Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
reactingFoam solution is strongly dependent on time step size
Old   July 12, 2011, 08:12
Default reactingFoam solution is strongly dependent on time step size
Andras Horvath
andras is on a distinguished road
Dear Foamers and CFD-hackers,
This is a (desperate) cross-post from the "Running+Solving" section.
I am using OpenFoam-1.7.1 (git: 03e7e056c215). I noticed that there is a tight dependence between "T gas max" and the CFL number in the reactingFoam tutorial case. Lower Courant-numbers lead to lower maximum temperatures and vice versa.
In "applications/solvers/combustion/reactingFoam/chemistry.H" the line
// Chalmers PaSR model
kappa = (runTime.deltaT() + tc)/(runTime.deltaT() + tc + tk);
with an _absolute_ runTime.deltaT() clearly is an error, isn't it?
Also to test mesh dependence of the solution i tried this:
I refined the original mesh from the tutorial from 4000 -> 400000 cells (x10 in both directions) and ran the tutorial again. It crashes both in single and parallel at around 0.0007s. I also tried removing runTime.deltaT() from the kappa-equation in the source code, recompiled it, and ran it to the same effect. At some point epsilon becomes negative and the solver crashes.
Can this be considered a bug or is it just a defficiency in the underlying Chalmers PaSR model?
Cheers,
Andras
andras is offline   Reply With Quote
Old   July 13, 2011, 02:45
Alberto Passalacqua
According to http://www.openfoam.com/mantisbt/view.php?id=249 it seems not to be a bug, but it depends on the model. You might want to refer to the original literature to be safe.
Alberto Passalacqua
Old   July 13, 2011, 07:50
Default Chalmers PaSR model
Andras Horvath
According to "F. P. Kärrholm: Numerical Modelling of Diesel Spray Injection, Turbulence Interaction and Combustion, Department of Applied Mechanics, Chalmers University of Technology, Göteborg, Sweden (2008)" the reaction rate multiplier kappa is defined by
kappa = tc / (tc + tmix)
where tc is the chemical time scale and tmix is the turbulence time scale, where
tmix = Cmix * k/epsilon
using Cmix=0.03.
The source code of reactingFoam introduces the absolute time step into the k-equation, and uses Cmix=0.1 (in the tutorial case):
---- OpenFOAM/OpenFOAM-1.7.1/applications/solvers/combustion/reactingFoam/chemistry.H ----
Cheers,
Andras
Old   July 13, 2011, 10:28
Alberto Passalacqua
I guess the implementation is older. However, I would write this in you bug report ;-)
Alberto Passalacqua
cfl, crash, mesh, reactingfoam
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
IcoTopoFoam case is aborted deepblue17 OpenFOAM Running, Solving & CFD 25 December 2, 2010 14:20
Is there a way to write the time step size, time a may FLUENT 6 November 22, 2009 11:52
Navier-Stokes time step size Martin Main CFD Forum 2 June 6, 2008 03:38
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
