Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] Angular momentum conservation algorithms in solids4Foam
Old   May 13, 2024, 20:40
Post Angular momentum conservation algorithms in solids4Foam
Smith John
Ma cHAO is on a distinguished road
Question:
The solids4Foam solver uses the total Lagrangian formulation and the updated Lagrangian formulation to compute large strains and rotations of solids, which is different from the usual solid dynamics that considers linear and angular momentum. I see that the boundary condition implementation takes into account the case of fixed rotation, does this mean that this solver automatically satisfies the conservation of angular momentum, i.e. the nonlinear geometric method solver can also be applied to rotational problems, such as the rotation of 3D beams (rotation)?
This problem comes from comparing the solids4Foam toolbox with the explicit dynamics toolbox -'explicitSolidDynamics', which I saw in the source code has a posteriori angular momentum projection algorithm for angular momentum conservation.
Angular momentum is not necessarily conserved, as the deformation gradient F is no longer 'strongly' obtained as the material gradient of the current geometry, as mentioned in "A first-order hyperbolic framework for the computation of dynamics of solids with large strains: a total Lagrangian scheme centered on the upwind cell".
I'm not quite sure how this is considered in solids4Foam.
Ma cHAO is offline   Reply With Quote
angular momentum, rotation
Angular momentum flux between regions atheodor CONVERGE 4 July 22, 2022 14:28
Angular momentum flux through faceZone askjak OpenFOAM Programming & Development 1 March 5, 2010 14:42
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
conservation angular momentum swirling flow Roberto Main CFD Forum 0 October 20, 2007 11:15
Angular momentum conservation? Barry Main CFD Forum 19 April 11, 2002 10:37
