[swak4Foam] problem with a parabolic velocity profile
Like Tree2Likes
  • 2 Post By billie
Old   June 4, 2013, 07:53
Default problem with a parabolic velocity profile
Claudio
Claudio87 is on a distinguished road
Hi all!
I'm trying to apply, as BC, a parabolic velocity profile at the inlet of my problem (a pipe) using groovyBC (from swak4foam).
It works, in the sense that I have a parabolic profile, but:
I would like to have velocity values (only in x direction) between 0 and 2
instead:
I obtain a profile going from -0.11924 (negative!!) to 1.993 , looking only Ux in paraview,
and from 1.929e-5 to 1.993 considering the Umagnitude. (see attached pictures)
I'm worried about the negative value overall. Do you have any idea why I obtain these results instead of what I expected (zero?!
Here how I applied the condition:
        type			groovyBC;
	value			uniform (1 0 0);
        variables		"Vm=2;yp=pos().y;zp=pos().z+0.005;h=-max(zp);a=-Vm/(h*h);b=Vm;";
	fractionExpression	"1";
        valueExpression		"vector(a*((yp*yp)+(zp*zp))+b,0,0)";
I used the expression for a poiseuille flow ( V=Vm*(1-(r/R)^2) ).
I defined zp=pos().z+0.005 because z interval is [-0.0075 : -0.0025].
Thank you in advance!
Claudio
Claudio87 is offline   Reply With Quote
Old   June 4, 2013, 13:10
Assistant Moderator
Bernhard Gschaider
Originally Posted by Claudio87 View Post
Hi all!
instead:
        type			groovyBC;
Claudio
At first: never use point-values when claiming "it is that way". The only way you see the real values are cell values. Point values are paraview interpolating them and what you see might (doesn't have to) be an artefact of the interpolation. For checking boundary conditions it is even better to not import the internalMesh but only the patch in question (both readers support this) and USE THE CELL VALUE
The max not hitting 2 is OK: if the peak of the parabola doesn't "hit" a face-center then you will get a slightly lower value. The "+0.005"-trick can be avoided. Use max(pts().z) to get the maximum of the vertices of the patch. Get the minimum the same way (see how it is done in the pulsating pitzDaily).
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 5, 2013, 05:41
Claudio
Hi Bernhard,
thank you for your quick answer!
I tried to do what you said, and now it works!
I mean:
I was yet looking to the patch and not to the internalMesh; and using the cell value, it seems the same (look the attached pictures called "old").
I modified the "trick" in this way:
        type			groovyBC;
        variables		"Vm=2;yp=pos().y;zp=pos().z+0.005;h=-max(pts().z);a=-Vm/(h*h);b=Vm;";
and now it works (see the "new" pict), even if I didn't understand exactly why!
If you could explain it to me someway it could be usefull!
Thank you very much!
Old   June 18, 2013, 09:34
Daniel Pielmeier
billie is on a distinguished road
        type            groovyBC;
I think what Bernhard meant by avoiding the "+0.005"-trick is that you can acquire the the min and max position of the patch and and use them to calculate the offsets from the origin. This way you don't have to worry where your patch is positioned but only in which plane (e. g. XZ) it is located.
I tried the same but wanted to achieve a fixed volumetric flow rate. I post this here, maybe someone can make use of it. If somebody has a better solution I would be glad to hear it.
First I obtain the list of face centres for the x and z coordinate (xp, zp) corrected by the offset between the centre of the pipe inlet and the origin. This way the maximum value is at the centre of the inlet patch. For the parabolic profile (para) I used the same function Claudio used. What I call normalizedFlux is the resulting flux for a parabola with a maximum velocity of 1m/s. The ratio between my desired flux and the normalizedFlux is then used in the valueExpression along with the parabolic profile. This results in the same flux as for the flowRateInletVelocity boundary condition with a uniform value.
    inflow
        //type            flowRateInletVelocity;
        //volumetricFlowRate 0.000583333;
        //value           uniform (0 0 0);
        type            groovyBC;
        variables (
            "flux=-0.000583333;"
            "minX=min(pts().x);"
            "maxX=max(pts().x);"
            "minZ=min(pts().z);"
            "maxZ=max(pts().z);"
            "r=mag((maxZ-minZ)/2.0);"
            "xOffset=minX+r;"
            "zOffset=minZ+r;"
            "xp=pos().x-xOffset;"
            "zp=pos().z-zOffset;"
            "para=1-((xp*xp)+(zp*zp))/pow(r,2);"
            "normalizedFlux=sum(para*area());"
            "ratio=flux/normalizedFlux;"
        valueExpression "vector(0,ratio*para,0)";
        value           uniform (0 1 0);
arvindpj and Romulus like this.
billie is offline   Reply With Quote
Old   May 29, 2014, 05:12
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am trying to do the same trick, using the coded BC instead of using swak4Foam, since I can't compile it on the machine where I have to launch my simulations.
Do you know how I can fix this?
I tried something like
    movingWall
		type codedFixedValue;
		value uniform (0 -2 0);
		redirectType parabolicInlet;
		code
			scalar U_0 = 2;
			scalar a = 0;
			scalar yp = 0;
			scalar zp = 0;
			fixedValueFvPatchVectorField myPatch(*this);
			forAll(this->patch().Cf(),i)
				a = U_0 / (0.5*0.5);
				yp = pos().y;
				zp = pos().z+0.005;
				myPatch=vector(0,-2*a,0);
			operator==(myPatch);
but it does not work properly, since it "does not like" the lines where I evaluate yp and zp.
Could you help, please?
Thanks,
Samuele
samiam1000 is offline   Reply With Quote
Old   May 29, 2014, 09:30
Assistant Moderator
Bernhard Gschaider
Originally Posted by samiam1000 View Post
Dear All,
    movingWall
		code
			scalar U_0 = 2;
			scalar a = 0;
			scalar yp = 0;
			scalar zp = 0;
				yp = pos().y;
				zp = pos().z+0.005;
Thanks,
Samuele
You know that you've succeeded when people start using swak-idioms in their C++-code
I think what you want is (I'm doing this from memory so it might be slightly off. Especially the .y()-part)
yp=this->patch().Cf()[i].y();
zp=this->patch().Cf()[i].z()+0.005;
Although I honestly don't understand why you'd want to do that. These values are not used afterwards.
Also replace the next line with
myPatch[i]=vector(0,-2*a,0);
because otherwise the whole myPatch would have the value from the last iteration (not that it matters here because it is the same value anyway for the present code)
Concerning "can't compile it on the machine where I have to launch my simulations": if it is about outdated bison&flex on that machine: the development-version (and next release) of swak have a script to download and build a more up-to-date version of bison and use that. Nothing more than a C++-compiler is needed. And you must have access to that on that machine (otherwise coded wouldn't work)
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 06:25
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain sdfij6354 OpenFOAM Running, Solving & CFD 3 July 26, 2017 16:16
pressure contour and velocity profile problem alee1293 Main CFD Forum 0 July 18, 2014 10:31
Multi step transient UDF velocity profile problem William177 FLUENT 1 February 3, 2008 06:47
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
