[swak4Foam] Fixed Wall Heat Flux with groovyBC
Old   September 7, 2016, 09:48
Default Fixed Wall Heat Flux with groovyBC
flowpow is on a distinguished road
Hello FOAMers,
I'm currently trying to run a multiRegion case. I need a temperature dependent heat flux boundary condition with radiation and convection term on the outside of the solid (not coupled with the fluid). So I tried to use groovyBC. But there you can only specify the temperature gradient.
q = gradT * thermal diffusity
geh_out
        type                         groovyBC;
        gradientExpression           "gradT";
        fractionExpression           "0";
        variables                    "Tinf=313.15;k=160;heatFlux=-(radiation+convection);gradT=heatFlux/k;";
But I don't know which thermal diffusity to use. I tried the thermal diffusity from the solid, but the result was incorrect. Which thermal diffusity can I use?
In comparison to CFX, is there the possibility to determine a heat flux?
With best regards
flowpow is offline   Reply With Quote
chtmultiregionsimpefoam, groovybc, swak4foam
buoyantSimpleFoam: fixed wall heat flux TaPantaRei OpenFOAM Running, Solving & CFD 18 December 26, 2018 10:15
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
