[cfMesh] How to run CfMesh in parallel?
Like Tree2Likes
  • 1 Post By Krao
  • 1 Post By Carlo_P
Old   June 27, 2019, 05:41
Default How to run CfMesh in parallel?
Carlo_P
Carlo_P is on a distinguished road
Dear all,
I'm trying to use CfMesh in parallel.
I'm not an able user of Linux.
Can someone explain me step by step every single command?
I tryed with cartesianMesh, but I have a error:
attempt to run parallel on 1 processor.
Thanks a lot,
Carlo
Carlo_P is offline   Reply With Quote
Old   June 27, 2019, 07:57
Kmeti Rao
Krao is on a distinguished road
Hi Carlo,
follow this link cfmesh and OMP_NUM_THREADS weirdness
Regards
Krao is offline   Reply With Quote
Old   June 28, 2019, 05:35
Carlo_P
Thanks Krao for the link.
I saw also before it, but I didn't understand where I have to modify OMP_NUM_THREADS .
Should I also decompose the case before?
Thanks a lot,
Carlo
Old   June 28, 2019, 07:16
Kmeti Rao
Hi Carlo,
Open the terminal and go to the directory in which your mesh is placed. Before running the command cartesianMesh or whichever you would like to run, enter 'bash' and press 'enter'. After this, type for example, 'export OMP_NUM_THREADS=4,4'. Use the system monitor to know, whether the application utilising all the cores. Also, you would see change in total meshing time. I think it is not required to decompose. It is only required to run the application.
Krao
lukasf likes this.
Old   July 2, 2019, 06:01
Carlo_P
Thanks Krao,
your process worked perfectly!
Thanks a lot again,
Carlo
Krao likes this.
cfmesh, meshing, parallel
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 10:35
chtMultiRegionSimpleFoam: crash on parallel run student666 OpenFOAM Running, Solving & CFD 3 April 20, 2017 11:05
User fortran to input/output file in a parallel run doublestrong CFX 5 March 31, 2017 08:15
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 14:43
