[swak4Foam] Calculate variable at different heights with GroovyBC
Old   December 7, 2016, 09:26
Default Calculate variable at different heights with GroovyBC
Agustín Villa
agustinvo is on a distinguished road
I would like to ask you if you have ever used GroovyBC in this way. I want to replicate a BC given by the author of my test case, where it computes a variable at different heights of a patch, which corresponds to the heights of the different cells. And once this variable is given, the gradient of the same in function of the height is calculated. The use of the gradient is not a mistery, but I have no idea on how to compute for each face of my patch the indicated value.
There is an attached sketch. The dashed lines (at different heights) are the lines where I have to compute the variable.
Thanks for your attention!
agustinvo is offline   Reply With Quote
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
UDF for time based variable to calculate velocity longhuandu Fluent UDF and Scheme Programming 1 January 21, 2013 06:38
Condensation as an additional variable Clark Griswold CFX 2 April 21, 2012 07:20
[OpenFOAM] How to calculate flux across the patch unit ParaView 0 October 23, 2008 16:02
Calculate variable div zero braennstroem OpenFOAM Post-Processing 8 January 28, 2008 10:02
