[waves2Foam] Looking for equations of turbulence model and very high pressures (p_rgh)
Old   March 13, 2014, 04:22
Default Looking for equations of turbulence model and very high pressures (p_rgh)
Nick Krgs
Nick_civ is on a distinguished road
Hi Niels,
1) I am trying to find where the equations of your turbulence model (as described in your article) are. I have run several cases and I can see breaking wave or run up but you have set laminar in the turbulence properties file. I suppose that your turbulence model is included inside the code and I am trying to find where. Can you help me?
2) I get very high pressures (p_rgh) when I use snappyhexMesh and the p_rgh animation (Paraview) is like the alpha one. It must be mentioned that I have changed the sea level (it is not zero) because the stl file must have positive coordinates. You can try it with the test attached to my previous posts (#1 post here). Do you have any idea about that?
Thank you in advance.
Kind regards,
Nick
Last edited by wyldckat; November 4, 2018 at 14:07. Reason: changed reference to post #720
Nick_civ is offline   Reply With Quote
Old   March 13, 2014, 12:08
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Nick,
Ad. 1.: The turbulence model is not part of waves2Foam. I do not have any immediate plans of releasing it.
Ad. 2.: The pressure does exactly as it is supposed to do. p_rgh is the pressure in excess of the hydrostatic component, which is 0 for z = 0 m, i.e. placing the sea level high means that the hydrostatic pressure is large and negative, why p_rgh has to be large and positive.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
