Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solidMechanics] a defect of solidMechanics in foam-extend-3.0
Old   June 3, 2014, 07:57
Default a defect of solidMechanics in foam-extend-3.0
xuhe-openfoam
bieshuxuhe is on a distinguished road
hi,
I found a defect of solidMechanics in foam-extend-3.0 !
for example , I created a myelasticNonLinULSolidFoam just changing the elasticNonLinULSolidFoam
from
    Info<< "Reading accumulated displacement field U\n" << endl;
    volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        mesh,
        dimensionedVector("zero", dimLength, vector::zero)
to
    volVectorField Usolid
        IOobject
            "Usolid",
            runTime.timeName(),
            mesh,
        mesh,
of course I did all the necessary changes which means replacing the U by Usolid at other place .
then, wmake to get the myelasticNonLinULSolidFoam ! and I created a case that replace U by Usolid too !
when we use this new solver to run a case which needs to use the accumulated displacement field(for example use the timeVaringFixedDisplacement boundary) , it will be error
Starting time loop
Time = 0.01
--> FOAM FATAL ERROR:
    request for volVectorField U from objectRegistry region0 failed
    available objects of type volVectorField are
5
Usolid
DUPrevIter
DU
divDSigmaLargeStrainExp
divDSigmaExp
    From function objectRegistry::lookupObject<Type>(const word&) const
    in file /home/sxh/foam/foam-extend-3.0/src/foam/lnInclude/objectRegistryTemplates.C at line 139.
FOAM aborting
we know that the "Usolid" should be the "volVectorField U from objectRegistry region0" , and the "Usolid" is a available object !
actually , I first found this problem in the icoFsiElasticNonLinULSolidFoam which use Usolid instead of U in solid part , for there is a U in fluid part !
I don't know what is wrong . maybe it is a bug ?
what do you think ?
thanks
bieshuxuhe is offline   Reply With Quote
Old   June 3, 2014, 09:29
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Many of the solid mechanics boundary conditions (in $FOAM_SRC/solidModels/fvPatchFields) expect the displacement field to be called "U", and have this hard-coded into the boundary condition.
So you would need to modify the specific boundary condition if you want to change the name of the displacement field, or add an optional variable to the boundary condition definition giving the name of the displacement field.
Best regards,
Philip
bigphil is offline   Reply With Quote
solidmechanics
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
