Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
UNV mesh converter fails with patch
Like Tree1Likes
  • 1 Post By Saleh Abuhanieh
Old   September 9, 2009, 17:30
Default UNV mesh converter fails with patch
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hi forum
UNV mesh converter succeeds in converting nodes and cells of .unv from SALOME, but fails while building patches of some meshes.
The message is :
Build  : 1.6-53b7f692aa41
Exec   : ideasUnvToFoam mesh.unv
Date   : Sep 09 2009
Time   : 22:26:38
Host   : linux-a6ws
PID    : 5383
Case   : /home/nous/OpenFOAM/nous-1.6/run/run/case
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
 Create time
 Processing tag:2411
Starting reading points at line 3.
Read 4156 points.
 Processing tag:2412
Starting reading cells at line 8318.
First occurrence of element type 11 for cell 1 at line 8319
First occurrence of element type 41 for cell 378 at line 9450
First occurrence of element type 111 for cell 2584 at line 13862
Read 21238 cells and 2206 boundary faces.
 Processing tag:2467
Starting reading patches at line 56340.
For facegroup 0 named outer trying to read 76 patch face indices.
 When reading patches expect Entity Type Code 8
At line 56343
     From function readPatches
    in file ideasUnvToFoam.C at line 464.
 FOAM exiting
Hereafter is an extract of the .unv file. "outer" is the patch name. The failure line 56343 is the last one:
      2052      1936      1962      2063
     23821       111         2         1         7         4
      2236      2220      2461      1745
    -1
    -1
  2467
         0         0         0         0         0         0         0        76
outer
         7       317         0         0         7       318         0         0
         7       319         0         0         7       320         0         0
Any help would be appreciated
Thanks in advance
Jean-Michel
jmf is offline   Reply With Quote
Old   September 10, 2009, 04:43
Mattijs Janssens
mattijs is on a distinguished road
What is the difference between files that work and those that don't? In the source directory ($FOAM_UTILITIES/mesh/conversion/ideasUnvToFoam/) there is a unv/ subdirectory with some sample files.
mattijs is offline   Reply With Quote
Old   September 10, 2009, 18:20
Default Solved : UNV mesh converter fails with patch
jmf
Dear Mattijs
Thanks for your advise : I compared sample .unv files with mine and found out that ideasUnvToFoam failure was caused by useless groups of nodes (Entity code = 7 instead of 8)
Everything runs fine now
Best wishes
J-Michel
Old   October 17, 2009, 05:21
Michael
druckgott is on a distinguished road
How do you have changed this.
In the Unv file or is it posible to change this in salome?
thx
PS because have same problem.
Also starts at 7
druckgott is offline   Reply With Quote
Old   October 17, 2009, 05:53
Default UNV mesh converter fails with entity code 7
jmf
Hi Michael
I just deleted all nodes groups in SALOME before exporting to .unv
Best wishes
J-Michel
Old   October 17, 2009, 06:16
Michael
How can I do this?
Could you give me a short explanation?
I have just start working with salome
thx
Old   October 17, 2009, 08:31
jmf
Dear Michael
- activate Mesh module (scroll list or mesh icon)
- develop your mesh tree completely
--> you should find "Group of Nodes" and "Goup of Faces"
- right mouse button on each group of nodes names and delete them
SALOME in line help is quite nice, have a look inside
Otherwise you might try removing in your .unv file all the lines with entity code 7. It may work, I did not try
Best wishes
J-Michel
Old   October 17, 2009, 09:06
Michael
ok thx I get it
Old   October 18, 2009, 12:32
Mattijs Janssens
do you have a sample file that fails? I'll fix it in the converter itself.
Old   October 18, 2009, 13:55
Michael
Originally Posted by druckgott View Post
ok thx I get it
Ah thank you it works with the solution of jmf
Old   October 18, 2009, 14:33
  #11
jmf
Hi Mattijs
Please find here enclosed a small .unv file
Jean-Michel
Old   October 18, 2009, 16:02
Mattijs Janssens
Thanks. I pushed a fix to 1.6.x so it can read your file and I've added your file as an example to the unv/ subdirectory.
Old   November 12, 2009, 23:17
Default ideasUnvToFoam 1.5 doesn´t work
  #13
Jonathas Assunção de Castro
jonmec is on a distinguished road
Hello ...
I tried to convert a .unv mesh using ideasUnvToFoam utility, but I have always the same problem:
" Cannot open file ...
From function ideasUnvToFoam in file ideasUnvToFoam.C at line 585
FOAM exiting"
Please ... I need help!!
Thanks
jonmec is offline   Reply With Quote
Old   November 13, 2009, 06:19
Mattijs Janssens
You need to supply the complete filename as an argument. This does not sound like a bug so please move this discussion off this OpenFOAM-bugs forum and into e.g. the preprocessing forum.
Old   November 13, 2009, 09:52
Mattijs ... how could I delete my message?
Old   September 1, 2018, 12:34
fede32's Avatar
Federico Agustín Caccia
fede32 is on a distinguished road
Originally Posted by jmf View Post
Dear Michael
Best wishes
J-Michel
Hi, I'm having the same error. I have not group of nodes. I dont know how to fix it.
fede32 is offline   Reply With Quote
Old   January 4, 2019, 11:08
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
It seems there is a problem in ideasUnvToFoam with foam-Extended fork.
The foam can read the polyMesh folder (it works for me for many cases but not 100% sure) which has been generated using OpenFoam forks.
So, you may use ideasUnvToFoam with OpenFoam then copy the folder.
Saleh
wyldckat likes this.
Saleh Abuhanieh is offline   Reply With Quote
converter, mesh, patch, unv
Grid check fails after sliding mesh calculation Tito FLUENT 0 March 3, 2008 14:28
Moving interface patch using mesh subsets lr103476 OpenFOAM Running, Solving & CFD 0 January 10, 2008 16:14
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Mesh Mignard FLUENT 2 March 22, 2000 05:12
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
