Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
CheckMesh
Old   August 8, 2008, 12:36
Default (1) if we change blockMeshDict
Maka Mohu
maka is on a distinguished road
(1) if we change blockMeshDict to: (see the end of the message)
(2) run blockMesh and then checkMesh
(3) we get from checkMesh:
Mesh non-orthogonality Max: 45 average: 36.4151
(4) I expected :
Mesh non-orthogonality Max: 45 average: (2/3)*45=30.
since 1/3 of the mesh hax non-othogonality=0 (faces normal to z directions).
convertToMeters 0.1;
vertices
(0 0 0)
(1 0 0)
(2 1 0)
(1 1 0)
(0 0 1)
(1 0 1)
(2 1 1)
(1 1 1)
blocks
hex (0 1 2 3 4 5 6 7) (5 5 5) simpleGrading (1 1 1)
maka is offline   Reply With Quote
Old   August 8, 2008, 12:37
Default case: cavity; V 1.3;
Maka Mohu
Old   August 11, 2008, 05:13
Default You are right - to avoid the e
Mattijs Janssens
mattijs is on a distinguished road
You are right - to avoid the expensive acos we determine the average in-product, not angle, and only when output convert it into an angle. See primitiveMeshCheck.C::checkFaceOrthogonality.
mattijs is offline   Reply With Quote
Warning from checkMesh is this serious hsieh OpenFOAM Running, Solving & CFD 9 April 27, 2022 10:45
[Commercial meshers] CheckMesh error after fluent3DToFoam luca_phi OpenFOAM Meshing & Mesh Conversion 0 September 17, 2008 03:41
Segmentation fault when using checkMesh skabilan OpenFOAM Pre-Processing 4 June 5, 2008 17:15
[Other] CheckMesh for mesh quality gdbaldw OpenFOAM Meshing & Mesh Conversion 2 October 18, 2007 00:11
CheckMesh in OF 13 dev 01_05_2007 fra76 OpenFOAM Running, Solving & CFD 5 June 14, 2007 14:16
