July 14, 2010, 09:51 |
atmBoundaryLayerInletVelocity profiles
Ivo
Rep Power: 15 |
I recently started using OpenFoam for modeling atmospheric processes. Since I am new to the program and OpenFoam version 1.7 includes a tutorial case, turbineSiting, which uses a simulated atmospheric boundary layer I decided to start by stuying this tutorial. The first problem I encountered was the fact that the Allrun script references the non-existing solver simpleWindFoam. However, since the case seems to run just fine using simpleFoam I used this instead. Having run the case successfully I started to play with the input parameters and found out that the atmBoundaryLayerInletVelocity boundary condition displays some very strange behaviour. Defining the ABL by setting the velocity Uref to 15 m/s at a height Href of 300 meters and not changing any of the other parameters I get a velocity profile as shown in the attachment. The profile clearly doesn't reach a velocity of 15 m/s at the specified height of 300 meters, but around the 300 meter mark it does quickly increase to that value, after which it stays constant. The formulas in the boundary condition source code seem valid enough to me, so perhaps there is a problem with one of the parameters which get passed to/from the routine? Or maybe simpleFoam is an improper solver for this problem after all? Thank you very much in advance! |
July 15, 2010, 03:47 |
Rep Power: 22 |
the simpleWindFoam demonstration solver is in the
OpenFOAM-1.7.?/tutorials/incompressible/simpleWindFoam/simpleWindFoam directory. In the OpenFOAM-1.7.?/tutorials/incompressible/simpleWindFoam directory type foamRunTutorials which will compile simpleWindFoam and run it. H |
July 15, 2010, 12:28 |
Ivo
Rep Power: 15 |
Hi Henry,
Thank you very much for your reply. I'm sorry I didn't know about the way to compile the simpleWindFoam solver. It tried your suggestion and I can now indeed compile and use it. However, the resulting velocity profile I get is unchanged from my original post, so it seems the problem is not with the solver. Do you perhaps have another suggestion what I could try? Best wishes, Ivo |
July 16, 2010, 05:35 |
atmBoundaryLayerInletVelocityFvPatchVectorField
Sergio Ferraris
Rep Power: 15 |
There was an error in the expression for the inlet velocity in the file
atmBoundaryLayerInletVelocityFvPatchVectorField.C It was updated in our git repository for 1.7.x Thanks S |
July 16, 2010, 10:32 |
Ivo
Rep Power: 15 |
It now works fine, many thanks!!!
Ivo |
July 30, 2010, 11:05 |
siri
Rep Power: 16 |
Dear
I’m also working with the turbineSiting tutorial. It runs fine and I will now change the terrain file to a terrain file of my interest. I manage to use snappyHexMesh and a checkMesh gives me good result. But when I try to run simpleWndFoam I continuing to get this error massage. The only thing I change was the terrain. It looks like it reding the field p fine but it stops when rading U. I’m not used at reading different error massages and I would be very grateful if anyone can tell me what this message is indicating; #13 __libc_start_main in "/lib/libc.so.6"#14 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/user/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linuxGccDPOpt/simpleWindFoam" |
September 27, 2012, 04:54 |
I am actualy trying to compile atmBoundaryLayerInletVelocity the things is i get that error : m::incompressible::atmBoundaryLayerInletVelocityFv PatchVectorField const&, Foam::fvPatch const&, Foam:imensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::fvPatchFieldMapper const&)' Make/linuxGccDPOpt/simpleFoam.o:simpleFoam.C.text+0x3090): first defined here Make/linuxGccDPOpt/atmBoundaryLayerInletVelocityFvPatchVectorField.o: (.bss+0x4): multiple definition of `Foam::incompressible::atmBoundaryLayerInletVeloci tyFvPatchVectorField::debug' Make/linuxGccDPOpt/simpleFoam.o.bss+0x4): first defined here Make/linuxGccDPOpt/atmBoundaryLayerInletVelocityFvPatchVectorField.o: (.bss+0x2): multiple definition of `Foam::incompressible::addatmBoundaryLayerInletVel ocityFvPatchVectorFieldpatchConstructorTofvPatchVe ctorFieldTable_' Make/linuxGccDPOpt/simpleFoam.o.bss+0x2): first defined here Make/linuxGccDPOpt/atmBoundaryLayerInletVelocityFvPatchVectorField.o: (.bss+0x1): multiple definition of `Foam::incompressible::addatmBoundaryLayerInletVel ocityFvPatchVectorFieldpatchMapperConstructorTofvP atchVectorFieldTable_' Make/linuxGccDPOpt/simpleFoam.o.bss+0x1): first defined here Make/linuxGccDPOpt/atmBoundaryLayerInletVelocityFvPatchVectorField.o: (.bss+0x0): multiple definition of `Foam::incompressible::addatmBoundaryLayerInletVel ocityFvPatchVectorFielddictionaryConstructorTofvPa tchVectorFieldTable_' Make/linuxGccDPOpt/simpleFoam.o.bss+0x0): first defined here collect2: ld a retourné 1 code d'état d'exécution make: *** [/home/gregoire/OpenFOAM/OpenFOAM-2.1.1/platforms/linuxGccDPOpt/bin/bounSimpleFoam] Erreur 1 for come to here i had do : • Add .atmBoundaryLayerInletVelocityFvPatchVectorField.C to the second line of Make/files, and modify the final line to EXE = $(FOAM_USER_APPBIN)/ • Add #include "parabolicVelocityFvPatchVectorField.H" in the header of your simpleFoam.C file, so that the solver knows the new boundary condition. • wclean rm -r Make/linux* wmake somebody can help me ? or at least give me a good website for compile atmBoundaryLayerInlet |
abl, boundary condition, turbinesiting |
[ICEM] Reading/Writing Profiles in tilted geometry | qascapri | ANSYS Meshing & Geometry | 0 | August 14, 2009 11:04 |
Laminar wing profiles and drag | gregorv | OpenFOAM Running, Solving & CFD | 4 | December 4, 2007 13:25 |
Gas flow profiles in mixing tank | srinivas | FLUENT | 0 | November 8, 2006 04:52 |
Velocity profiles | Rex | FLUENT | 4 | July 23, 2002 19:35 |
component flow direction fieldnames for boundary profiles required. | Ricky Wong | FLUENT | 1 | May 12, 2000 10:36 |
