[swak4Foam] Groovy boundary condition
Old   April 4, 2015, 03:06
Default Groovy boundary condition
harshawardhank
harsha_kulkarni is on a distinguished road
Hello friends,
I am using groovyBC for linear temp. profile after that which command should I run for implementing groovyBC.
Regards
Harshawardhan
harsha_kulkarni is offline   Reply With Quote
Old   April 4, 2015, 04:36
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by harsha_kulkarni View Post
Hello friends,
Regards
Harshawardhan
Dear Harwardhan,
From your post it is understood that you have implemented groovyBC in your case and you are facing difficulty to run the same.
Please edit these libraries in the system folder of your case directory (path: $OF_case/system/).
Add these lines in "controlDict" file (on the top or bottom of the file):
libs (
      "libOpenFOAM.so"
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
Best Luck!
Tushar@cfd is offline   Reply With Quote
Old   April 4, 2015, 06:32
harshawardhank
Yes it's working now getting this error
--> FOAM FATAL ERROR:
No terminating ';' found in expression '"z=vector(0,0.01,0.1)"' of dictionary ".temperature"
here I'm attaching funkySetFieldDict
FoamFile
version 2.0;
format ascii;
root "/.automount/werner/Werner/bgschaid/bgschaid-foamStuff/DepositionTests";
case "neutralTest";
instance "system";
local "";
class dictionary;
object funkySetFieldsDict;
expressions
temperature
field T;
target value;
patchName movingWall;
variables "z=vector(0,0.01,0.1)";
expression "0.01*z";
Old   April 4, 2015, 06:36
T. Chourushi
Dear Harshwardhan,
This issue is related to the expression used for the temperature boundary condition placed inside the "0" folder. Can you post your expression here:
Best Regards!
Old   April 5, 2015, 00:30
T. Chourushi
FoamFile
version 2.0;
format ascii;
case "neutralTest";
instance "system";
local "";
class dictionary;
expressions
temperature
field T;
target value;
Dear Harwardhan,
You miss ";" at the end of your variable expression. Write like this:
expressions
         temperature
        field T;
                target value;
        variables "z=vector(0,0.01,0.1);";
This will work
Best Luck!
Old   April 6, 2015, 07:46
Exclamation
harshawardhank
now I have got this error
inconsistent types: T is volScalarField while the expression evaluates to a volVectorField
Old   April 6, 2015, 23:55
T. Chourushi
Dear Harshawardhan,
You have Temperature field which is scalar and the expression applied as boundary condition (in groovybc) is of vector form.
Can you please elaborate your problem case in detail with actual mathematical expression that you want to apply?
Best Regards!
Old   May 11, 2015, 13:53
Juan David Rodriguez P
JuanRodriguez is on a distinguished road
Dear Mr. Tushar
My case is about heat conduction through a solid and I am trying to calculate the gradient of Temperature in order to plot the heat flux lines in paraview. I think using funkySetsFields -field T -region solid -expression "grad(T)" -latestTime will help me but I get this error:
swakVersion: 0.3.1 (Release date: 2014-07-11)
Create time
Create mesh solid for time = 5000
Time = 5000
 Using command-line options
 Modifying field T of type volScalarField
 Putting "grad(T)" into field T at t = "5000" if condition "true" is true
swak4Foam: Allocating new repository for sampledMeshes
swak4Foam: Allocating new repository for sampledGlobalVariables
    From function doAnExpression()
    in file funkySetFields.C at line 361.
FOAM exiting
Do you know what might be wrong?
Thank you.
JuanRodriguez is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
