[PyFoam] notebook with Pyfoam: case not working + deprecated widget warning
Prev Previous Post   Next Post Next
Old   August 27, 2017, 10:05
Default notebook with Pyfoam: case not working + deprecated widget warning
Jeff
jf_vt is on a distinguished road
Hi
I am using pyFoamIPythonNotebook.py to initialize jupyter notebook to postprocess cases
Doing so ,I run in 2 issues that might be related.
1-When executed for the first time, the cell
from PyFoam.IPythonHelpers.Case import Case
return the warning:
/home/jf/anaconda2/lib/python2.7/site-packages/IPython/html.py:14: ShimWarning: The `IPython.html` package has been deprecated since IPython 4.0. You should import from `notebook` instead. `IPython.html.widgets` has moved to `ipywidgets`.
  "`IPython.html.widgets` has moved to `ipywidgets`.", ShimWarning)
and I dont understand the recommendation this warning carries:
by the way ipydgets and mathJax are installed inmyenvironment.
Now ignoring this warning and continuing
I notice that all the cells
case.timelineSelector or case.pickledPlotSelector
fail with the same error
AttributeError                            Traceback (most recent call last)
<ipython-input-18-cdb75a748b1b> in <module>()
----> 1 case.timelineSelector('postProcessing/patchExpression_CO2')
/home/jf/foam/foam-extend-4.0/ThirdParty/packages/PyFoam-0.6.4/platforms/noarch/lib/python2.7/site-packages/PyFoam/IPythonHelpers/Case.pyc in timelineSelector(self, directoryName)
    205     def timelineSelector(self,directoryName):
    206         info=self.timelineInfo(directoryName)
--> 207         lst=[widgets.LatexWidget(value="Fields:")]
    208         fieldsSelected=set()
    209         storeButton=widgets.ButtonWidget(description="Store to",disabled=True)
/home/jf/anaconda2/lib/python2.7/site-packages/IPython/utils/shimmodule.pyc in __getattr__(self, key)
     90             return import_item(name)
     91         except ImportError:
---> 92             raise AttributeError(key)
AttributeError: LatexWidget
apparently related to a widget (so related to 1 above..?)
Is is a known behavior
and is there a way to fix it?
Thanks
JF
jf_vt is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
