[waves2Foam] Building of waveDyMFoam under foam-extend-4.0
Old   January 15, 2018, 06:33
Default Building of waveDyMFoam under foam-extend-4.0
P.A.
blaise is on a distinguished road
Hello all,
I am trying to build waveFoam with dynamic mesh functionality (waveDyMFoam) under foam-extend-4.0. waves2Foam svn checkout is from 2018-01-09). I am following the instructions in Niels manual but I am unsure if I did things right as I am not proficient enough with the theory and the coding in OpenFOAM. As far as I understood things, I had to compare the changes that were applied to interFoam to create waveFoam from it, and incorporate these changes to interDyMFoam.
I attach my solution, which compiles without errors. I know that this does not mean the solver will work correctly. Could someone be so kind as to check the modified code and tell me if something is wrong?! I am especially unsure about pEqn.H (treatment of phi and the pimple correction loop).
The modifications are marked with "PAmod" and "PAadd" - unfortunately the code does not get more readable by it - apologies!
Any hint is appreciated.
Thank you very much!
Best regards,
Pascal.
blaise is offline   Reply With Quote
Old   January 15, 2018, 08:34
Default Correction in code
P.A.
this is an update to my previous code alteration. Please consider the previous attachment as obsolete.
Regards,
Pascal.
Old   March 11, 2024, 04:43
LIU XIN
liuxinsan is on a distinguished road
in .c file
maybe u forgot something in the last line
// Close down the external wave forcing in a nice manner
externalWave->close();
liuxinsan is offline   Reply With Quote
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
