Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Correction to the script wcleanMachine
Old   June 10, 2008, 07:30
Default Hello, I would like to prop
Martin Beaudoin
mbeaudoin will become famous soon enough
I would like to propose a small correction to the script wcleanMachine in order to correctly cleanup the Make directory under src/Pstream/mpi.
With the actual current version of wcleanMachine, the clean-up is not made properly under src/Pstream/mpi/ because the script only looks for an exact machine pattern under the Make directory, which usually is $WM_OPTIONS.
But under src/Pstream/mpi, we usually end up with directory names like this:
Make/$(WM_OPTIONS)MPI or
Make/$(WM_OPTIONS)LAM or
Make/$(WM_OPTIONS)OPENMPI
and wcleanMachine fails to remove those.
So I would like to propose this little modification to the script wcleanMachine in order to handle this cleanup problem:
# find `find . -depth \( -name "Make.[A-Za-z]*" -o -name "Make" \) -type d -print` -depth \( -type d -name "*$1" \) -exec rm -r {
\; # <---- old version}
find `find . -depth \( -name "Make.[A-Za-z]*" -o -name "Make" \) -type d -print` -depth \( -type d -regex ".*$1\|.*$1$WM_MPLIB" \) -exec rm -r { \;}
Martin
mbeaudoin is offline   Reply With Quote
Old   June 10, 2008, 10:21
Default Thanks for the suggestion, I h
henry is on a distinguished road
Thanks for the suggestion, I have put it in 1.5
Henry
henry is offline   Reply With Quote
Old   June 10, 2008, 13:05
Default Thanks Henry, Please take n
Martin Beaudoin
Thanks Henry,
Please take note that I messed up the braces syntax of the last part of the find command while playing with the Forum Message formatting language.
Here are the two lines again, but without any formatting:
#find `find . -depth \( -name "Make.[A-Za-z]*" -o -name "Make" \) -type d -print` -depth \( -type d -name "*$1" \) -exec rm -r {} \;
find `find . -depth \( -name "Make.[A-Za-z]*" -o -name "Make" \) -type d -print` -depth \( -type d -regex ".*$1\|.*$1$WM_MPLIB" \) -exec rm -r {} \;
Sorry about that,
and thanks to Bernhard for pointing that one out.
Martin
Old   June 10, 2008, 14:18
Default Yes I noticed the error and co
Yes I noticed the error and corrected it. I also changed the -regex to -name ... -o ... as I am not sur we can rely on all implementations of find support -regex.
H
Old   June 10, 2008, 15:38
Default Indeed, according to the man p
Martin Beaudoin
Indeed, according to the man page, "-name" and "-o" are specified in the POSIX standard, which should be more portable.
Thanks for the tip!
Martin
ICEM SCRIPT bhaskar CFX 0 January 3, 2009 04:49
Error in Tcl script Haider Fidelity CFD 2 October 5, 2007 01:44
awk script question awk script question Main CFD Forum 0 March 28, 2005 02:06
Kill Script DAE FLUENT 3 March 31, 2003 04:43
linking the script Mavinakere FLUENT 0 September 12, 2002 11:57
