[swak4Foam] Error with mapFields using a groovyBC
Old   October 6, 2016, 11:28
Default Error with mapFields using a groovyBC
Agustín Villa
agustinvo is on a distinguished road
Hi
I am mapping a domain, where originally I have a BC where I use groovyBC.
Once it is mapped, some errors can appear, that I can solve just replacing my groovyBC with a fixedValue.
The problem is, that after I map, and I reinsert my groovyBC, the solver gives me an error like this:
--> FOAM FATAL IO ERROR:
compound has already been transfered from token
    on line 2880035 the empty compound of type List<scalar>
file: /case3D_URANS/0/T.boundaryField.cylWall.value at line 2880035.
    From function token::transferCompoundToken(const Istream& is)
    in file lnInclude/token.C at line 103.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::IOerror::abort() at ??:?
#2  Foam::token::transferCompoundToken(Foam::Istream const&) at ??:?
#3  Foam::Istream& Foam::operator>><double>(Foam::Istream&, Foam::List<double>&) at ??:?
#4  Foam::Field<double>::Field(Foam::word const&, Foam::dictionary const&, int) at ??:?
#5  Foam::groovyBCFvPatchField<double>::groovyBCFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#6  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::groovyBCFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#7  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#8  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#9  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:?
#10  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:?
#11  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:?
#12
 at ??:?
#13  __libc_start_main at ??:?
#14
 at ??:?
Aborted
I have compared with the case before the mapping and everithing seems to be ok. Do you have an idea of this error? Did someone have this problem before?
Thank you!
PS: I attach the original file and the final one
agustinvo is offline   Reply With Quote
Old   October 6, 2016, 20:33
Assistant Moderator
Bernhard Gschaider
Originally Posted by agustinvo View Post
Hi
FOAM aborting
#12
 at ??:?
#14
 at ??:?
Aborted
Thank you!
To be honest: I'm not 100% if groovyBC works with mapFields. I could but I never really tested it.
Is this the first time you tried mapFields and it doesn't work or did you do this before and this is the first time that it doesn't work?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 7, 2016, 09:46
Agustín Villa
Hi, thanks for your answer.
I have used before mapFields before without problem, but previously I had no groovyBC's in my cases.
At the end, it seems I did a mistake over there, so I was messing up the file. Today I have tried to do the same, but in two steps (so, from 1 cell depth to 8, and then to 32), I used fixedValue at the very begining, and I edited again my BC's. Now it seems to work.
Old   October 7, 2016, 10:11
Assistant Moderator
Bernhard Gschaider
OK. But of course Mapping should work. I'll look into it if I remember it.
If there is a report in the swak bug-tracker it would help my memory
[swak4Foam] How to mapFields with groovyBC? xuegy OpenFOAM Community Contributions 0 June 1, 2017 16:57
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
Strange random behaviour of mapFields blaise OpenFOAM Pre-Processing 0 November 3, 2014 09:37
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
