[swak4Foam] Error while moving swak4foam to the global site.
Like Tree1Likes
  • 1 Post By adewindt
Old   January 16, 2015, 14:08
Default Error while moving swak4foam to the global site.
Aaron
adewindt is on a distinguished road
[SOLVED]
Hi
I have successfully installed swak4foam, but now I need to move it to the global site, so it's available to all users without rebuilding. This is necessary, since I'll be running it from a liveCD/USB and the user is created while booting.
According to the readme I have to run the "copySwakFilesToSite.sh" found the "maintainanceScripts" folder. However when I run this file it says that it cannot find "theFiles.sh". There is no file named "theFiles.sh" in the "maintainanceScripts". Is this causing any problems or is it just some legacy code which was left behind?
Full output
./copySwakFilesToSite.sh: line 3: ./theFiles.sh: No such file or directory
mkdir: created directory ‘/opt/site’
mkdir: created directory ‘/opt/site/2.3.1’
mkdir: created directory ‘/opt/site/2.3.1/platforms’
mkdir: created directory ‘/opt/site/2.3.1/platforms/linux64GccDPOpt’
mkdir: created directory ‘/opt/site/2.3.1/platforms/linux64GccDPOpt/lib’
mkdir: created directory ‘/opt/site/2.3.1/platforms/linux64GccDPOpt/bin’
adewindt is offline   Reply With Quote
Old   January 16, 2015, 14:28
Default Solved it.
Aaron
I found my mistake. I had changed my directory to the folder where the file was located and it didn't find "theFiles.sh". I just changed the directory back and ran it again without any problems.
wyldckat likes this.
installation, swak4foam, swak4foam error
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
