[swak4Foam] groovyBC usage
Old   July 28, 2015, 08:41
Default groovyBC usage
Antonio
avigrod is on a distinguished road
I have created the following boundary condition for the phase.water based on Swak4FOAM:
inlet
        type            groovyBC;
        valueExpresion "(pos().z<=0.20) ? 1 : 0";
       value 1;
And i included
libs (
      "libOpenFOAM.so"
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
in my controlDict
however when calling interFoam, (or when decomposing), I get alpha.water = 0 in all points as well as a warning like this:
--> FOAM Warning :
    From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/Field.C at line 318
    Reading "/home/user/OpenFOAM/user-2.3.0/run/rejas_m028horizontal/0/alpha.water.boundaryField.inlet" from line 26 to line 30
    expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
where lines 26-30 are the lines I pasted previously.
Am I doing something wrong?
I am using OpenFOAM 2.3.0 and swak4FOAM 0.3.1
avigrod is offline   Reply With Quote
Old   July 30, 2015, 08:54
Antonio
inlet
        type            groovyBC;
       value 1;
And i included
libs (
      "libOpenFOAM.so"
      "libgroovyBC.so"
in my controlDict
--> FOAM Warning :
It was working properly. By the way before I realised, I also saw how to the same in another way (with codedFixedValue). I will paste it into another page in case it is usefull for anybody
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC interFoam splitted inlet -- massflowrate FerdiFuchs OpenFOAM Community Contributions 1 October 1, 2014 07:51
