[swak4Foam] Trouble setting groovyBC interFoam Inlet BC
Like Tree1Likes
  • 1 Post By gschaider
Old   June 30, 2012, 14:37
Default Trouble setting groovyBC interFoam Inlet BC
Matthew Denno
mgdenno is on a distinguished road
As indicated in the post title, I am trying to use groovyBC to set the inlet boundary condition for a interFoam simulation. I am using OpenFOAM 2.1.0 running on kubuntu 11.10. The attached picture (colored as p_rgh) shows a 2D view of the problem which is flow in a channel over a spillway. The inlet is on the right, the outlet is on the left, top is atmosphere, bottom is wall, and front and back are symmetry plane. Historically I have split my inlet patch into 2 separate patches, one for air and one for water. I was hoping that I would be able to use groovyBC to accomplish the same thing with one patch so that I can change the inlet water level without changing my mesh. Anyway, the simulation seems to run ok, and the water surface looks ok (although I haven't compared to physical model data yet), but the pressure at the inlet seems to be funky. You can see in the picture that the p_rgh is 0 at the inlet, and p (not shown) has a significant negative pressure at the inlet.
This seems incorrect to me. Can anyone provide any insight regarding what is happening? Are my boundary conditions (below) specified incorrectly?
p_rgh:
|  \\    /   O peration     | Version:  2.1.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    top
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    bottom
        type            buoyantPressure;
        value           uniform 0;
    inlet
        value           uniform 0;
    outlet
       type            totalPressure;
       p0              uniform 0;
       U               U;
       phi             phi;
       rho             rho;
       psi             none;
       gamma           1;
       value           uniform 0;
    walls
        type            symmetryPlane;
    wes
        value           uniform 0;
alpha1:
FoamFile
    version     2.0;
    format      ascii;
    object      alpha1;
dimensions      [0 0 0 0 0 0 0];
boundaryField
    top
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    bottom
        type            zeroGradient;
    inlet
       type             groovyBC;
       valueExpression "1";
       fractionExpression "(pos().z<28) ? 1 : 0";
       value            uniform 1;
    outlet
        type            inletOutlet;
        value           uniform 0;
    walls
        type            symmetryPlane;
    wes
        type            zeroGradient;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    top
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    bottom
        type            slip;
    inlet
       type            groovyBC;
       valueExpression "(pos().z<28) ? vector(1.981,0,0) : vector(0,0,0)";
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    walls
        type            symmetryPlane;
    wes
        type            slip;
Thanks in advance. I look forward to your input.
mgdenno is offline   Reply With Quote
Old   June 30, 2012, 15:47
Nima Samkhaniani
nimasam is on a distinguished road
have you ever tried it with zeroGradient for inlet pressure?
nimasam is offline   Reply With Quote
Old   June 30, 2012, 16:52
Matthew Denno
Hi nimasam,
Thanks for your input. Yes, I have tried with zeroGradient for pressure at inlet. it yields very similar results.
The weird thing is that my boundary conditions are the same as another case where I don't see those weird pressure results.
Not sure where to go from here...
MD
And checkMesh says all is good...
Old   July 1, 2012, 04:49
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
<snip>
A remark to the graph: Am I right that you used point-values and not cell values for visualizing? DON'T DO THAT if you want to see the "real values". Point values mean that you're looking at how Paraview interpolates/interprets OFs data (use point-values ONLY when you're preparing picture for a presentation)
Last thing: have a look at p and p_rgh directly (with "less" or a text editor) and see what OF has written in "values" (at the end of the day these are the only values that really count). It is my suspicion that there are no values present on the inlet in p_rgh and paraview therefor assumes them to be 0 (as the reader doesn't know about the real physical meaning of the bCs)
mgdenno likes this.
gschaider is offline   Reply With Quote
Old   July 1, 2012, 08:16
Matthew Denno
Bernhard,
Thanks so much for your suggestion. You are absolutely correct. The values I was seeing were only paraviews interpretation of the data. The real cell values are much more believable.
I have to admit, now that you say this, I recall seeing another recent post regarding a different "problem" where you made the same suggestion to another user. At the time I though, "yeah that makes lots of sense", then when it came to my own case I pushed forward with the interpolated values thinking I had a problem (blinders on).
Thanks for all the work you do on OF and the time you spend answering questions on the forums, and of couse thanks again for your help on my problem.
MD
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 16:36
problem with inlet BC setting Tanjina Fluent Multiphase 4 July 1, 2013 13:06
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
Warning 097- AB Siemens 6 November 15, 2004 04:41
