March 14, 2018, 00:26 |
Stream Function wave theory
Kun Zheng
Rep Power: 9 |
Hi Niels,
I find the code fragment of the wave theory: Stream Function theory is somewhat different from what described in manualWavesFoam_v090. I am not sure if I download the latest version of manual. But I think the code fragment of Stream Function theory you described in manual is much more convenient to use. Because I can not get the exact value of uBar, A(), and B(), which is necessary for using SF in waves2Foam, even if I have the streamfunction (CW263) code. I am really appreciated if you could give more guidance to have these value for a certain regular wave. Thank you ! Best regards, Kun |
March 14, 2018, 01:06 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Kun,
I do not understand your question. Stream function wave theory is part of setWaveParameters and it works as detailed in the manual. Maybe you use a too old version of waves2Foam? Check the appendix for corrections to the code and associated svn revision. Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
March 14, 2018, 20:41 |
#3 | |
Kun Zheng
Rep Power: 9 |
Best regards, Kun |
March 15, 2018, 01:20 |
Rep Power: 37 |
Hi Kun,
Please describe the wrong usage, so other users can learn. Kind regards Niels
March 16, 2018, 02:08 |
#5 | |
Kun Zheng
Rep Power: 9 |
So I highly suggest the new waves2Foamer to read your manual firstly. Best regards Kun |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
