[swak4Foam] Problems finding groovyBC library
Old   January 18, 2013, 08:52
Default Problems finding groovyBC library
Duncan Weatherhead
duncan21187 is on a distinguished road
Hi All
I am trying to use groovyBC to simulate the exhaust valve pressure profile of an IC engine. I have installed groovyBC as part of the latest swak4Foam package in a directory titled src within my user folder. Having added
libs (
"libOpenFOAM.so"
"libgroovyBC.so"
"libgroovyStandardBCs.so");
to the controlDict I then tried to run the case but consistently receive the error
FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96
could not load "libgroovyBC.so"
--> FOAM Warning :
could not load "libgroovyStandardBCs.so"
indicating the libraries have not been found.
Can anyone suggest reasons why this could be?
Many thanks, Duncan
duncan21187 is offline   Reply With Quote
Old   January 18, 2013, 16:31
Assistant Moderator
Bernhard Gschaider
Originally Posted by duncan21187 View Post
Hi All
libs (
"libOpenFOAM.so"
"libgroovyBC.so"
FOAM Warning :
--> FOAM Warning :
No idea. Compilation was OK? Check whether the library is there with
ls $FOAM_USER_LIBBIN
and whether $FOAM_USER_LIBBIN is in the $LD_LIBRARY_PATH
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 19, 2013, 09:02
Duncan Weatherhead
Many thanks, could not find library so re-compiled and found multiple compilation errors, I suspect that I have downloaded a bad source file.
groovybc, libraries, swak4foam
ERROR: unable to find library HJH CFX 6 February 26, 2019 06:52
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 07:17
[swak4Foam] groovyBC oscilating pipe flow problems duncan21187 OpenFOAM Community Contributions 8 January 27, 2013 05:21
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 11:51
Problems in personal library compilation shrina OpenFOAM 3 February 23, 2009 11:12
