[swak4Foam] calculate gradient of U in groovyBC
Old   May 21, 2014, 04:48
Default calculate gradient of U in groovyBC
Chao Liu
lcchaos is on a distinguished road
Hello
I'm trying to calculate the force on a surface to update the moving-wall boundary condition of the surface. The gradient of U is needed for calculating viscous contribution of forces.
The code is based on the example on wiki
http://openfoamwiki.net/index.php/Co...ectionalForces
sphere
	type		groovyBC;
  	variables 	(
			"pressure_force=sum(p*normal()*area());"
			"viscous_force=sum(-snGrad(U)*area()*0.01);"	//nu=0.01
			"force=pressure_force+viscous_force;"
			"acceleration=force*1000/33.51;"	//density=1000;mass=33.51 SI
			"torque=sum((pos()-vector(0,0.4,0))^(p*normal()*area()-snGrad(U)*area()*0.01));"
			"angular_acceleration=torque*1000/0.5362;"	//moment of inertia=0.5362
	valueExpression	"(time()>1.0) ? U+(vector(acceleration.x,0,0)+angular_acceleration^(pos()-vector(0,0.4,0)))*deltaT()*0.5 : U";
	value		uniform (0 0 0);
I noticed that snGrad(U) is not the inner product of normal vector of face and the deformation tensor. So I change snGrad(U) into grad(U)+grad(U)T (T means transport matrix). However, I got an error
--> FOAM FATAL ERROR:
 Parser Error for driver PatchValueExpressionDriver at "1.1-4" :"field grad not existing or of wrong type"
"grad(U)"
Thanks for your help!
Regards,
lcchaos is offline   Reply With Quote
Old   May 21, 2014, 06:49
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi!
But what is snGrad(U) else?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   May 21, 2014, 08:16
Chao Liu
Originally Posted by RodriguezFatz View Post
Hi!
Hi, snGrad(U) is the gradient of U in the surface normal direction.
Old   May 21, 2014, 08:18
Philipp
Well ok, this does not account for the moving wall... or what is the problem?
Old   May 21, 2014, 09:30
Chao Liu
Philipp, I want to impose a moving wall boundary condition on the surface of a sphere. The motion results from the hydrodynamic force . Therefore, the gradient of U at the surface must be obtained to calculate the force. The problem is that an error appears when I use grad(U). Using snGrad(U) is incorrect physically.
Old   May 23, 2014, 06:32
Assistant Moderator
Bernhard Gschaider
You need the gradient in tangential direction? There is no built in implementation for that in OF (and therefor not in swak). Best way to get this would be to calculate grad(U) (in a seperate step. groovyBC can't do this) on the interior and then get that value from the cells next to the patch (with internalField). But this is probably rather inaccurate.
On the other hand: as you probably know the U of the sphere it is probably better to calculate grad(U) in tangential direction analytically
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   May 25, 2014, 10:34
Chao Liu
Hi Bernhard,
Thanks for your advice! I' m trying to do the calculation by modify the source code. My general idea is adding a new equation for the tensor grad(U) after the momentum equation is solved. Does this way can avoid the inaccuracy?
Regards
Chao
groovybc
[swak4Foam] Velocity gradient outlet BC penalisation using groovyBC Hiroshiman OpenFOAM Community Contributions 10 June 11, 2014 16:57
[swak4Foam] Time varying non uniform velocity gradient, groovyBC? ic3wall OpenFOAM Community Contributions 1 November 14, 2012 17:26
calculate temperature gradient from temperature field xiyuqiu Main CFD Forum 14 July 30, 2012 14:38
A function to calculate gradient in a cell Ballal Siemens 0 June 9, 2012 00:07
calculate the temperature gradient on a profile arther FLUENT 0 April 19, 2006 23:12
