[swak4Foam] Validation of swak4Foam for lagrangian particle tracking
Like Tree1Likes
  • 1 Post By gschaider
Old   September 20, 2013, 07:38
Exclamation Validation of swak4Foam for lagrangian particle tracking
Sebastian W.
nero235 is on a distinguished road
Send a message via ICQ to nero235
I am simulating several different multiphase flow regimes, consisting of 3 phases with multiphaseInterFoam. Additionally I need to inject a particle (not massless) to the flow and track it as it moves. I found that this can be done using swak4Foam libraries to add LPT (lagrangian particle tracking) methods to any solver. I set up several test cases, combining interFoam and swak4Foam with success.
However I need to validate this method in order to know if the calculated particle trajectory is physically correct. For this I have set up a 3D test case of a rectangular domain filled with air. A particle will be injected at the bottom of the domain with an initial velocity (in x and z-direction). Gravity is acting in negative z-direction. I am using interFoam for the calculation of the continuous phase and swak4Foam for the uncoupled particle tracking.
The result of this simulation should be a parabolic particle trajectory. However it seems that there is no gravity acting on the particle. Therefor the particle trajectory is linear.
I have uploaded my validation case in the hope somebody can tell me why the gravity is not considered here.
Thanks in advance!
Sebastian
nero235 is offline   Reply With Quote
Old   September 20, 2013, 08:42
Assistant Moderator
Bernhard Gschaider
Thanks in advance!
Sebastian
The lagrangian particles in swak add no submodels to the particles (basically swak only creates the cloud and at each timestep says "move the way you always move"). So in fact you're verifying the OF lagrangian particles. Haven't got the time to look at the case today. Have you switched on gravity (I think it is in the "forces"-subdict of the cloudDict)?
Anyway: when moving through the fluid the viscosity should also slow down the particle so it should at least come to a stand-still (especially with the high viscosities you usually have in interFoam)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 20, 2013, 08:57
Sebastian W.
Yes, I am using gravity and sphereDrag as body forces. However it doesn't show an effect on the particle trajectory when I change the value of "g" in the controlDict under the particle function.
Here is my particleCloudProperties file:
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermoCloud1Properties;
solution {
    active          on;
    coupled         false;
    transient         true;
    cellValueSourceCorrection on;
    interpolationSchemes
        rho             cell;
        mu                cell;
        U               cellPoint;
//        DUcDt            cellPoint;
    sourceTerms
        schemes
            rho             explicit 1;
            U               explicit 1;
    integrationSchemes
        U               Euler;
constantProperties
    parcelTypeId     1;
    rhoMin           1;
    minParticleMass  5.23e-10;
    rho0             2000;
    epsilon0         10;
    Pr               0.7;
    pMin               1;
    constantVolume   true;
    youngsModulus    1e9;
    poissonsRatio    0.35;
subModels
    particleForces
        gravity;
        sphereDrag;
//        pressureGradient
//            U U;
        //virtualMass off;
    injectionModels
        model1
            type            manualInjection;
            massTotal       1.05e-6;
            parcelBasisType mass;
            nParticle       1;
            SOI             0;                 //Start Of Injection
            positionsFile   "tracerParticlePositions";
            U0              (0.1 0 0.1);     //the calculated 'linear momentum' is p=m*v
            sizeDistribution
                type        fixedValue;
                fixedValueDistribution
                    value   1e-3;
    dispersionModel none;
    patchInteractionModel standardWallInteraction;
    heatTransferModel none;
    radiation       off;
    standardWallInteractionCoeffs
        type            rebound;
        mu                0;
    surfaceFilmModel none;
cloudFunctions
    particleTracks
        trackInterval   1;
        maxSamples      1000000;
        resetOnWrite    yes;
and the controlDict
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         20;
deltaT          0.005;
writeControl    adjustableRunTime;
writeInterval   20;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  no;
maxCo             1;
maxAlphaCo        1;
maxDeltaT       0.005;
libs
    "libsimpleFunctionObjects.so"
    "libsimpleLagrangianFunctionObjects.so"
    "libswakLagrangianCloudSourcesFunctionPlugin.so"
    "libswakFunctionObjects.so"
functions
    mu
        type expressionField;
        expression "1.7894e-5";
        fieldName mu;
        autowrite true;
    Particle
        type evolveKinematicCloud;
        cloudName ParticleCloud;
        g "down" [0 1 -2 0 0 0 0] (0 0 -9.81 );
        rhoName rho;
        muName mu;
        UName U;
Greetings, Sebastian.
Old   September 23, 2013, 18:59
Assistant Moderator
Bernhard Gschaider
OK. I think I found the problem. The clouds want a reference to the gravity vector. The swak-functionObjects were passing a value ... the cloud took a reference to the temporary value which turned into garbage .... it's painfully obvious once you found it.
Anyway. The fix is just one additional char (it will be in the next release):
diff --git a/Libraries/simpleLagrangianFunctionObjects/EvolveCloudFunctionObject.H b/Lib
--- a/Libraries/simpleLagrangianFunctionObjects/EvolveCloudFunctionObject.H
+++ b/Libraries/simpleLagrangianFunctionObjects/EvolveCloudFunctionObject.H
@@ -105,7 +105,7 @@
     autoPtr<CloudType> &cloud() { return cloud_; }
-    const dimensionedVector g() const { return g_; }
+    const dimensionedVector &g() const { return g_; }
     const objectRegistry &obr() const { return obr_; }
Old   May 28, 2015, 21:05
luchen
luchen2408 is on a distinguished road
Dear gschaider,
I also have this problem in my simulation, but I don't konw how to solve it in the simulation. can you explain more about that or give a solution with more details?
luchen2408 is offline   Reply With Quote
Old   May 29, 2015, 03:09
Sebastian W.
Originally Posted by luchen2408 View Post
Dear gschaider,
You have to modify the file:
/home/$USER/OpenFOAM/.../swak4Foam/Libraries/simpleLagrangianFunctionObjects/EvolveCloudFunctionObject.H
Change the line 109 to:
Where the "&" is missing. Recompile swak4Foam and it then it should work.
Old   May 31, 2015, 16:21
Assistant Moderator
Bernhard Gschaider
Which version of swak are you talking about? I just checked in the repository and this is fixed since September 2013 so it should be in the last 2 releases (at least)
Old   May 31, 2015, 21:36
luchen
Dear Sebastian and Bernhard,
Thanks for your reply, I took the swak version 0.3.1 in which the problem is solved in the code. The "&" is in the code. But the gravity seems doesn't on the particles.
Old   June 2, 2015, 01:59
luchen
I have cross checked my code in the ContolDict file.
I found I took the EvolveKinematicCloud, not EvolveCloud and I thinkd I need to modified the EvolveKinematicCloudFunctionObject.H, but there is not codes to adjust as you mentioned, how can I adjust code in the EvolveKinematicCloudFunctionObject.H? Thanks
Old   June 2, 2015, 02:12
luchen
You mean I have to remove the "&" and then recompile the swak4foam. Thanks your feedback.
Old   January 15, 2017, 09:05
zhaoshiyu
zhaoshiyu is on a distinguished road
Hi Have you solved the problem?
I also want to add LPT to interFoam using the swak4Foam, but I donnot know how to compile the swak4Foam with interFoam, and is that right now?
zhaoshiyu is offline   Reply With Quote
Old   January 24, 2017, 16:11
Assistant Moderator
Bernhard Gschaider
You don't have to compile swak4foam "with" interFoam. You compile it on its own and add function objects to it with the libs and functions entries in the controlDict. Examples can be found in the swak-sources in Examples/Lagrangian/functionObjects (admitedly not with interFoam. for that look at Examples/FromPresentations/OSCFD_cleaningTank2D although that case probably won't run on current OF-versions. But it will give you an idea how to calculate a muField so that particles float on the surface)
pbachant likes this.
Old   March 26, 2017, 10:48
zhaoshiyu
Thanks for the reply.
I am very curious whether the LPT model can simulate the particles part in debris flow, can friction between particles be realized, or the particle can only work as tracer moving along the flow?
Old   March 28, 2017, 05:45
Assistant Moderator
Bernhard Gschaider
Depending on the OF-Version there are models for particle-interactions but they are limited. Check out $FOAM_TUTORIALS/lagrangian and look for collisionModel. For better collisions of large particles look at http://www.cfdem.com/node/414
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 16:30
Request for Lagrangian Particle Tracking Validation or Verification Paper Mojtaba.a OpenFOAM Verification & Validation 6 May 23, 2016 01:47
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow DarrenC CFX 5 April 7, 2016 14:50
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 18:00
injection problem Mark New FLUENT 0 August 4, 2013 01:30
