[swak4Foam] swak4foam-0.3.0 make parallel run crash on foam-extend-3.0 |
March 31, 2014, 12:09 |
Hello, dear foamers!
Suddenly I've encountered following problem. After installation of latest foam-extend-3.0 and swak4foam-0.3.0 my parallel runs crash. The same case runs ok on serial run. In addition, same case runs ok in parallel on OF-1.6-ext and swak4foam 0.2.0. Terminal output of crash (simpleFoam): Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0-8c304619f538 Exec : simpleFoam -parallel Date : Mar 31 2014 Time : 19:52:42 Host : chaos2 PID : 16636 CtrlDict : /home/aleksey/foam/foam-extend-3.0/etc/controlDict Case : /home/aleksey/foam/aleksey-3.0/run/trial nProcs : 4 Slaves : 3 ( chaos2.16637 chaos2.16638 chaos2.16639 ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : blocking SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model laminar Starting time loop Time = 0.1 DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 1.95781538458e-10, No Iterations 11 DICPCG: Solving for p, Initial residual = 1, Final residual = 9.9567414437e-10, No Iterations 311 DICPCG: Solving for p, Initial residual = 0.351569807727, Final residual = 9.39034466264e-10, No Iterations 268 DICPCG: Solving for p, Initial residual = 0.0602889779533, Final residual = 9.35013783622e-10, No Iterations 257 DICPCG: Solving for p, Initial residual = 0.0177328464787, Final residual = 9.218992822e-10, No Iterations 252 DICPCG: Solving for p, Initial residual = 0.0056772888986, Final residual = 9.11894751162e-10, No Iterations 246 time step continuity errors : sum local = 4.36977402214e-07, global = 3.01209409715e-10, cumulative = 3.01209409715e-10 [chaos2:16636] *** An error occurred in MPI_Recv [chaos2:16636] *** on communicator MPI_COMM_WORLD [chaos2:16636] *** MPI_ERR_TRUNCATE: message truncated [chaos2:16636] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort -------------------------------------------------------------------------- mpirun has exited due to process rank 1 with PID 16637 on node chaos2 exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [chaos2:16635] 3 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal [chaos2:16635] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Dear colleagues, I'd like to ask you, whether your parallel runs crash with new foam-extend and swak4foam. Best regards, Aleksey. |
March 31, 2014, 19:49 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- what kind of case is this (standard tutorial etc). Are there any functionObjects etc added - does this case use swak? If yes: try to remove it (no libs, no functions) and see if the problem persists - have you tried to run a tutorial case (for instance pitzDaily) in parallel on that installation?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
April 2, 2014, 12:04 |
Dear Bernhard,
thank you very much for your reply! Here's the case (simple 3D tube + Poiselle's inlet conditions): http://files.mail.ru/E0756960CFBB4DFC82322AC2935C2325 It runs ok in following cases: - using groovyBC for U + serial run - using funkySetBoundaryField + fixedValue conditions for U + serial run - using funkySetBoundaryField + fixedValue conditions for U + parallel run It crashes in following cases: - using groovyBC for U + parallel run As you can easily see, there's no functionObjects in presented run case. These data suggest that namely using of groovyBC make parallel run crash. If you need any additional data, please, let me know. Best regards, Aleksey. |
April 5, 2014, 09:27 |
Dear colleagues,
please, could you check if presented case runs in parallel on your machines (using groovyBC). I do need to know whether this is a bug or I simply installed OF and SWAK wrong. Best regards, Aleksey. |
April 11, 2014, 06:57 |
#5 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
One remark: could you please use a file sharing service that provides an english translation. Some people feel extremely uncomfortable clicking on stuff that they can't read. Especially with the bad reputation these russian file-shares have concerning the distribution of viruses. Doesn't have to be a "endorsed by the NSA"-service. Remove the points/faces/etc-files from polyMesh and the case should be small enough to add as an attachment here on the board. I'll have a look. But as mentioned in the Manits-report: this seems to happen one level below swak
April 17, 2014, 14:53 |
Dear Bernhard,
I'm terribly sorry for inconvenience. I attach the example run case to this post. Indeed, changing of etc/controlDict helped! Here's a link to the workaround: http://sourceforge.net/apps/mantisbt...iew.php?id=123 Thank you very much for advise! Best regards, Aleksey. |
March 12, 2015, 05:12 |
#7 | |
zhaomajie
Rep Power: 12 |
I have the same problem, I don't understand that "changing of etc/controlDict helped" mean and I can't find any helpful information with the link "http://sourceforge.net/apps/mantisbt...iew.php?id=123", |
April 3, 2015, 09:35 |
#8 | |
It means you need to change the fragment of $WM_PROJECT_DIR/etc/controlDict from: Code:
// commsType nonBlocking; //scheduled; //blocking; commsType blocking; //scheduled; Code:
commsType nonBlocking; //scheduled; //blocking; // commsType blocking; //scheduled; |
April 3, 2015, 09:49 |
#9 | |
zhaomajie
Rep Power: 12 |
March 18, 2019, 15:57 |
#10 |
Rep Power: 10 |
I'm facing a similar problem. With groovyBC, my parallel computation doesn't work. And I have nonBlocking in my etc/controlDict as well. Code:
//- Modification checking: // - timeStamp : use modification time on file // - inotify : use inotify framework // - timeStampMaster : do time stamp (and file reading) only on master. // - inotifyMaster : do inotify (and file reading) only on master. fileModificationChecking timeStampMaster; commsType nonBlocking; //scheduled; //blocking; floatTransfer 0; nProcsSimpleSum 0; // Optional max size (bytes) for unstructured data exchanges. In some // phases of OpenFOAM it can send over very large data chunks // (e.g. in parallel load balancing) and some Pstream implementations have // problems with this. Setting this variable > 0 indicates that the // data exchange needs to be done in multiple passes, each of maxCommsSize. // This is not switched on by default since it requires an additional // global reduction, even if multi-pass is not needed) maxCommsSize 0; |
March 21, 2019, 18:58 |
#11 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
This is a rather old thread. With "doesn't work" you mean the same behaviour as the original poster? Could you be more specific about the swak-version you use? Is this your own case or have you tried one of the examples?
March 21, 2019, 19:46 |
#12 |
Rep Power: 10 |
Hi Bernhard!
Thanks for replying! I'm using swak 0.4.2. I'm running a case where I have air as the bulk fluid and I'm injecting water droplets. So essentially I have two fluids in my domain once the water evaporates and becomes "part" of the bulk fluid. I have a Neumann BC at one of the patches. Here my groovyBC Code:
BOTTOM { type groovyBC; variables "Dmuc=4.3e-6;Dmem=1.4e-6;tmem=1e-5;kow=200;liq{BOTTOM}=H2O;"; valueExpression "liq"; gradientExpression "-(Dmem*kow/(Dmuc*tmem))*liq*1e-3"; fractionExpression "0"; value uniform 0; evaluateDuringConstruction 1; timelines ( ); lookuptables ( ); lookuptables2D ( ); } Code:
--> FOAM FATAL ERROR: Parser Error for driver PatchValueExpressionDriver at "1.3-5" :"field air not existing or of wrong type" "1-air" ^^^ ----| Context of the error: - Driver constructed from scratch Evaluating expression "1-air" From function parsingValue in file lnInclude/CommonValueExpressionDriverI.H at line 1246. FOAM exiting Code:
--> FOAM FATAL ERROR: hanging pointer at index 1 (size 5), cannot dereference From function const T& Foam::UPtrList<T>::operator[](Foam::label) const [with T = Foam::fvPatchField<double>; Foam::label = int] in file /usr/local/apps/OpenFOAM/gcc482-v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude/UPtrListI.H at line 107. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Patch const& Foam::fvPatch::patchField<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Patch const& Foam::fvPatch::lookupPatchField<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, double>(Foam::word const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const*, double const*) const at ??:? #4 Foam::tmp<Foam::Field<double> > Foam::PatchValueExpressionDriver::getField<double>(Foam::word const&) at ??:? #5 parserPatch::PatchValueExpressionParser::parse() at ??:? #6 Foam::PatchValueExpressionDriver::parseInternal(int) at ??:? #7 Foam::CommonValueExpressionDriver::parse(Foam::exprString const&, Foam::word const&) at ??:? #8 Foam::CommonValueExpressionDriver::evaluateVariableRemote(Foam::exprString const&, Foam::word const&, Foam::exprString const&) at ??:? #9 Foam::CommonValueExpressionDriver::addVariables(Foam::exprString const&, bool) at ??:? #10 Foam::CommonValueExpressionDriver::addVariables(Foam::List<Foam::exprString> const&, bool) at ??:? #11 Foam::CommonValueExpressionDriver::clearVariables() at ??:? #12 Foam::groovyBCFvPatchField<double>::updateCoeffs() at ??:? #13 Foam::mixedFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) at ??:? #14 Foam::groovyBCFvPatchField<double>::groovyBCFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #15 Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::groovyBCFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #16 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #17 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #18 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:? #19 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:? #20 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&, bool) at ??:? #21 ? at ??:? #22 ? at ??:? #23 __libc_start_main in "/lib64/libc.so.6" #24 ? at ??:? |
March 22, 2019, 07:57 |
#13 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
evalDuringConstruction was introduced for exactly that reason. As fields are constructed one after another it can't be guaranteed that a peer field is already there when the boundary condition gets evaluated the first time (during construction). Usually it is sufficient if boundary conditions are evaluated whenever the field is solved for. It is possible that the "other" field has a wrong value during the first time-step because it has not been evaluated yet. For such cases set a reasonable value for the "value"-entry of the other field
parallel execution, swak4foam error |
OpenFOAM can't be run in parallel in cluster | sibo | OpenFOAM Running, Solving & CFD | 4 | February 21, 2017 16:29 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
MPI PROBLEMS | gtg627e | OpenFOAM Running, Solving & CFD | 20 | October 5, 2007 04:02 |
