June 5, 2018, 10:50 |
Problems with OF-v1612+
P.A.
Rep Power: 17 |
I tried to compile waves2Foam under OF-v1612+ today, as it was named as a supported version in the waves2Foam manual. Unfortunately I had to find out that there is no "solver" for this version in the solvers section for the various OF versions. Researching this issue I came across a post from ngj from last year (Release of a Wave Generation and Absorption Toolbox for OF) about some incompatibility issues. I wonder if these issues are resolved (as the manual dates from November 2017, and the post from January 2017) , and if there is a suitable "solvers1612_PLUS" directory available somehow/somewhere (probably not, as it is missing in the current svn repository... I just want to be sure). Thank you and best regards, Pascal. -- |
June 5, 2018, 11:02 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Pascal,
The incompatible issue for wave gauges is solved, but I have not created solvers for 1612. There are solvers available for 1712, so better to use a more recent version. Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
June 6, 2018, 02:56 |
P.A.
Rep Power: 17 |
Hi Niels,
thank you for your response. I will try to follow your recommendation. One minor problem (or actually a confusion) arises from the version numbering scheme. There seems to be no such version like 1712+, only 1712 (on openfoam.com). There was a 1606+ and a 1612+ version, but this "+" scheme seems to be discontinued since 17XX. Am I right? Then again, which OF version does the 1712+ solver in waves2Foam refer to? Could you please clear my confusion? Thank you very much! Pascal. -- |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 03:45 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 05:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 11:00 |
