Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug in wall distance calculation
Old   November 24, 2010, 09:41
Default Bug in wall distance calculation
David Hora
david is on a distinguished road
Hi everybody
I found a problem with the wall distance calculation in conjunction with cyclic patches in OpenFOAM 1.7.x and 1.5-dev. I will describe it for 1.5-dev as the rotationaAngle in 1.5-dev could help us to find the root of the problem.
Unfortunately I couldn't reproduce this bug with simpler meshes. The geometry is the inlet section (straight pipe) of my case with rotational periodicity (360°/7). I converted the mesh with fluentMeshToFoam from a fluent mesh file. It doesn't help to use fluent3DMeshTofoam. checkMesh doesn't report any problem. The settings of the cyclic patch are:
PERIODIC
type cyclic;
nFaces 3120;
startFace 236890;
featureCos 0.9;
transform rotational;
rotationCentre (0 0 0);
rotationAxis (0 0 1);
rotationAngle -51.42857;
This setup gives me a "correct" Urel, k, omega and pressure but the result of the wall distance is wrong. I get the same results in 1.7.x and 1.5-dev.
If I change the rotationAngle to 51.42857, the simulation does not converge due to the wrong transformation of the velocity vectors at the cyclic patches. The big surprise is that the wall distance seems to be correct in this case. The attached image shows the wall distance y for a positive and negative rotation angle.
I could imagine that the problem can be found somewhere in FaceCellWave.C. I will try to find it but maybe somebody is faster than me. If anybody is interested I can send him the mesh.
Best regards
David
david is offline   Reply With Quote
Old   November 26, 2010, 11:32
David Hora
http://www.openfoam.com/mantisbt/view.php?id=91
Old   December 1, 2010, 11:46
David Hora
fixed in 1.7.x
Old   March 15, 2011, 09:32
jms
José
jms is on a distinguished road
I am using the files in yPlus.tar.gz from the thread http://www.cfd-online.com/Forums/ope...tml#post277386. This uses the nearWallDist.H file you are talking about in here. I had a look at the values of this d (nearWallDistance). I expected them to be the same all over the airfoil I am computing (since I am using a mesh with constant 1st cell height of 2.75e-5). To be sure that this is constant after having converted it to OF, I checked that in a post processor and this 1st cell height is constant, so there are no "conversion issues"). :S
What I get is that this value of nearWallDistance oscillates between 9e-6 and 1.3e-05. I don´t like this because the value of the computed yPlus then is not perfect.
Can you tell me anything about this?
Thanks,
Regards,
José
jms is offline   Reply With Quote
Wall Shadow interfering with Nusselt Number calculation? ryzd FLUENT 1 March 3, 2010 06:16
calculation of wall heat flux in CHT richard CFX 1 July 23, 2009 09:00
cell to wall distance azmir Siemens 0 March 27, 2007 01:03
MACRO FOR DIMENSIONLESS WALL DISTANCE Y+ ? Wael FLUENT 7 October 6, 2005 04:24
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
