[swak4Foam] why continuity doesn't solve when p be fixedGradient in groovyBC?
Old   July 4, 2013, 16:09
Default why continuity doesn't solve when p be fixedGradient in groovyBC?
immortality's Avatar
Ehsan
immortality is on a distinguished road
I have set p in outlet be:
(internalField(p)-50000)
in a period of time in start of run.
but it seems continuity doesn't solve for that as can be seen in the attached image.why?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   July 6, 2013, 20:27
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
How come that you are not satisfied with 1e-18? I would say it was perfect from a continuity perspective.
Kind regards,
Niels
ngj is offline   Reply With Quote
Old   July 7, 2013, 07:40
Ehsan
hi Niels
in first time steps its a straight line without fluctuations.I think maybe it be an issue.
Old   July 8, 2013, 15:07
Assistant Moderator
Bernhard Gschaider
Originally Posted by immortality View Post
hi Niels
No. For continuity error of 1e-18 to be a problem the system has to be really tiny. If your system is really that tiny the question is whether the continuum assumption is still valid (if it isn't then of course the question is whether the standard OF-solvers are still the right thing for you)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 8, 2013, 15:25
Ehsan
dear Bernhard.I don't want that residuals to be less than 1e-18 ar such thing.
I focus on time 0 till around time 2e-5 that the continuity is a stright horizontal line.I ask why in this period (in figure) there are not any fluctuations in residuals.is it normal?how and why?!
Old   July 8, 2013, 16:20
Ehsan
I found out why its so!
in first time steps the residuals are of order 0f 1e-22 or 1e-21 and are very low in compare with later times(2e-5 to next)(I don't know the exact reason) then they appear as a line without fliuctuations,in next time steps continuity errors are a bit higher but are low enough as dear Benhard and dear Niels told to say continuity is satisfied.
How to use PIMPLE properly? floquation OpenFOAM Running, Solving & CFD 25 December 2, 2021 09:40
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
