Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Problems caused by fvcmeshPhi
Old   March 28, 2007, 07:08
Default Hi, I had some troubles exper
Rolando Maier
rolando is on a distinguished road
I had some troubles experimenting with moving meshes using an adjustable time step with the icoDyMFoam solver.
If I use a timestep, which is far from the "optimal" one at the beginning of the calculation the timestep doesnīt "converge" at all, but sometimes changes many orders of magnitude from step to step.
Watching the meshPhi fields showed that this fields donīt contain the correct values of mesh movement.
I tried to track the problem and I think it is located in fvc::meshPhi.
As I use the backward timescheme, I can only talk about backwardDdtScheme<type>::meshPhi().
I think the problem is caused when deltaT and deltaT0 have very different size, which may happen at the beginning of a simulation.
The whole calculation in this method seems somehow inconsistent.
The methods return is:
(1 + dT/(dT + dT0))*phi - (dT^2/(dT0*(dT + dT0)))*phi0
If I look at the extreme case with constant meshPhi (phi=phi0) this method produces incorrect results.
The return now is:
(dT0^2+2*dT*dT0-dT^2)/(dT0*(dT+dT0))*phi
If I now say dT = 1.2*dT0 (this is the upper limit, set by setDeltaT.H) the error is about 11%, which is quite a lot.
If dT -> 0 which can also occur, as there is no limiter for lower bounds the error can even "explode".
Would it be better to use the uncorrected value fvMesh::phi() instead of fvc::meshPhi()?
If so, why then even do the above meshPhi correction?
Rolando
rolando is offline   Reply With Quote
Old   March 28, 2007, 07:15
Default Does your case run correctly i
henry is on a distinguished road
Does your case run correctly if you use Euler implicit rather than the backward temporal scheme?
Henry
henry is offline   Reply With Quote
Old   March 28, 2007, 07:26
Default Hi Henry, after quickly looki
Rolando Maier
Hi Henry,
after quickly looking at the case, it seems to work with the Euler scheme.
Rolando
Old   March 28, 2007, 07:30
Default OK, I will look more closely a
OK, I will look more closely at the implementation of fvc::meshPhi for the backward scheme; it's not well tested because for moving-mesh problems we usually use Euler because the Courant number is limited by stability issues and Euler is usually accurate enough.
Henry
Old   March 28, 2007, 07:42
Default Thanks Henry. I think the fir
Rolando Maier
Thanks Henry.
I think the first order Euler scheme is not the correct choise for what Iīm planning to do. I hope to do some LES calculations with a moving grid.
Would it meanwhil be incorrect to use the uncorrected fvMesh::phi() instead of fvc::meshPhi()?
Rolando
Old   March 28, 2007, 07:51
Default Rolando, You can do LES wit
Rolando,
You can do LES with the Euler implicit scheme if your Courant number is sufficiently small although it is preferable to use either backward or Crank Nicholson with a small amount of off-centering. Using fvMesh::phi() directly is not consistent with using the backward scheme for a case in which the time step changes which is why fvc::meshPhi() was introduced. I will test the backward differencing implementation of this function and post the correction if necessary.
Henry
Old   March 28, 2007, 07:52
Default Hello Hrvoje, is it possible
Rolando Maier
Hello Hrvoje,
is it possible to get a patched version of OpenFOAM-1.3?
This would help me to continue my work, while waiting for 1.4.
Rolando
Old   March 28, 2007, 07:59
Default Henry, what do you mean with
Rolando Maier
Henry,
what do you mean with a sufficiently small Courant number?
I use max Co of about 1.5. Therefore I use an additional nonlinear loop around all equations.
By the way, what small amount of off-centering do you mean?
Rolando
Old   March 28, 2007, 08:06
Default Certainly less than Co < 0.5 w
Certainly less than Co < 0.5 would be necessary to get good results using the Euler scheme. With a Courant number as high as 1.5 backward may be your only choice because you will probably find Crank Nicholson unstable. If you want to try it use a coefficient of 0.9 which corresponds to using 10% Euler, we find that is pretty much as stable as backward and is useful for equation systems in which sub-cycling precludes the use of backward.
Henry
Old   March 28, 2007, 08:21
Default Henry, thatīs also what I not
Rolando Maier
Henry,
thatīs also what I noticed. The Cranck Nicholson scheme is very unstable at that high Co.
But I will try it with the coefficient of 0.9.
Do you mean the nonlinear loop around the equations with sub-cycling?
Hrvoje,
thanks for your eMail.
Rolando
Old   March 28, 2007, 10:09
Default No I mean sub-cycling with in
  #11
No I mean sub-cycling with in the time-step, e.g. in the interFoam codes the gamma equation is sub-cycled and this is consistent with the rest of the equations for Euler and Crank-Nicholson but not with backward.
There is a problem with fvc::meshPhi() for backward and I will fix it and post the fix after testing.
Henry
Old   March 28, 2007, 10:14
Default Thanks a lot Henry, Rolando
  #12
Rolando Maier
Thanks a lot Henry,
Rolando
Old   March 28, 2007, 12:18
Default Hello Hrvoje, Iīm still compi
  #13
Rolando Maier
Hello Hrvoje,
Iīm still compiling your development version.
1) I had problems with the files skewLinear.C and leastSquaresGrad.C. They both use the method mesh(), which is not yet implemented in the base class MeshObject. I changed the calls from mesh() to mesh_.
2) I get some errors compiling tetDecompositionMotionSolver. Iīll delete all lnIncludeīs (I didnīt do so far) and recompile everything. I tell you tomorrow, if I had success.
Rolando
Old   March 28, 2007, 14:22
Default Rolando, I have now checked
  #14
Rolando,
I have now checked the backwardDdtScheme<type>::meshPhi function in version 1.3 carefully and tested it and I don't think there is any error, the coefficients are the way they are to be second-order accurate with time-step variation. If you are having stability problems when your Courant number is high and your time-step varies rapidly this may be fundamental to the backward scheme and that you will either need to reduce the time-step, reduce the rate of change of the time-step or perhape use Euler implict during the start-up phase of the calculation and change to backward after the flow has evolved and the time-step stopped changing so rapidly. Play around with these options to see if you can stabilise your calculation.
Henry
Old   March 29, 2007, 04:48
Default Hello Henry, thanks for that.
  #15
Rolando Maier
Hello Henry,
thanks for that.
Rolando
Old   March 30, 2007, 04:31
Default Hello Hrvoje, Iīm now using y
  #16
Rolando Maier
Hello Hrvoje,
Iīm now using your new version of backwardDdtScheme.C and Iīm experimenting quite a lot with it.
It works better than the original version, but the problem is not cured.
fvc::meshPhi now produces results that are about the same order of magnitude of what they should be. But they still can differ quite a lot.
They seem to oscillate around the target value.
So the problem is still the same:
- Adjusting the timestep causes a wrong prediction of meshPhi
- This will cause a change in timestep
When I start calculation with a fixed and "correct" time step and I switch to adjustable timestep afterwards, the oscillation also occurs, after some delay.
The absolute fluxes in contrast have correct values.
Rolando
Old   March 30, 2007, 04:50
Default Rolando, You seem to be mis
  #17
Rolando,
You seem to be missing the point of fvc::meshPhi: it is a mechanism to generate "effective" mesh fluxes corresponding to the mesh motion such that the order of the temporal discretisation scheme is maintained during mesh motion; they should not necessarily be the same as current time-step mesh fluxes obtained from mesh.phi() except for the Euler scheme. Perhaps the problem you are seeing is not directly associated with fvc::meshPhi but that this affects the relative fluxes which are then used in the time-step evaluation. Try using the absolute fluxes in the time-step evaluation and see if that removes the instability the current approach seems to be exciting.
Henry
Old   March 30, 2007, 05:34
Default Thanks Henry, if I got you ri
  #18
Rolando Maier
Thanks Henry,
if I got you right, it seems to be a stability problem inherent in the backward scheme.
The Euler scheme as posted above works well, even the Crank-Nicholson scheme works well (for this very simple test case).
Evaluating the absolute fluxes helps and the case runs absolutly stable and correct.
But for evaluating flows with moving grids the relative fluxes should be evaluated.
Maybe the way of time-step evaluation can be changed for stabilization reasons. E.g. using a proper damping mechanism or using fvMesh::phi() instead of fvc::meshPhi() for the evaluation.
What do you think about it?
Rolando
Old   March 30, 2007, 05:40
Default It isn't clear that there is s
  #19
It isn't clear that there is stability problem inherent in the backward scheme except perhaps in the case of moving meshes with variations in time step derived from the relative fluxes; this is a very special case. If this is so then you need to find a way of avoiding this feed-back mechanism from the high-order mesh fluxes to the time-step and back to the high-order mesh fluxes, one way being using the absolute fluxes or as you suggest approximate relative fluxes for the evalauation of the time-step adjustment.
Henry
Old   March 30, 2007, 05:49
Default Thanks Henry, Iīll try to fin
  #20
Rolando Maier
Thanks Henry,
Iīll try to find a proper time-step adjustment for that kind of problem.
Rolando
Bug caused by CrankNicholson scheme cbeck OpenFOAM Bugs 8 March 28, 2009 01:48
waves caused by stones gamego Main CFD Forum 5 October 1, 2008 10:33
Forces caused by fluids anja OpenFOAM Running, Solving & CFD 20 May 8, 2006 06:37
Adiabatic compression caused by gas ram Chris FLUENT 0 December 13, 2005 04:42
problem caused by the different materials limingtiger Siemens 1 November 21, 2005 08:02
