[waves2Foam] Average wave elevation decreases along the propagation axis |
June 13, 2018, 08:43 |
Constance C
Hi everyone,
I am currently modelling a Numerical Wave Tank (NWT) thanks to OpenFOAM using the toolbox waves2Foam. The solver waveFOAM allows to generate and absorb waves and also to track the free surface. My simulations run and I have great results! However, I observe that the average wave elevation depends on the place in the NWT. In the generation and absorption zones, this is explained by the relaxation method implemented in the solver. But between these two zones, in the "CFD zone", the average elevation decreases linearly in function of the abscissa along the wave propagation axis. I changed the size of generation and absorption but it does not have an impact on results. Is it a problem you have already observed ? Thanks a lot in advance ! Constance |
June 18, 2018, 05:24 |
Constance C
Hi everyone,
I am currently modelling a Numerical Wave Tank (NWT) thanks to OpenFOAM using the great toolbox waves2Foam. I observe that the average wave elevation depends on the place in the NWT. In the generation and absorption zones, this is explained by the relaxation method implemented in the solver. But between these two zones, in the "CFD zone", the average elevation decreases linearly in function of the abscissa along the wave propagation axis. I changed the size of generation and absorption but it does not have an impact on results. Is it a problem you have already observed ? Also, I am wondering if it is better to control simulation with a little Courant Number (maxCo) or a little deltaT (maxdeltaT) in controlDict ? Thanks a lot in advance ! Constance |
decrease, elevation, propagation, waves2foam |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
How to obtain turbulent kinetic energy data from LES model of Ansys CFX? | rsin | CFX | 19 | December 29, 2018 04:43 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
UDF for Sinusoidal wave propagation at channel wall | engrmansoor2534 | Fluent UDF and Scheme Programming | 5 | August 21, 2015 04:01 |
help for a modified probe file (wave elevation vs time ) | zhajingjing | OpenFOAM | 5 | August 5, 2011 08:25 |
