Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Parallel Moving Mesh Bug for Multi-patch Case
Old   May 22, 2009, 10:44
Default Parallel Moving Mesh Bug for Multi-patch Case
Cem Albukrek
albcem is on a distinguished road
Hello all,
Sorry for re-posting this, but getting absolutely no responses to any of my postings in general I thought I may want to target them to the appropriate sub-forums. If anyone knows how to delete previous postings, please let me know...
I am testing the mesh motion for a simple case that consists of a rectangular block with 6 patches for 6 faces. I use pointMotionVelocity to drive the mesh motion.
If I run a solver like "InterDyMFoam" on a single processor, everything runs right. However, if I decompose the case to 2 or more processors and continue the run in parallel then I get errors similar to the below.
It seems the mesh.update() does not interpret the number of points to move on the patches distributed between the processors right. If I define the whole cube as a single patch and run it in parallel then I do not run into any issues.
Some validation on whether this is a true bug and insight into resolving the issue would be helpful.
Thanks
Cem
Exec : rasInterDyMFoam -parallel
Date : May 20 2009
Time : 19:59:13
Host :
PID : 8833
Case :
nProcs : 2
Slaves :
1
goldenhorn.8834
Pstream initialized with:
floatTransfer : 1
nProcsSimpleSum : 0
commsType : nonBlocking
Create time
Create mesh for time = 0.01
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityLaplacian
[1] [0]
[0]
[0] size 834 is not equal to the given value of 835
[0]
[0] file: /MultiPatchCube/processor0/0.01/pointMotionU::Block_Side2 from line 3800 to line 3801.
[0]
[0] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)
[0] in file /home/cae/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 224.
[0]
FOAM parallel run exiting
[0]
[goldenhorn.caebridge.com:08833] MPI_ABORT invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1
[1]
[1] size 889 is not equal to the given value of 890
[1]
[1] file: /MultiPatchCube/processor1/0.01/pointMotionU::Block_Bottom from line 1627 to line 1628.
[1]
[1] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)
[1] in file /home/cae/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 224.
[1]
[1]
[goldenhorn:08834] MPI_ABORT invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1
mpirun noticed that job rank 1 with PID 8834 on node goldenhorn exited on signal 123 (Unknown signal 123).
albcem is offline   Reply With Quote
Old   May 23, 2009, 04:18
henry is on a distinguished road
Are your running 1.5 or 1.5.x? If the former please pull 1.5.x from our git repository and try again. If it still doesn't work please post the case here and we will take a look.
Henry
henry is offline   Reply With Quote
Old   May 23, 2009, 13:03
Cem Albukrek
Hello Henry,
The problem persists in all versions - 1.5, 1.5.x and 1.5-dev. For the 1.5.x, I pulled the latest version this morning and retried as you suggested. The problem is still there.
For your evaluation, I am including two cases - one with a multi-patch cube, the other with a single-patch cube. The single patch case is derived from the multi-patch one by manually editing the polymesh/boundary file to collapse the 6 cube patches to a single one. This way the geometric aspects of the meshes are exactly the same. The single patch case works in both serial and parallel modes. The multi-patch case fails in parallel mode as I mentioned before.
You will need to march the cases from the final time step at which the point and cell motion files have non-zero values. You can use interDyMFoam for the tests.
You can download the two cases from:
MultiPatchCube
SinglePatchCube
Thanks a lot for your support.
Cem
Old   May 25, 2009, 17:29
Unfortunately I am unable to download the cases, could you please check the links?
Thanks
H
Old   May 25, 2009, 23:08
Cem Albukrek
Hello Henry,
Sorry about the problem. Apparently the web server where the files are was offline due to a power outage. Now everything is in order - the links should work.
Thanks.
Cem
Old   May 29, 2009, 05:34
Your case runs fine if you decompose the 0 time and run in parallel from there.
Henry
Old   May 29, 2009, 06:05
Cem Albukrek
Hello Henry,
Wrong conclusion for the wrong reason is what I can respond you:
There is no mesh motion prescribed in a dictionary to keep things simple. So if you start from time step 0, where the point motion file prescribes no motion, you will trivially skip the mesh motion part of the solver, where there is trouble.
As I mentioned in my previous message, you need to start from the latest time step, in which some non-zero point and cell motion values are prescribed to get into the mesh motion portions of the solver.
I should have erased time step 0 to avoid this confusion...
Please let me know whether it is now clear to you that the bug is still there and needs to be fixed...
Thanks
Cem
Old   May 29, 2009, 06:19
When I run from time-step the mesh-motion is solved for:
FDICPCG: Solving for cellMotionUx, Initial residual = 0, Final residual = 0, No Iterations 0
FDICPCG: Solving for cellMotionUy, Initial residual = 0, Final residual = 0, No Iterations 0
FDICPCG: Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 0
Execution time for mesh.update() = 0.28 s
which uses the pointMotionU file provided. The fact than no motion occurs is not important with respect to the problem you reported. What this means is that you cannot currently decompose your 0.01 directory, this generates files with incorrect numbers of points in the pointMotionU files, what you need to do is decompose the 0 directory and then specify the motion in parallel either in the solver or by writing a setup code which you run in parallel.
Henry
Old   May 29, 2009, 07:28
Cem Albukrek
Hello Henry,
The underlying solver is a customized 6-DOF solver that I have been developing and it does exactly what you suggest in your response:
I do start my simulations in parallel at time step 0 and the point motion is specified during the execution of this code in parallel. If the single patch version works in serial+parallel, and the multi-patch version works in serial, why would the multi-patch in parallel fail? So this may be a solver dependent issue.
Forgetting about the details of the solvers, you have point and cell motion files that work fine in serial mode and fail in parallel after decomposition. Isn't this an issue of concern, ie a bug on the decomposePar side?
I still think there is a problem with mesh motion for a multi-patch case, when one specifies non uniform point motion values on the patches. If I could make a stronger case to you on this claim (how can I?), we could move forward looking both at decomposePar and the point motion solvers to see where the issue arises.
Cem
Old   May 29, 2009, 07:45
There is a limitation in decomposePar with respect to pointFields which will be removed following a future reorganization of the way pointFields and cellFields relate. For now you need to specify the pointMotionU field in a pre-processing application that runs in parallel and operates on your correctly decomposed initial field or is set in parallel in the solver running in parallel. This is what we do for complex mesh-motion cases running in parallel.
Henry
Old   May 29, 2009, 11:07
Cem Albukrek
Hello Henry,
Thank you for the insight. Before things cool off I wanted to get your advice on how to assign pointMotionU in parallel. The code I work with utilizes the following lines to assign a solid body rotation and translation on a multi-patch object:
for (int pcnt=0; pcnt<motionPatches_.size(); pcnt++)
patchI=label(mesh_.boundaryMesh().findPatchID(moti onPatches_[pcnt]));
pointCentres = mesh_.boundaryMesh()[patchI].localPoints() - CoG;
Xdot = (((pointCentres ^ unitVectX) & Omega_cog_global) * unitVectX);
Ydot = (((pointCentres ^ unitVectY) & Omega_cog_global) * unitVectY);
Zdot = (((pointCentres ^ unitVectZ) & Omega_cog_global) * unitVectZ);
pointMotionU.boundaryField()[patchI] ==
Xdot + Ydot + Zdot +
U_cog_global
If this needs to be modified and you have an example piece of code for the modification, it would help greatly. Else I don't exactly know what I need to change in the way I do things...
Thanks for your help.
Cem
Old   June 25, 2009, 00:57
Cem Albukrek
Hello Henry,
I would appreciate it if you could post an example code for the parallel assignment of the pointMotionU field as you suggest or a way for me to go around the issue. I am really stuck for quite some time with this problem...
Thanks.
Cem
Old   June 25, 2009, 02:56
You run whatever code you have written to set pointMotionU in parallel on a case which has been decomposed with the initial pointMotionU field having uniform values. The only issue you have to be careful of is the presence of "global" points on the processors which come from the shared points at edges and corners. To see an example take a look at how the cellMotionU field is mapped to the pointMotionU field after the mesh-motion solution.
H
Old   June 25, 2009, 19:07
Cem Albukrek
Hello Henry,
Thank you very much for the tip.
Before moving forward with any code modification, I played around with the decomposition parameters a little more and noticed that I could get my "hardest" case going with metis based decomposition and the less demanding ones by playing with the "delta" parameter in decomposeParDict.
This is a little relief for me, however I find it troubling that different decompositions give different success results.
Are there any best practices for parallel decomposition parameters for moving mesh problems? I can not find any guideline indicating the role of "delta" or how one would choose "simple", "hierarchical", "metis" or "manual" methods over the rest. I also remember reading one can force to assign chosen patches to a single processor as desired. Is this documented anywhere?
Best regards,
Cem
Old   June 26, 2009, 03:22
Changing the decomposition changes how many "global" points are generated and how they relate between the patches. By changing this you might get lucky and not need to set the position of the "global" points in your code but if you did do this as I suggest then the behavior will be independent of the decomposition.
H
Old   August 17, 2009, 10:23
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Hi Henry,
I have the same problem here with version 1.6.x where as my pointMotionU file at time 0 is very simple :
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
Inlet
//Slip will allow the mesh to move at the inlet
//type slip;
type fixedValue;
value uniform (0 0 0);
Outlet
//Slip will allow the mesh to move at the outlet
//type slip;
type fixedValue;
Walls
type symmetryPlane;
section_solid
type angularOscillatingDisplacement;
axis (0 0 1);
origin (2.1267 0 0);
angle0 0;
amplitude 0.035;
omega 22.0;
Using decomposePar with 2 cpus and trying to run with pimpleDyMFoam gave me this :
Create time
[1] [0]
[0]
[0] size 12540 is not equal to the given value of 6367
[0]
[0] file: /data-cfd01/projects/OpenFOAM/pod-1.6.x/run/BridgeSectionDy/processor0/0/pointMotionU::section_solid from line 40 to line 12591.
[0]
[0] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[0] in file /data-cfd01/software/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/Field.C at line 237.
[0]
[0]
[1]
[1] size 12540 is not equal to the given value of 6240
[1]
[1] file: /data-cfd01/projects/OpenFOAM/pod-1.6.x/run/BridgeSectionDy/processor1/0/pointMotionU::section_solid from line 40 to line 12591.
[1]
[1] From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
[1] in file /data-cfd01/software/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/Field.C at line 237.
[1]
I'm not doing anything fancy / not sure what is the problem. The same case runs well on single cpu.
Regards,
PO
podallaire is offline   Reply With Quote
Old   April 19, 2011, 18:00
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
I realise this post is quite old but I have the same problem.
Is there now a solution?
Philip
bigphil is offline   Reply With Quote
Old   April 28, 2013, 23:44
xinguang cui
flying is on a distinguished road
Hey all of foamers:
I also have met this problem, have you solve the problem? If it is, would you please give me some hints?
Thanks and best regards.
Originally Posted by bigphil View Post
Philip
flying is offline   Reply With Quote
Runing InterFoam for 3 D damBreak case Patch issue nishant_hull OpenFOAM Running, Solving & CFD 5 February 18, 2009 00:32
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
[mesh manipulation] TranformPoints gives skewed mesh Possible Bug andersking OpenFOAM Meshing & Mesh Conversion 3 March 25, 2008 21:33
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Automatic Mesh Motion solver michele OpenFOAM Running, Solving & CFD 10 September 26, 2005 08:21
