[waves2Foam] wave2foam dictionary waveProperties objectRegistry request failed
Like Tree1Likes
  • 1 Post By sophie_l
Old   March 15, 2013, 06:18
Post wave2foam dictionary waveProperties objectRegistry request failed
sophie_l is on a distinguished road
I am running interFoam with wave2foam. The mesh, setFields, setWaveField stuff and etc are fine, however, when I type $ interFoam in the terminal, fatal error occurs.
--> FOAM FATAL ERROR:
request for dictionary waveProperties from objectRegistry region0 failed
available objects of type dictionary are
2
fvSchemes
fvSolution
From function objectRegistry::lookupObject<Type>(const word&) const
in file /opt/openfoam171/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 139.
FOAM aborting
I've included the wave2foam library in the controlDict (libs ( "libwaves2Foam.so" ) ), and the 'waveProperties' is placed in the 'constant' directory. Could you help indicate what I should do please?
Thanks a lot in advance!
Kummi likes this.
sophie_l is offline   Reply With Quote
Old   March 15, 2013, 07:40
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Sophie,
This is not possible. You need to use waveFoam instead of interFoam.
/ Niels
ngj is offline   Reply With Quote
Old   March 15, 2013, 08:19
Hi Niels,
Thanks a lot! I am using openfoam 1.7.1. I thought I've installed wave2foam without error messages. However, the solver waveFoam cannot be found. So I tried to compile waveFoam from
/OpenFOAM/waves2Foam/applications/solvers/solvers170/waveFoam, using 'wmake', and the following errors occured.
Making dependency list for source file waveFoam.C
SOURCE=waveFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/lnInclude -I/opt/openfoam171/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam171/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/lnInclude -DOFVERSION=170 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/waveFoam.o
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’:
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:11:10: warning: unused variable ‘transonic’ [-Wunused-variable]
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:14:9: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:3:9: warning: unused variable ‘nCorr’ [-Wunused-variable]
/opt/openfoam171/src/finiteVolume/lnInclude/readPISOControls.H:8:10: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/lnInclude -I/opt/openfoam171/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam171/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/lnInclude -DOFVERSION=170 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linuxGccDPOpt/waveFoam.o -L/opt/openfoam171/lib/linuxGccDPOpt \
-linterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -L/home/yaru/OpenFOAM/yaru-1.7.1/lib/linuxGccDPOpt -lwaves2Foam -lOpenFOAM -liberty -ldl -lm -o /home/yaru/OpenFOAM/yaru-1.7.1/applications/bin/linuxGccDPOpt/waveFoam
/opt/openfoam171/lib/linuxGccDPOpt/libinterfaceProperties.so: undefined reference to `typeinfo for Foam::alphaContactAngleFvPatchScalarField'
collect2: ld returned 1 exit status
Could you give some suggestions please?
Thank you very much!
Sophie
Old   March 15, 2013, 08:41
ngj
Hi Sophie,
It is because there are subtle differences between the versions. Please follow the guide on http://openfoamwiki.net/index.php/Contrib/waves2Foam, which in detail describes the needed modifications in order to obtain waveFoam from interFoam.
However, how come you have settled on OF171? More recent version exist, and waves2Foam compiles on all of them (though, no solver is distributed along with OF2.2.0 as of now).
Kind regards,
Niels
Old   March 15, 2013, 10:09
Hi Niels,
Thank you so much for your patience with a linux dummy. I've modified waveFoam.C from interFoam (v1.7.1) as instructed by the website in your post. When I try to compile it, the 'undefined reference' stuff occur again. I saw some posts mentioning the same problem, but didn't work out how to fix it. Just wondering could you shed some light on this please?
SOURCE=waveFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/lnInclude -I/opt/openfoam171/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam171/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/lnInclude -DOFVERSION=171 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/waveFoam.o
g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/transportModels -I/opt/openfoam171/src/transportModels/incompressible/lnInclude -I/opt/openfoam171/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam171/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/lnInclude -DOFVERSION=171 -I./../../../../src/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linuxGccDPOpt/waveFoam.o -L/opt/openfoam171/lib/linuxGccDPOpt \
-ltwoPhaseInterfaceProperties -lincompressibleTransportModels -lincompressibleTurbulenceModel -lincompressibleRASModels -lincompressibleLESModels -lfiniteVolume -L/home/yaru/OpenFOAM/yaru-1.7.1/lib/linuxGccDPOpt -lwaves2Foam -lOpenFOAM -liberty -ldl -lm -o /home/yaru/OpenFOAM/yaru-1.7.1/applications/bin/linuxGccDPOpt/waveFoam
Make/linuxGccDPOpt/waveFoam.o: In function `main':
waveFoam.C.text.startup+0xe3a): undefined reference to `Foam::interfaceProperties::interfaceProperties(Fo am::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::IOdictionary const&)'
waveFoam.C.text.startup+0x3a9e): undefined reference to `Foam::interfaceProperties::calculateK()'
Many thanks
Sophie
Old   March 17, 2013, 06:05
ngj
Hi Sophie,
Sorry for the latency.
I have seen this type of error many times, however, but only if I use a version of interFoam, which is not compatible with the version of OpenFoam. Now, that you have used interFoam from 171, it hardly makes sense.
The only way forward (at least when sticking to 1.7.1) is to try, whether you are able to compile interFoam without any modifications at all. If that is possible, you can try to add the waves2Foam functionalities one at the time.
Kind regards,
Niels
Old   March 17, 2013, 19:43
Hi Niels,
Thank you so much for your guidance. Luckily my supervisor helped me with the compilation and it's done now. However, I can only run waveFoam with laminar mode, and cannot run it with RASModel, the error message is
Unknown turbulenceModel type RASModel
Valid turbulenceModel types are :
1
laminar
From function turbulenceModel::New(const volVectorField&, const surfaceScalarField&, transportModel&)
in file turbulenceModel.C at line 101.
FOAM exiting
I saw some threads having the same problem, which was mainly due to the update of their operating system. However, I didn't update the operating system on my pc. Just wondering what would be the cause.
Thanks!
Sophie
Old   March 18, 2013, 01:39
ngj
Hi Sophie,
It looks like an upstream error. interFoam/waveFoam should automatically detect your choice of turbulence model, i.e. laminar, reynolds averaged, LES.
You have to be more specific in what you change where, otherwise I can only be guessing on what goes wrong.
/ Niels
Old   March 19, 2013, 08:14
Hi Niels,
Thanks a lot for your reply. I copied the interFoam folder and renamed it as solver171. A waveFoam.C was modified as instructed by the wave2foam wiki page. Then I changed the 'Make/options' file as follows
EXE_INC = \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
-I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
-I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-DOFVERSION=171 \
EXE_LIBS = \
-linterfaceProperties \
-ltwoPhaseInterfaceProperties \
-lincompressibleTransportModels \
-lincompressibleTurbulenceModel \
-lincompressibleRASModels \
-lincompressibleLESModels \
-lfiniteVolume \
-L$(FOAM_USER_LIBBIN) \
-lwaves2Foam
After compilation, laminar cases can be run but when using RASModel, the aforementioned error occurs.
I didn't change anywhere else, so I am thinking the 'options' file should give out some clue.
Many thanks,
Sophie
Old   March 19, 2013, 09:14
ngj
Can you run your standard interFoam tutorials with anything but laminar? If this is possible, then I really do not understand the problems.
Kind regards,
NIels
Old   March 19, 2013, 10:59
I've run the tutorial case ras/dambreak with interFoam and everything is ok! Another strange thing is that the error message occurred again when I tried to set up the alpha1 value for the waveFoam case. When I type 'setFields' in the terminal, it says
Reading setFieldsDict
Setting field default values
Setting volScalarField alpha1
3
fvSchemes
fvSolution
setFieldsDict
totally lost now...Just wondering could you get a clue from this.
Many thanks,
Sophie
Old   March 19, 2013, 11:08
ngj
Hi Sophie,
I recommend that you use setWaveField as setFields does not load waveProperties, which is needed by the boundary conditions in alpha1.
Kind regards,
Niels
boundary conditions, dictionary, objectregistry, wave2foam
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
