Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
gmshToFoam: small fix for gmsh 2.4.x import
Old   September 11, 2009, 04:42
Default gmshToFoam: small fix for gmsh 2.4.x import
Etienne Lorriaux
elorriaux is on a distinguished road
it's not really a bug but a small fix since the physical entities format has been changed in the last gmsh-2.4 release. The format now takes into account the entities type (line, surface, volume).
I've modified the source to handle this change and the file is attached to this post. It should work also with the previous format.
Hope it will help.
Regards, Etienne.
elorriaux is offline   Reply With Quote
Old   September 11, 2009, 05:51
Mattijs Janssens
Thanks. I pushed it to 1.6.x. Do you have a sample file I can test it on?
Old   September 11, 2009, 07:52
Etienne Lorriaux
Sure I can, but the files are too heavy to be uploaded here (even with gzip).
Maybe you can give me your mail in a private message.
Etienne.
Old   October 14, 2009, 15:02
Michael
druckgott is on a distinguished road
can you send me a testfile
druckgott is offline   Reply With Quote
Old   November 23, 2009, 15:30
Paul
pajofego is on a distinguished road
Is it possible to upload a compiled gmshToFoam Linux version with the actual patch? I've a problem in compiling the OpenFoam source.
Thank in advance,
pajofego
pajofego is offline   Reply With Quote
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
[Gmsh] Modified gmshToFoam to help import hexahedral and prism elements from Gmsh adorean OpenFOAM Meshing & Mesh Conversion 1 April 18, 2005 08:19
