November 7, 2018, 08:42 |
Refine mesh inside auxiliary STL
Marc
Rep Power: 9 |
I'm trying to mesh a nozzle geometry with cfmesh and have a question regarding refinement with external STLs. In snappy you can access an auxiliary STL and refine inside it using "refinementRegions" and "mode inside". However in cfmesh I only see two options:
April 1, 2020, 10:10 |
#2 | |
Lei
Rep Power: 7 |
Have you found an answer to this? I am thinking of using patch for overlapping faces of different regions but am also trying to figure out how to get a refinement in an arbitrary region, e.g. described by another stl file.
April 1, 2020, 10:31 |
Marc
Rep Power: 9 |
From out testing cfMesh is not ideal because, although it achieves great boundary layer coverage, it retains bad quality cells which causes cases to eventually diverge. My recommendation would be to go back to sHM which does not have this critical issue and enables you to have arbitary refinement regions |
April 1, 2020, 14:06 |
Catchup discussion
#4 | |
Lei
Rep Power: 7 |
Hi, Dreoasteh,
thanks for your comment on cfMesh. By bad quality cell you mean the degree of skewness? I don't know yet but maybe there's some options to regulate this like in blockMesh? Ok, I would try sHM that you suggested and the only problem is that I don't know what is a sHM? Could you inform a full name? Quote:
April 1, 2020, 14:17 |
Marc
Rep Power: 9 |
The bad quality cells come from different types, skewness, cell volume, etc. There's no option to tighten tolerances or improve mesh quality as the whole idea of cfMesh is to have an automatic mesher with a small numer of degrees of freedom. In our experience it is always a good idea to try out cfMesh but be aware that your case can blow up with no aparent reason and with little in the way of fixing it.
By sHM I ment snappyHexMesh which is an automatic mesher that comes with OpenFOAM. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
