Siemens 2 June 26, 2007 03:14
Segmentation fault billy OpenFOAM Installation 20 April 23, 2007 22:57
Segmentation fault??? LiQiang Main CFD Forum 3 March 18, 2005 13:25
Segmentation fault Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 3 January 10, 2005 05:02
