Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
MergeMeshes fails on OF141 any fix
Old   January 4, 2008, 22:54
Default Hi, I tried to merge two me
Pei-Ying Hsieh
hsieh is on a distinguished road
I tried to merge two meshes together using mergeMeshes util, but, failed. Is this a bug, or did I do something wrong? I did not have the same problem with OF-1.3.
Error Messages attached.
Pei
phsieh@jali:~/OpenFOAM/phsieh-1.4.1/run> mergeMeshes . genesysReagentPackRotation_hex1 . genesysReagentPackRotation_tet1
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : mergeMeshes . genesysReagentPackRotation_hex1 . genesysReagentPackRotation_tet1
Date : Jan 04 2008
Time : 22:31:09
Host : jali
PID : 19400
Root :
Case :
Nprocs : 1
Master: "." "genesysReagentPackRotation_hex1"
mesh to add: "." "genesysReagentPackRotation_tet1"
Create Times
Reading master mesh for time = 0.6
Create mesh
Reading mesh to add for time = 0.6
Create mesh
Writing combined mesh to 0.60001
patch names:
4
walls
internal
wall1
inter1
patch types:
4
wall
patch
wall
patch
point zone names:
0
face zone names:
0
cell zone names:
0
Copying old patches
Adding new patches.
--> FOAM FATAL ERROR : polyTopoChange was constructed with a mesh with 2 patches.
The mesh now provided has a different number of patches 4 which is illegal
#0 Foam::error::printStack(Foam:stream&) in "/home/phsieh/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/phsieh/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::polyTopoChange::compactAndReorder(Foam::poly Mesh const&, bool, Foam::Field<foam::vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::objectmap>&, Foam::List<foam::map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<foam::map<int> >&) in "/home/phsieh/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libdynamicMesh.so"
#3 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool) in "/home/phsieh/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libdynamicMesh.so"
#4 Foam::polyMesh::readUpdate() in "/home/phsieh/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/mergeMesh es"
#5 main in "/home/phsieh/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/mergeMesh es"
#6 __libc_start_main in "/lib64/libc.so.6"
#7 __gxx_personality_v0 in "/home/phsieh/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/mergeMesh es"
From function polyTopoChange::compactAndReorder(polyMesh&, const bool, const bool)
in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 1631.
FOAM aborting
Aborted
hsieh is offline   Reply With Quote
Old   January 4, 2008, 23:08
Default Hi, OK, I found how to use
Pei-Ying Hsieh
OK, I found how to use mergeMeshes now.
Before performing mergeMeshes, in boundary of the master case, I need to add the patchnames (from the second case) with nFaces 0 - some kind of place holder. Then, mergeMeshes was successful.
Pei
Old   January 29, 2008, 15:04
Default Hi Pei, I am trying to do the
Anant Grewal
agrewal is on a distinguished road
Hi Pei,
I am trying to do the same without success. I followed your solution and added a patch in the boundary of the master mesh which contains the interfacing patch from the slave mesh, i.e.
Mesh_rest_dom_front
type patch;
nFaces 0;
startFace 17860;
This did not work (Note, I incremented the number of patches at the top of the boundary file). Can you please provide more details of the changes you made to the master boundary file.
Thanks
Anant
agrewal is offline   Reply With Quote
Old   January 29, 2008, 19:31
Default Hi, Anant, Could you pleas
Pei-Ying Hsieh
Hi, Anant,
Could you please either email me your case files or post the error messages? I recalled that, all I need to do is to add the patches (in the slave mesh) to the master mesh prior to mergeMeshes.
Did you check the meshes that you are trying to merge "before" merging? Are the meshes checked out fine (checkMesh . case) prior to merging?
Pei
phsieh2005@yahoo.com
MergeMeshes with version OF14 jens_klostermann OpenFOAM Bugs 2 November 7, 2014 16:27
[mesh manipulation] MergeMeshes hsieh OpenFOAM Meshing & Mesh Conversion 3 September 10, 2014 09:15
[mesh manipulation] MergeMeshes and stitchMesh problem flo OpenFOAM Meshing & Mesh Conversion 6 May 10, 2010 10:40
MergeMeshes and mesh format from 14x 15 pitmanm OpenFOAM Bugs 14 July 4, 2009 00:55
Parallel computation with OF141 benru OpenFOAM Running, Solving & CFD 3 August 15, 2007 09:21
