November 8, 2008, 16:09 |
Follow up on the thread http:/
Niklas Wikstrom
Follow up on the thread http://www.cfd-online.com/cgi-bin/Op...8039#POST28039
Sorry about the delayed bug report, but here it is and with test case. Description: snappyHexMesh bails out when increasing nCellsBetweenLevels from 2 to 3 in specific case (below) Could not find point 129196 in the anchorPoints for cell 97678 Does your original mesh obey the 2:1 constraint and did you use consistentRefinement to make your cells to refine obey this constraint as well?#0 Foam::error::printStack(Foam::-Ostream&) in "/home/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libOpenFOAM.so" Solver/Application: snappyHexMesh Source file: Testcase: snappyBugCase.tar.bz2 Platform: linux 32 and 64 bit (Ubuntu 8.04 and 8.10) Version: 1.5.x Cheers Niklas |
November 10, 2008, 08:38 |
Thanks. Pushed a change to 1.5
Mattijs Janssens
Rep Power: 26 |
Thanks. Pushed a change to 1.5.x git to stop it failing. With more than two layers between levels it uses a geometric test which does not work very well for non-cubic cells so it still might not do what you want.
November 11, 2008, 04:51 |
Adding question to this thread
Niklas Wikstrom
Adding question to this thread since it's still warm, although no bug:
I have generated a snappyHexMesh mesh for a customer running OF-1.5. It was generated on 1.5.x. When running checkMesh in 1.5 there are several errors about concaveFaces and warpedFaces et c. These errors does not apear when the mesh is checked in 1.5.x. Are ther mesh differences, or only tolerance changes between the versions? Cheers and many thanks! Niklas |
November 13, 2008, 11:08 |
There should be little mesh di
Mattijs Janssens
Rep Power: 26 |
There should be little mesh differences. Mesh checking hasn't changed. Rerun with binary writing and see if that helps.
[snappyHexMesh] SnappyHexMesh and Snapping | thomasr | OpenFOAM Meshing & Mesh Conversion | 5 | March 15, 2012 11:07 |
[snappyHexMesh] SnappyHexMesh | erik023 | OpenFOAM Meshing & Mesh Conversion | 19 | October 17, 2010 10:09 |
[snappyHexMesh] SnappyHexMesh in Parallel | bastil | OpenFOAM Meshing & Mesh Conversion | 22 | April 7, 2010 11:48 |
[snappyHexMesh] SnappyHexMesh | mp340 | OpenFOAM Meshing & Mesh Conversion | 1 | November 13, 2008 13:30 |
SnappyHexMesh vs turbDyMFoam | young | OpenFOAM Running, Solving & CFD | 0 | October 16, 2008 10:21 |
