Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Recent updates done to libforces
Old   May 28, 2010, 08:42
Default Recent updates done to libforces
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Good day,
I'm very impressed with the new updates that were done in libforces / the
ability to use constraints and restraints is very interesting.
I just have a simple suggestion regarding the springs. With the report option "on",
the spring lengths and angles are displayed. However, I understand that the
magnitude is returned, meaning that the values are always > 0. It would be a
good thing if the "sign" would be included as well / it makes it easier to track
the exact position in time of the rigid body.
Regards,
PO
podallaire is offline   Reply With Quote
Old   May 31, 2010, 06:47
Graham Macpherson
gmacpherson is on a distinguished road
Thanks.
I have pushed this to 1.6.x.
What to do with the sign of the angle was unambiguous, but linear springs can start with zero length and move in any direction, so the concept of a sign for their displacement is not always clear. I added reporting of the vector from the anchor to the instantaneous attachment point on the body.
Graham
gmacpherson is offline   Reply With Quote
Old   May 31, 2010, 10:54
Thanks for the changes / will give it a try.
Another question -> did you try to run a case with single cpu for some time
and then, decompose the latest time step for a multi-cpu run ? I most be
missing something because I just cannot run multi-cpu if I try that. I guess I
need to move the latest time/polyMesh/points file in constant/polyMesh before
decomposing or something like that ... Not sure what is the best practice for
this.
Regards,
PO
Old   June 2, 2010, 05:10
Graham Macpherson
There are some issues to do with decomposing moving mesh cases in 1.6.x that have been fixed in our internal development version.
For the moment, best practice would be to decompose the case at the start and do everything in parallel.
Graham
Old   June 3, 2010, 08:20
Ok, thanks Graham
Old   June 10, 2010, 10:33
Good day Graham,
I have another question related to the definition of the damping for the
restraints. Can you confirm that the damping input is in fact the damping ratio,
in percentage, meaning that an input of 0.5 means 0.5% damping ratio (or
0.005). Also, can you confirm that this works for both axial spring and vertical
spring / I'm facing some discrepancies in my decay tests.
Regards,
PO
Old   June 10, 2010, 10:51
Graham Macpherson
It is not a damping ratio, it is a damping coefficient.
For the definition see linearSpring.H
//- Damping coefficient (Ns/m)
scalar damping_;
and .C
restraintForce = -stiffness_*(magR - restLength_)*r - damping_*(r & v)*r;
Graham
Old   October 6, 2010, 19:13
Default Some results
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Hi I made some fsi videos using pimpleDyMFoam, but quite rudiment, It is a wind tunnel case. I found the new patch is very capable for some rigid body movement simulation, Good.
Video Link
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Paper Request (recent years, 2003-2005) rt Main CFD Forum 1 February 27, 2007 09:35
Share updates for star-cd v3.26 or v3.24 denizen Siemens 10 December 16, 2006 15:30
most recent research area in CFD omr Main CFD Forum 0 March 11, 2005 02:33
Gambit on RedHat 7.3 with recent nvidia driver Jonas Larsson FLUENT 4 May 6, 2003 10:46
Recent Flame-Wars Jonas Larsson Main CFD Forum 12 October 26, 2001 16:47
