[cfMesh] only one (surface) patch after meshing
Old   December 29, 2019, 08:15
Default only one (surface) patch after meshing
Kahnbein.Kai is on a distinguished road
the origin file format is parasolid with 20 selectable faces on it.
I downloaded the the file in the stl format, and mesh it with cfmesh.
In the MeshMetaDict file is only one patch for the hole surface.
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant/polyMesh";
    object      meshMetaDict;
surfaceFile     "HWE_symmetrie_II_cropped.stl";
surfaceMeta
    nPoints         23058;
    nFacets         46112;
    nPatches        1;
    nFeatureEdges   0;
    patches
        patch0
            type            empty;
            nFacets         46112;
    pointSubsets
    facetSubsets
    featureEdgeSubsets
Is there any way to get the faces back ?
Best regards
Kai
edit: i found the tool "surfaceAutoPatch", it works, but it is a little unclean, is there any other way available ?
Kahnbein.Kai is offline   Reply With Quote
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
