[swak4Foam] funkyDoCalc in cyclic system
Old   November 2, 2016, 21:07
Smile funkyDoCalc in cyclic system
Su Choi
S choi is on a distinguished road
I am trying to analyze results from openfoam calculation using funkyDoCalc.
ex) funkyDoCalc -time 0.65 calfile
It works well in normal full 3d case,
but in periodic system(there are 2 cyclic patches; cyclic_a, cyclic_b) funkyDoCalc does not work and shows error message like
--> FOAM FATAL IO ERROR:
keyword rotationAngle is undefined in dictionary "::cyclic_a"
file: ::cyclic_a from line 67 to line 75.
how can I solve this problem??
S choi is offline   Reply With Quote
Old   November 7, 2016, 16:41
Assistant Moderator
Bernhard Gschaider
That is not much context to work with: when does the problem occur? While reading the mesh or reading a field-file? Please at least add a few lines of the "regular" output before that error. Without that I would have to guess
BTW: Foam-version and swak-version are also important. AND: was the case written with the same Foam-version that you're currently using?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
cyclic, funkydocalc, rotationangle, swak4foam
Why Menter's SST model low-Re issue has not been seriously investigated? vkrastev OpenFOAM 58 January 8, 2018 15:20
which windows operating system for multi-core system? Chris Lee Hardware 11 December 14, 2014 07:26
simpleFoam + cyclic pipe = unstable? RodriguezFatz OpenFOAM Running, Solving & CFD 9 December 1, 2014 05:28
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
Cyclic boundary matching - help needed Robert_B STAR-CD 5 June 15, 2011 08:03
