[swak4Foam] errors when trying to use swakCoded-function
Old   April 11, 2014, 23:14
Default errors when trying to use swakCoded-function
India
mayank.dce2k7 is on a distinguished road
I have OpenFOAM-2.2.2 on my laptop with Ubuntu 12.04 LTS. I downloaded swak4Foam from the following link:
https://github.com/wyldckat/swak4foam/tree/OF22X (it's already patched for building with OpenFOAM 2.2.x.)
and installed on my laptop. Everything is working fine, right from installation to loading libraries while running simulations.
I have OpenFOAM-2.2.2 on cluster running RHEL(Red Hat Enterprise Linux). I used the same swak4Foam files downloaded from above source. I compiled it with bison-2.7 and flex-2.5.35 by putting in my swak4Foam directory as mentioned on this page:http://openfoamwiki.net/index.php/In...g_dependencies
The compilation went smooth. Below is the log when I type in ./Allwmake in swak4Foam folder:
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Swak version is 0.2.4
Bison is version 2.7
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 2 Minor 2 Patch 2 (-1 == x)
No change to swak4FoamParsers/foamVersion4swak.H
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libgroovyBC.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libsimpleFunctionObjects.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libsimpleLagrangianFunctionObjects.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libsimpleSearchableSurfaces.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakTopoSources.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakSourceFields.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libgroovyStandardBCs.so' is up to date.
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakMeshQualityFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakLocalCalculationsFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakRandomFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakFvcSchemesFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakThermoTurbFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakTransportTurbFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakSurfacesAndSetsFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakVelocityFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakChemistryModelFunctionPlugin.so' is up to date.
'/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/libswakRadiationModelFunctionPlugin.so' is up to date.
make[1]: Entering directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/calcNonUniformOffsetsForMapped'
make[1]: `/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/bin/calcNonUniformOffsetsForMapped' is up to date.
make[1]: Leaving directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/calcNonUniformOffsetsForMapped'
make[1]: Entering directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/funkyDoCalc'
make[1]: `/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/bin/funkyDoCalc' is up to date.
make[1]: Leaving directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/funkyDoCalc'
make[1]: Entering directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/funkySetBoundaryField'
make[1]: `/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/bin/funkySetBoundaryField' is up to date.
make[1]: Leaving directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/funkySetBoundaryField'
make[1]: Entering directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/funkySetFields'
make[1]: `/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/bin/funkySetFields' is up to date.
make[1]: Leaving directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/funkySetFields'
make[1]: Entering directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/replayTransientBC'
make[1]: `/share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/bin/replayTransientBC' is up to date.
make[1]: Leaving directory `/share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Utilities/replayTransientBC'
If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /share/mvaish/OpenFOAM/mvaish-2.2.2/run/swak4foam-OF22X/Libraries (most people will be fine without setting that variable)
But when I run the case I get following error:
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : libsimpleSwakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libsimpleSwakFunctionObjects.so"
--> FOAM Warning :
dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libswakFunctionObjects.so"
--> FOAM Warning :
dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libgroovyBC.so"
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
Unknown patchField type groovyBC for patch type patch
Valid patchField types are :
68
SRFFreestreamVelocity
SRFVelocity
activeBaffleVelocity
activePressureForceBaffleVelocity
advective
atmBoundaryLayerInletVelocity
calculated
codedFixedValue
codedMixed
cyclic
cyclicAMI
cyclicSlip
cylindricalInletVelocity
directionMixed
empty
externalCoupled
fixedGradient
fixedInternalValue
fixedJump
fixedJumpAMI
fixedMean
fixedNormalSlip
fixedValue
flowRateInletVelocity
fluxCorrectedVelocity
freestream
inletOutlet
kqRWallFunction
mapped
mappedField
mappedFixedInternalValue
mappedFixedPushedInternalValue
mappedFlowRate
mappedVelocityFlux
mixed
movingWallVelocity
nonuniformTransformCyclic
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
partialSlip
pressureDirectedInletOutletVelocity
pressureDirectedInletVelocity
pressureInletOutletParSlipVelocity
pressureInletOutletVelocity
pressureInletUniformVelocity
pressureInletVelocity
pressureNormalInletOutletVelocity
processor
processorCyclic
rotatingPressureInletOutletVelocity
rotatingWallVelocity
sliced
slip
supersonicFreestream
surfaceNormalFixedValue
swirlFlowRateInletVelocity
symmetryPlane
timeVaryingMappedFixedValue
translatingWallVelocity
turbulentInlet
uniformFixedValue
uniformJump
uniformJumpAMI
variableHeightFlowRateInletVelocity
waveTransmissive
wedge
zeroGradient
file: /share/mvaish/OpenFOAM/mvaish-2.2.2/run/zhaotransientvelfurther/0/U.boundaryField.INLET from line 27 to line 31.
From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
in file /usr/local/apps/OpenFOAM/gcc454-2.2.2/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 136.
FOAM exiting
What should I do?
mayank.dce2k7 is offline   Reply With Quote
Old   April 12, 2014, 14:32
India
Also, does it matters, if I am using bash shell or tcshrc(c shell) for installing swak4Foam? Shell available on cluster is tcshrc while that on my laptop is bash shell.
Regards,
Mayank.
Old   April 14, 2014, 19:09
Assistant Moderator
Bernhard Gschaider
Originally Posted by mayank.dce2k7 View Post
Create time
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Reading field p
Reading field U
68
SRFVelocity
advective
calculated
codedFixedValue
codedMixed
cyclic
cyclicAMI
cyclicSlip
directionMixed
empty
externalCoupled
fixedGradient
fixedInternalValue
fixedJump
fixedJumpAMI
fixedMean
fixedNormalSlip
fixedValue
freestream
inletOutlet
kqRWallFunction
mapped
mappedField
mappedFlowRate
mappedVelocityFlux
mixed
movingWallVelocity
outletInlet
partialSlip
processor
processorCyclic
sliced
slip
symmetryPlane
turbulentInlet
uniformFixedValue
uniformJump
uniformJumpAMI
waveTransmissive
wedge
zeroGradient
FOAM exiting
What should I do?
Is /share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/ in your LD_LIBRARY_PATH? (that is necessary for OF to find it. Usually the etc/bashrc of the distro should set this correctly) And is this your FOAM_USER_LIBBIN?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   April 14, 2014, 19:25
India
Hi Bernhard,
Yes, /share/mvaish/OpenFOAM/mvaish-2.2.2/platforms/linux64GccDPOpt/lib/ is my FOAM_USER_LIBBIN.
You mean to say if I set:
setenv LD_LIBRARY_PATH = $FOAM_USER_LIBBIN
in my ~/.tcshrc file(equivalent of ~/.bashrc). Then it should work?
Regards,
Mayank
Old   April 15, 2014, 10:07
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Regards,
Mayank
No if you do "echo $LD_LIBRARY_PATH" then the path should be ONE component there. If not append it with
setenv LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$FOAM_USER_LIBBIN
but resetting the path the way you suggested will break everything
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 10:08
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
