[cfMesh] using cfMesh with interFoam ends in a Floating point exception |
September 15, 2016, 04:51 |
htwsaar
Rep Power: 11 |
I have a problem which seems to be caused by the combination of cfMesh and interFoam. I used cfMesh several times with simpleFoam and got very good (and easy to achieve) results without any problems; but when using with multiphase solver interFoam, I sometimes run into a numerical problem (at least it looks to me like a numerical problem): At a certain time in simulation, the timesteps (deltaT) are getting smaller and smaller (down to 10E-90 or similar), until finally a Floating point exception happens. I have no idea how to look further in these cases, therefore I started from an existing (and running) tutorial and change it step by step to see when the problem arises. Since I want to use the boubdary condition "variableHeightFlowRateInletVelocity", I started with the tutorial "weirOverflow" (located in multiphase/interFoam/ras/weirOverflow/), which has a blockMesh-generated 2D-geometry. I stretched the z-axis by factor 10, and still everything runs fine. Then I rebuild the same geometry with salome and created a new mesh with cfMesh, and then I run into the well-known trouble: When the water reaches the end of the weir and start to flow down, the time steps decrease down to 4.37805e-86 and causes then a Floating point exception. To be near to the tutorial, I didn't use boundary layers; in fact, I only defined a maxCellSize (later I also tried with boundary layers but run into similar problems). The resulting mesh looks good to me (at least good enough for such a simple geometry). I'm pretty sure that the problem is caused by the mesh since everything runs fine if I exchange the constant/polyMesh - directory with the blockMesh-case. I have no idea where to search for the reason, since the mesh looks good to me. Are there any special mesh requirements for multiphase simulation with interFoam? EDIT: I've added clip images of the blockMesh / cfMesh Last edited by STEFGER; September 15, 2016 at 07:17. |
cfmesh, floating point exception, interfoam |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
A floating point exception - SEM Model | yansheng | STAR-CCM+ | 1 | April 4, 2016 04:57 |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 13:56 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 05:58 |
Finished simulation doesn't start: floating point exception [Divide by zero] | MaxCFD | STAR-CCM+ | 3 | June 26, 2011 10:31 |
