[waves2Foam] new to using irregular waves
Old   March 13, 2017, 12:56
Default new to using irregular waves
Chia
chia87 is on a distinguished road
Dear Foamers,
I'm quite new to using irregular waves, there seemed to be some problems(elevation-related problems) with my focusing waves
wondered whats the problem
blockMesh as follows
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 -1 0)
(11 -1 0)
(16 -1 0 )
(0 -0.12 0)
(11 -0.12 0)
(16 -0.12 0)
(0 0.16 0)
(11 0.16 0)
(16 0.16 0)
(0 0.42 0)
(11 0.42 0)
(16 0.42 0)
(0 -1 2)
(11 -1 2)
(16 -1 2)
(0 -0.12 2)
(11 -0.12 2)
(16 -0.12 2)
(0 0.16 2)
(11 0.16 2)
(16 0.16 2)
(0 0.42 2)
(11 0.42 2)
(16 0.42 2)
blocks
hex (0 1 4 3 12 13 16 15) (660 32 1) simpleGrading (1 0.0094518 1)
hex (1 2 5 4 13 14 17 16) (50 32 1) simpleGrading (1 0.0094518 1)
hex (3 4 7 6 15 16 19 18) (660 420 1) simpleGrading (1 1 1)
hex (4 5 8 7 16 17 20 19) (50 420 1) simpleGrading (1 1 1)
hex (6 7 10 9 18 19 22 21) (660 25 1) simpleGrading (1 56.7 1)
hex (7 8 11 10 19 20 23 22) (50 25 1) simpleGrading (1 56.7 1)
did used this same meshing for my combinedWaves simulation (10 waves, with wave heights ranging from 1.2cm to 3.7cm) and was fine
My control dict as follow
application interFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 9;
deltaT 0.0004;
writeControl adjustableRunTime;
writeInterval 0.25;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.2;
maxAlphaCo 0.3;
maxDeltaT 1;
My JONSWAP wave properties as below
seaLevel 0.00;
// A list of the relaxation zones in the simulation. The parameters are given
// in <name>Coeffs below.
relaxationNames (inlet outlet);
initializationName outlet;
inletCoeffs
waveType irregular;
spectrum JONSWAP;
N 55;
Tsoft 0;
Tp 1.25;
gamma 3.3;
depth 1;
direction (1 0 0 );
phaseMethod focusingPhase;
focusTime 14;
focusPoint (8 0 0);
Hs 0.033;
frequencyAxis
writeSpectrum true; // false = default value
discretisation equidistantFrequencyAxis; // cosineStretchedFrequencyAxis;
lowerFrequencyCutoff 0.1; // Not required. Default: 1/3fp
upperFrequencyCutoff 2; // Not required. Default: 3fp
relaxationZone
relaxationScheme Spatial;
relaxationShape Rectangular;
beachType Empty;
relaxType INLET;
startX (0 0.0 -1);
endX (4 0.0 1);
orientation (1.0 0.0 0.0);
outletCoeffs
waveType potentialCurrent;
U (0 0 0);
Tsoft 0;
relaxationZone
beachType Empty;
relaxType OUTLET;
startX (11 0.0 -1);
endX (16 0.0 1);
screenshot of my surface elevation at point of focusing, seems like no waves are produced, well, i did see some microwaves producing in paraFoam,
any inputs would be greatly appreicated thanks all
- chia
chia87 is offline   Reply With Quote
Old   March 13, 2017, 13:51
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Chia,
I suppose it is because your focus time is larger than your end time. You could also verify that the expected amplitudes and phases are written to waveProperties.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   March 14, 2017, 10:09
Chia
Originally Posted by ngj View Post
Hi Chia,
Kind regards
Niels
Thanks Niels, for the reply
I tried re-running a regular wave simulation, and found that no waves were generated. I admit i think I may had compile wavefoam wrongly on my new working environment.
I'm actually working on a new environment and I tried compiling wavefoam by using of301
I tried to copy my simulations that Ive successfully used in my old workplace using of301, and my current work station doesnt recognize the inlet boundary type of alpha1.org (doesnt recognize waveAlpha) ,
boundaryField
inlet
type waveAlpha;
refValue uniform 0;
refGrad uniform 0;
valueFraction uniform 1;
value uniform 0;
Hence, i tried changing it to fixedValue and no waves were made, thats prolly the case im facing,
I went back to execute ./Allwmake , this is what I got
ENVIRONMENTAL VARIABLES
EXTBRANCH=0
FOAMEXTENDPROJECT=0
OFPLUSBRANCH=0
WAVES_APPBIN=/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin
WAVES_DIR=/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam
WAVES_GSL_INCLUDE=/usr/include
WAVES_GSL_LIB=/usr/lib64
WAVES_LIBBIN=/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/lib
WAVES_POST=/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/applications/utilities/postProcessing
WAVES_PRE=/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/applications/utilities/preProcessing
WAVES_SOL=/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/applications/solvers/solvers301
WAVES_SRC=/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/src
WAVES_TUT=/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/tutorials
WAVES_UTIL=/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/applications/utilities
WAVES_XVERSION=0
WM_PROJECT_VERSION_NUMBER=301
COMPILE LAPACK-3.3.1
lapack-3.3.1 has already been compiled
COMPILE SPARSKIT2
SPARSKIT2 has already been compiled
COMPILE OCEANWAVE3D
Pull changes from the OceanWave3D git repository ...
*** Please tell me who you are.
Run
git config --global user.email "you@example.com"
git config --global user.name "Your Name"
to set your account's default identity.
Omit --global to set the identity only in this repository.
fatal: unable to auto-detect email address (got 'chia@chia-VirtualBox.(none)')
Cannot save the current index state
No stash found.
OceanWave3D has already been compiled
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/ThirdParty
COMPILE FENTON4FOAM
fenton4Foam has already been compiled
COMPILE LIBRARY
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/src/waves2Foam
'/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/lib/libwaves2Foam.so' is up to date.
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/src/waves2FoamProcessing
'/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/lib/libwaves2FoamProcessing.so' is up to date.
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/src/waves2FoamSampling
'/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/lib/libwaves2FoamSampling.so' is up to date.
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/src/waves2FoamPorosity
'/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/lib/libwaves2FoamPorosity.so' is up to date.
COMPILE SOLVERS
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/solvers/solvers301
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/twoPhaseMixture/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/transportModels -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/incompressible/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/interfaceProperties/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/TurbulenceModels/turbulenceModels/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/TurbulenceModels/incompressible/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/finiteVolume/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/fvOptions/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/meshTools/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/sampling/lnInclude -DOFVERSION=300 -DEXTBRANCH=0 -DOFPLUSBRANCH=0 -DXVERSION=0 -I/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/src/waves2Foam/lnInclude -I/home/chia/OpenFOAM/chia-3.0.1/applications/utilities/waves2Foam/src/waves2FoamSampling/lnInclude -I/usr/include -IlnInclude -I. -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude -I/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/OSspecific/POSIX/lnInclude -fPIC -c waveFoam.C -o /home/chia/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt64Opt/applications/utilities/waves2foam/applications/solvers/solvers301/waveFoam.o
In file included from waveFoam.C:73:0:
readWaveProperties.H: In function ‘int main(int, char**)’:
readWaveProperties.H:1:1: error: ‘S’ was not declared in this scope
S Info << "\nReading waveProperties" << endl;
In file included from waveFoam.C:84:0:
CourantNo.H:39:29: error: ‘phi’ was not declared in this scope
fvc::surfaceSum(mag(phi))().internalField()
In file included from waveFoam.C:98:0:
setRDeltaT.H:63:33: error: ‘phi’ was not declared in this scope
fvc::surfaceSum(mag(phi))().dimensionedInternalFie ld()
setRDeltaT.H:64:33: error: ‘rho’ was not declared in this scope
/((2*maxCo)*mesh.V()*rho.dimensionedInternalField() )
setRDeltaT.H:80:17: error: ‘reaction’ was not declared in this scope
mag(reaction->Sh())/(alphaTemp*rho*thermo.Cp()*T)
setRDeltaT.H:80:44: error: ‘rho’ was not declared in this scope
setRDeltaT.H:80:48: error: ‘thermo’ was not declared in this scope
In file included from waveFoam.C:102:0:
In file included from waveFoam.C:103:0:
alphaCourantNo.H:44:9: error: ‘mixture’ was not declared in this scope
mixture.nearInterface()().internalField()
alphaCourantNo.H:45:29: error: ‘phi’ was not declared in this scope
*fvc::surfaceSum(mag(phi))().internalField()
alphaCourantNo.H:32:8: warning: unused variable ‘maxAlphaCo’ [-Wunused-variable]
scalar maxAlphaCo
In file included from waveFoam.C:116:0:
/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/finiteVolume/lnInclude/alphaControls.H:1:51: error: ‘alpha1’ was not declared in this scope
const dictionary& alphaControls = mesh.solverDict(alpha1.name());
In file included from waveFoam.C:117:0:
alphaEqnSubCycle.H:11:32: error: ‘phi’ was not declared in this scope
dimensionedScalar("0", phi.dimensions(), 0)
alphaEqnSubCycle.H:16:38: error: ‘UdmModel’ was not declared in this scope
mesh.Sf() & fvc::interpolate(UdmModel.Udm())
In file included from alphaEqnSubCycle.H:40:0,
alphaEqn.H:29:35: error: ‘talphaPhiCorr0’ was not declared in this scope
if (alphaApplyPrevCorr && talphaPhiCorr0.valid())
alphaEqn.H:38:17: error: ‘mixture’ was not declared in this scope
mixture.alphaMax(),
alphaEqn.H:46:9: error: ‘talphaPhiCorr0’ was not declared in this scope
talphaPhiCorr0 = talphaPhiUD;
alphaEqn.H:77:17: error: ‘mixture’ was not declared in this scope
mixture.alphaMax(),
alphaEqn.H:101:17: error: ‘mixture’ was not declared in this scope
mixture.alphaMax(),
alphaEqn.H:109:9: error: ‘talphaPhiCorr0’ was not declared in this scope
talphaPhiCorr0 = alphaPhi - talphaPhiCorr0;
alphaEqn.H:112:5: error: ‘alpha2’ was not declared in this scope
alpha2 = 1.0 - alpha1;
In file included from alphaEqnSubCycle.H:48:0,
mixture.alphaMax(),
mixture.alphaMax(),
mixture.alphaMax(),
alphaEqnSubCycle.H:57:28: error: ‘turbulence’ was not declared in this scope
- fvm::laplacian(turbulence->nut(), alpha1)
alphaEqnSubCycle.H:63:9: error: ‘alpha2’ was not declared in this scope
alphaEqnSubCycle.H:72:5: error: ‘rhoPhi’ was not declared in this scope
rhoPhi = alphaPhi*(rho1 - rho2) + phi*rho2;
alphaEqnSubCycle.H:72:24: error: ‘rho1’ was not declared in this scope
alphaEqnSubCycle.H:72:31: error: ‘rho2’ was not declared in this scope
alphaEqnSubCycle.H:73:5: error: ‘rho’ was not declared in this scope
rho = mixture.rho();
alphaEqnSubCycle.H:73:11: error: ‘mixture’ was not declared in this scope
waveFoam.C:119:13: error: ‘relaxing’ was not declared in this scope
relaxing.correct();
waveFoam.C:121:13: error: ‘mixture’ was not declared in this scope
mixture.correct();
In file included from waveFoam.C:123:0:
UEqn.H:3:18: error: ‘rho’ was not declared in this scope
fvm::ddt(rho, U)
UEqn.H:4:18: error: ‘rhoPhi’ was not declared in this scope
+ fvm::div(rhoPhi, U)
UEqn.H:5:9: error: ‘turbulence’ was not declared in this scope
+ turbulence->divDevRhoReff(U)
UEqn.H:19:21: error: ‘interface’ was not declared in this scope
interface.surfaceTensionForce()
UEqn.H:20:21: error: ‘ghf’ was not declared in this scope
- ghf*fvc::snGrad(rho)
UEqn.H:21:33: error: ‘p_rgh’ was not declared in this scope
- fvc::snGrad(p_rgh)
UEqn.H:26:9: error: ‘K’ was not declared in this scope
K = 0.5*magSqr(U);
In file included from waveFoam.C:128:0:
pEqn.H:12:51: error: ‘phi’ was not declared in this scope
+ fvc::interpolate(rho*rAU)*fvc::ddtCorr(U, phi)
pEqn.H:15:27: error: ‘p_rgh’ was not declared in this scope
adjustPhi(phiHbyA, U, p_rgh);
pEqn.H:21:13: error: ‘ghf’ was not declared in this scope
pEqn.H:44:31: error: ‘pRefCell’ was not declared in this scope
p_rghEqn.setReference(pRefCell, getRefCellValue(p_rgh, pRefCell));
pEqn.H:62:22: error: ‘gh’ was not declared in this scope
p == p_rgh + rho*gh;
pEqn.H:70:13: error: ‘pRefValue’ was not declared in this scope
pRefValue - getRefCellValue(p, pRefCell)
pEqn.H:70:44: error: ‘pRefCell’ was not declared in this scope
/home/chia/OpenFOAM/OpenFOAM-3.0.1/src/finiteVolume/lnInclude/alphaControls.H:18:8: warning: unused variable ‘icAlpha’ [-Wunused-variable]
scalar icAlpha
/home/chia/OpenFOAM/OpenFOAM-3.0.1/wmake/rules/General/transform:8: recipe for target '/home/chia/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt64Opt/applications/utilities/waves2foam/applications/solvers/solvers301/waveFoam.o' failed
make: *** [/home/chia/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt64Opt/applications/utilities/waves2foam/applications/solvers/solvers301/waveFoam.o] Error 1
COMPILE PRE-PROCESSING
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/faceSetToSTL
make[1]: Entering directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/faceSetToSTL'
make[1]: '/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin/faceSetToSTL' is up to date.
make[1]: Leaving directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/faceSetToSTL'
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/relaxationZoneLayout
make[1]: Entering directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/relaxationZoneLayout'
make[1]: '/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin/relaxationZoneLayout' is up to date.
make[1]: Leaving directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/relaxationZoneLayout'
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/setWaveField
make[1]: Entering directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/setWaveField'
make[1]: '/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin/setWaveField' is up to date.
make[1]: Leaving directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/setWaveField'
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/setWaveParameters
make[1]: Entering directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/setWaveParameters'
make[1]: '/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin/setWaveParameters' is up to date.
make[1]: Leaving directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/setWaveParameters'
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/waveGaugesNProbes
make[1]: Entering directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/waveGaugesNProbes'
make[1]: '/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin/waveGaugesNProbes' is up to date.
make[1]: Leaving directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/preProcessing/waveGaugesNProbes'
COMPILE POST-PROCESSING
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/postProcessing/postProcessWaves2Foam
make[1]: Entering directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/postProcessing/postProcessWaves2Foam'
make[1]: '/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin/postProcessWaves2Foam' is up to date.
make[1]: Leaving directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/postProcessing/postProcessWaves2Foam'
/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/postProcessing/surfaceElevation
make[1]: Entering directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/postProcessing/surfaceElevation'
make[1]: '/home/chia/OpenFOAM/chia-3.0.1/platforms/linux64GccDPInt64Opt/bin/surfaceElevation' is up to date.
make[1]: Leaving directory '/home/chia/OpenFOAM/OpenFOAM-3.0.1/applications/utilities/waves2foam/applications/utilities/postProcessing/surfaceElevation'
COMPILATION DONE
it seems that in the waveFoam.C , there are alot of commands or items 'not declared' and i think that could be the root of the problem, any insights on how to proceed further?
thanks for your kind patience
Old   March 14, 2017, 11:09
ngj
You must have created the solver yourself, as 3.0.1 is not supported with solvers. You are likely missing files, but I cannot help in narrowing it down.
Kind regards
Niels
[waves2Foam] combined set of waves with waves2Foam blaise OpenFOAM Community Contributions 7 December 16, 2023 08:33
gravitational waves and capillary waves astroam COMSOL 0 August 15, 2015 16:49
gravitational waves and capillary waves astroam COMSOL 0 August 1, 2015 10:38
WAVES GENERATION IN A PORT OR BRAKE WAVES. important tecnicaf1 STAR-CCM+ 1 May 27, 2011 07:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
