[cfMesh] improveMeshQuality
Old   May 30, 2017, 01:49
Default improveMeshQuality
M. C.
student666 is on a distinguished road
currently I'm using cfMesh as meshing tool.
I found out the
improveMeshQuality
command, but I use it with default settings.
Default number of loops is 10
Default number of iterations is 50
Default number of surface iterations is 2
Using default quality threshold 0.1
No constraints applied on the smoothing procedure
With default settings, my feeling is that cfMesh tends to reduce the skewness of the faces, but generally non orthogonality increases, is it right?
Now I would like to ask if it is possibile to set it up to work on specific errors that arise with the
checkMesh
utility and if someone can share her/his experience with this option.
e.g. If checkMesh shows a huge non-ortogonality value (> 80) I would like to make
improveMeshQuality
work to reduce mainly this parameter.
This is a checkMesh after a single run with cartesianMesh
    Overall domain bounding box (-4.43393e-012 0.3235 -0.225969) (0.25 1.012 0.318)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Boundary openness (-9.98583e-015 2.23961e-015 9.44861e-016) OK.
    Max cell openness = 8.63145e-016 OK.
    Max aspect ratio = 139.552 OK.
    Minimum face area = 2.08953e-009. Maximum face area = 2.05036e-005.  Face area magnitudes OK.
    Min volume = 4.11405e-013. Max volume = 5.75174e-008.  Total volume = 0.0601205.  Cell volumes OK.
    Mesh non-orthogonality Max: 88.6164 average: 6.16081
   *Number of severely non-orthogonal (> 70 degrees) faces: 407.
    Non-orthogonality check OK.
  <<Writing 407 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
Average skewness 0.0461554
 ***Max skewness = 5.73023, 266 highly skew faces detected which may impair the quality of the results
  <<Writing 266 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
this is a first checkMesh output after improveMeshQuality has been run
Checking geometry...
    Boundary openness (-1.03912e-014 2.23071e-015 9.15085e-016) OK.
    Max cell openness = 1.44747e-015 OK.
    Max aspect ratio = 55.296 OK.
    Minimum face area = 1.8092e-009. Maximum face area = 2.05036e-005.  Face area magnitudes OK.
    Min volume = 7.42452e-014. Max volume = 5.12649e-008.  Total volume = 0.0601206.  Cell volumes OK.
    Mesh non-orthogonality Max: 86.0757 average: 8.91875
   *Number of severely non-orthogonal (> 70 degrees) faces: 9567.
  <<Writing 9567 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
Average skewness 0.0406472
 ***Max skewness = 4.91016, 2 highly skew faces detected which may impair the quality of the results
  <<Writing 2 skew faces to set skewFaces
Thanks in advance.
Regards.
student666 is offline   Reply With Quote
