[IHFOAM] IHFOAM patch problem IH_Waves_InletVelocity |
February 22, 2018, 10:56 |
Jorge Molines
Rep Power: 13 |
Hi!
I have downloaded and installed OpenFoam and Ihfoam and I have a problem with the patchField type IH_Waves_InletVelocity. My versions are Ubuntu 16.04, OpenFoam 1706 and ihFoam 1706 downloaded from http://ihfoam.ihcantabria.com/source-download/. Both installations of OpenFoam and ihFoam finished succesfully. I am running an example of a breakwater with porous media that I also downloaded from the web prepared for OF 230_240 and I modified some patches and the mode of the operating solver from PIMPLE to PISO. However, I do not know how to solve the new problem . Thanks in advance for any advise, Jorge. jorge@jorge-VirtualBox:~/OpenFOAM/OpenFOAM-v1706/tutorials/tutorials/OF230_240/breakwater$ ihFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1706 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1706 Arch : "LSB;label=32;scalar=64" Exec : ihFoam Date : Feb 22 2018 Time : 16:49:22 Host : "jorge-VirtualBox" PID : 26351 Case : /home/jorge/OpenFOAM/OpenFOAM-v1706/tutorials/tutorials/OF230_240/breakwater nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field porosityIndex Porosity activated Reading porosity variables Number of materials: 4 a = 4(0 50 50 50) b = 4(0 1.2 2 0.6) c = 4(0 0.34 0.34 0.34) D50 = 4(1 0.01 0.035 0.12) porosity = 4(1 0.49 0.493 0.5) Transient formulation is 0 Creating fields: porosity, aPor, bPor, cPor and D50Por Reading field p_rgh Reading field U --> FOAM FATAL IO ERROR: Unknown patchField type IH_Waves_InletVelocity for patch type patch Valid patchField types are : 81 ( SRFFreestreamVelocity SRFVelocity SRFWallVelocity activeBaffleVelocity activePressureForceBaffleVelocity advective atmBoundaryLayerInletVelocity calculated codedFixedValue codedMixed cyclic cyclicACMI cyclicAMI cyclicSlip cylindricalInletVelocity directionMixed empty extrapolatedCalculated fixedGradient fixedInternalValue fixedJump fixedJumpAMI fixedMean fixedNormalInletOutletVelocity fixedNormalSlip fixedProfile fixedShearStress fixedValue flowRateInletVelocity fluxCorrectedVelocity freestream inletOutlet interstitialInletVelocity kqRWallFunction mapped mappedField mappedFixedInternalValue mappedFixedPushedInternalValue mappedFlowRate mappedVelocityFlux mixed movingWallVelocity noSlip nonuniformTransformCyclic outletInlet outletMappedUniformInlet outletPhaseMeanVelocity partialSlip pressureDirectedInletOutletVelocity pressureDirectedInletVelocity pressureInletOutletParSlipVelocity pressureInletOutletVelocity pressureInletUniformVelocity pressureInletVelocity pressureNormalInletOutletVelocity pressurePIDControlInletVelocity processor processorCyclic rotatingPressureInletOutletVelocity rotatingWallVelocity sliced slip supersonicFreestream surfaceNormalFixedValue swirlFlowRateInletVelocity symmetry symmetryPlane timeVaryingMappedFixedValue translatingWallVelocity turbulentDFSEMInlet turbulentInlet uniformFixedGradient uniformFixedValue uniformInletOutlet uniformJump uniformJumpAMI variableHeightFlowRateInletVelocity waveTransmissive waveVelocity wedge zeroGradient ) file: /home/jorge/OpenFOAM/OpenFOAM-v1706/tutorials/tutorials/OF230_240/breakwater/0/U.boundaryField.inlet from line 26 to line 28. From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam:imensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>] in file /home/jorge/OpenFOAM/OpenFOAM-v1706/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 134. FOAM exiting |
February 26, 2018, 07:23 |
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
Rep Power: 8 |
Hi Jorge,
I just add here the answer I already sent you in case anyone might need it: IHFOAM boundary conditions are now implemented and released within OpenFOAM (since version v1612+) thanks to an agreement between ESI & IH-Cantabria. (https://www.openfoam.com/releases/op...ave-generation) You can find several tutorials in: ~/OpenFOAM-XXX/tutorials/multiphase/interFoam/laminar/waveExampleXX If you want to use the old ihFOAM tutorials, you must just change and adapt the names of the BC's. Best Regards, IHFOAM Team.
http://ihfoam.ihcantabria.com/ |
February 28, 2018, 10:07 |
Jorge Molines
Rep Power: 13 |
Thanks for your answer!
Regards, Jorge. |
October 22, 2018, 23:26 |
Luo_Bingjun
Rep Power: 7 |
Hello!I meet the same problem as you. The error "Unkown IHFOAM patch problem IH_Waves_InletVelocity" happens. My version is of v1806. How can I solve this problem. Thank you!
October 23, 2018, 03:08 |
Rep Power: 8 |
Hi Robin86
Please, canyou tell me which version of IHFoam have you tried to used with OpenFOAM-v1806? Regards, IHFOAM Team
October 23, 2018, 03:42 |
Luo_Bingjun
Rep Power: 7 |
I use OpenFoam v1806 and ihFoam v1806.
October 25, 2018, 21:52 |
Luo_Bingjun
Rep Power: 7 |
I use OpenFOAM 1806 to run the IHFOAM old version tutorials. The same problem "Unknown patchField type IH_Waves_InletVelocity" appears, just like the above problem. How can I solve it? Should I change the old version tutorials BC's? Which BC needs to be changed and how to change it? I am new OpenFOAM user. Thank you!
November 6, 2018, 09:32 |
Rep Power: 8 |
Hi Robin86,
There is no point in using the old version of IHFOAM with OpenFOAM-v1806. Why? Because, IHFOAM boundary conditions are already implemented within OpenFOAM-v1806 in a more accurate and faster way than the first release. Can I ask you why do you want to do this strange thing? Best Regrards, IHFOAM Team
November 6, 2018, 20:34 |
#9 |
Luo_Bingjun
Rep Power: 7 |
Actually, I want to run the old tutorials to understand how to monitor free surface of wave. The old tutorials realize this while the tutorials in OpenFOAM 1806 do not. How to draw the curve of wave elevation and time in specified location? Thank you!
November 7, 2018, 02:49 |
#10 | |
Rep Power: 8 |
Hi Robin86,
Please, take a look to the end of the controlDict: Code:
functions { line { type sets; libs ("libsampling.so"); enabled true; writeControl writeTime; writeInterval 1; interpolationScheme cellPoint; setFormat raw; sets ( line1 { type uniform; axis distance; start ( 1.0 0.02 0.0 ); end ( 1.0 0.02 0.55 ); nPoints 1001; } line2 { type uniform; axis distance; start ( 2.0 0.02 0.0 ); end ( 2.0 0.02 0.55 ); nPoints 1001; } line3 { type uniform; axis distance; start ( 3.0 0.02 0.0 ); end ( 3.0 0.02 0.55 ); nPoints 1001; } line4 { type uniform; axis distance; start ( 5.0 0.02 0.0 ); end ( 5.0 0.02 0.55 ); nPoints 1001; } line5 { type uniform; axis distance; start ( 7.5 0.02 0.0 ); end ( 7.5 0.02 0.55 ); nPoints 1001; } line6 { type uniform; axis distance; start ( 10.0 0.02 0.0 ); end ( 10.0 0.02 0.55 ); nPoints 1001; } line7 { type uniform; axis distance; start ( 12.0 0.005 0.0 ); end ( 12.0 0.005 0.55 ); nPoints 1001; } line8 { type uniform; axis distance; start ( 14.0 0.005 0.0 ); end ( 14.0 0.005 0.55 ); nPoints 1001; } ); fixedLocations false; fields ( U alpha.water ); } } Best Regards, IHFOAM Team
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 36 | January 7, 2015 00:31 |
[Gmsh] Single volume Mesh gmsh | PeteH | OpenFOAM Meshing & Mesh Conversion | 9 | August 6, 2013 08:54 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
