[swak4Foam] Alternating scalar BC using groovyBC for a super focus mixer
Old   July 3, 2014, 11:01
Default Alternating scalar BC using groovyBC for a super focus mixer
Dominik Pöltl
Yeru is on a distinguished road
Hi @ all,
I'm working on simulating a super focus mixer.
Here's the checkmesh.log. All fine.
Since "in real life" the nozzles for fluid A and B shall alternate in the focus inlet in x-direction, I want to assign alternating scalar values for T using scalarTransportFoam with groovyBC.
Below you find the 0/T-file.
Here's the general idea:
-circ is the circumference of the focus inlet
-n is the total number of nozzles
I'm creating the vector vec for calculation
mag(vec)%(circ/n)
If this is <=0.5 I want to assign value A, otherwise value B.
Using scalarTransportFoam works without any warnings (log-file) but in ParaView, the focus inlet is globally assigned my "failsafe" value 0.1.
I'm certain there are no mess-ups due to convertToMeters or anything alike.
Any ideas how to get by this?
Much appreciated,
Dominik
0/T-file:
internalField   uniform 0;
boundaryField
    focus_inlet
    type           groovyBC;
    variables    "n=5;alpha=pi*50/180;b_channel=500e-3;l_focus=1000e-3;r=(b_channel/2+tan(alpha/2)*l_focus)/(sin(alpha/2));circ=r*alpha;vec=vector(pos().x,0,pos().z-l_focus);";
//    condition ? value_if_true : value_if_false
    valueExpression "mag(vec)%(circ/n)<=0.5    ?    1    :    0.5";
    value         uniform 0.1;
    channel_outlet
        type            zeroGradient;
    walls
        type            zeroGradient;
Yeru is offline   Reply With Quote
alternating bc, groovybc, super focus mixer
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Division by zero exception - loop over scalarField Pat84 OpenFOAM Programming & Development 6 February 18, 2017 05:57
Issue symmetryPlane 2.5d extruded airfoil simulation 281419 OpenFOAM Running, Solving & CFD 5 November 28, 2015 13:09
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 06:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
