Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
rhoReactingFoam
Old   August 18, 2009, 09:25
Default rhoReactingFoam
Rachel Vogl
Rachel is on a distinguished road
Since there is no tutorial for rhoReactingFoam, I tried to develop a tutorial case. However I was not successful. It seems that this solver still uses CHEMKIN style for chemistry input.
I tried with foam.inp and foam.dat from another case and it did not work.
Is there some way to make this solver work? I would be thankful if a tutorial case could be put in the OF-1.6.x.
Thanks,
Rachel
Rachel is offline   Reply With Quote
Old   August 19, 2009, 14:06
henry is on a distinguished road
We have uploaded a tutorial for reactingFoam in OpenFOAM-1.6.x:
tutorials/combustion/reactingFoam/ras/counterFlowFlame2D
this could also be altered to run with rhoReactingFoam.
H
henry is offline   Reply With Quote
Old   October 29, 2009, 05:58
Question rhoReactingFoam tutorial,
Hamed Aghajani
haghajani is on a distinguished road
Dear all,
Would you please confrim following changes, which I made to keep "counterFlowFlame2D" working under "rhoReactingFoam"? (but I am not sure it should be the same for every other case)
1- In chemistryProperties; rhoChemistryModel ODEChemsitryModel<gasThermoPhysics>;
2- In ThermophysicalProperties; thermoType hRhoMixtureThermo<reactingMixture<gasThermoPhysics >>;
3- In fvSolution;
pFinal
solver PCG;
preconditioner DILU;
tolerance 1e-7;
reTol 0;
What kind of problems this solver is basically designed to solve?
Thank you in advance,
Hamed
haghajani is offline   Reply With Quote
Old   January 20, 2010, 04:10
jbf
jb
jbf is on a distinguished road
Dear all,
I have to simulate the effects of a Boiling Liquid Expanding Vapor Explosion (BLEVE) on a 3D environment. After being released, the gas may burn. The overpressure due to the exploding evaporation (and the fire ball) must be simulated. Is this "rhoReactingFoam" solver appropriate to do such a calculation ? I found no documentation about this solver and I encountered difficulties to make it run on a 3D mesh for a simple case. Any informations about documentations (or tutorial) would be very appreciated.
I thank you for your attention,
JB
jbf is offline   Reply With Quote
Old   March 27, 2015, 12:08
Smile
Howar
Howard is on a distinguished road
H
Hi, friend. could you tell me how to alter the reactingFoam to rhoReactingFoam tutorial. Do you know what kind of combustion model is used in rhoReactingFoam? also PaSR?
Howard is offline   Reply With Quote
Multiphase flow and Phase change due to heat transferevaporation haghajani OpenFOAM Running, Solving & CFD 88 February 11, 2020 08:00
rhoReactingFoam Rachel OpenFOAM Running, Solving & CFD 3 February 7, 2011 07:34
