[PyFoam] how to interrupt pyFoamPlotWatcher.py
Old   May 28, 2013, 04:18
Default how to interrupt pyFoamPlotWatcher.py
peter fox
peettter is on a distinguished road
What is the most suitable way to interrupt the excellent pyFoam tool pyFoamPlotWatcher.py?
I do not want to interrupt the simulation, I just want to stop the watcher such that I again have access to the command line. When press CTRL+C, i do get the message "Watcher: keyboard interrupt", but nothing else happens afterwards.
thanks in advance
peettter is offline   Reply With Quote
Old   May 28, 2013, 06:57
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
thanks in advance
Does this happen all the time or just at some times? The problem is that it happens only some times (for me) and is thus awkward to debug. The problem is that in order to do the plotting and other stuff smoothly the utility uses some multithreading and sometimes not all threads are terminated correctly.
The workaround is to suspend the watcher with CTRL-Z and then kill it with "kill %3" (or whatever is the number that was written by the shell). Alternatively you can of course kill with the PID you get with ps
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   May 28, 2013, 07:24
peter fox
Thanks for the answer. The problem happens all the time (although I have used the tool only for one case so far)...
i will go ahead with the CTRL-Z workaround.
[PyFoam] Using pyFoamPlotWatcher.py To Plot Residuals m_ridzon OpenFOAM Community Contributions 22 January 26, 2021 18:48
Interrupt control during system coupling? khhan0543 CFX 0 November 28, 2017 01:32
Interrupt Control for a expression-based monitor kohyar CFX 2 December 1, 2016 08:53
[ICEM] ICEM CFD Interrupt function Whitebear ANSYS Meshing & Geometry 2 April 23, 2015 02:47
logical expression for cfx interrupt control wjy-c CFX 0 November 29, 2013 04:30
