[waves2Foam] Compiling Waves2Foam r2137 error: no matching function for call to ‘exp(Foam::complex
Old   March 5, 2020, 10:54
Post Compiling Waves2Foam r2137 error: no matching function for call to ‘exp(Foam::complex
Marc
Marc_H is on a distinguished road
Hallo All,
I have trouble with compiling waves2Foam r2137. I think the problem is in the updated version for 1912 + waveFoam solver. Because the function ‘exp(Foam::complex' has no match. Does anyone has a clue on what is going on?
cheers,
Marc
    ENVIRONMENTAL VARIABLES
EXTBRANCH=1
FOAMEXTENDPROJECT=1
OFPLUSBRANCH=0
WAVES_APPBIN=/home/marc/foam/marc-3.1/applications/bin/linux64GccDPOpt
WAVES_DIR=/home/marc/foam/marc-3.1/applications/utilities/waves2Foam
WAVES_GSL_INCLUDE=/usr/include
WAVES_GSL_LIB=/usr/lib64
WAVES_LIBBIN=/home/marc/foam/marc-3.1/lib/linux64GccDPOpt
WAVES_POST=/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/applications/utilities/postProcessing
WAVES_PRE=/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/applications/utilities/preProcessing
WAVES_SOL=/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/applications/solvers/solvers310_EXT
WAVES_SRC=/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/src
WAVES_TUT=/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/tutorials
WAVES_UTIL=/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/applications/utilities
WAVES_XVERSION=0
WM_PROJECT_VERSION_NUMBER=310
    COMPILE LAPACK-3.3.1
lapack-3.3.1 has already been compiled
    COMPILE SPARSKIT2
SPARSKIT2 has already been compiled
    COMPILE OCEANWAVE3D
OceanWave3D has already been compiled
/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/ThirdParty
    COMPILE FENTON4FOAM
fenton4Foam has already been compiled
    COMPILE LIBRARY
'/home/marc/foam/marc-3.1/lib/linux64GccDPOpt/libwaves2Foam.so' is up to date.
SOURCE=postProcessing/postProcessingWaves/spectralAnalysis/fftBasedMethods/reflectionAnalysis2DFFT/reflectionAnalysis2DFFT.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOFVERSION=310     -DEXTBRANCH=1     -DXVERSION=0     -DOFPLUSBRANCH=0     -I/home/marc/foam/foam-extend-3.1/src/finiteVolume/lnInclude     -I/home/marc/foam/foam-extend-3.1/src/meshTools/lnInclude     -I/home/marc/foam/foam-extend-3.1/src/sampling/lnInclude     -I/home/marc/foam/foam-extend-3.1/src/lagrangian/basic/lnInclude     -I/home/marc/foam/marc-3.1/applications/utilities/waves2Foam/src/waves2Foam/lnInclude     -I/usr/include -IlnInclude -I. -I/home/marc/foam/foam-extend-3.1/src/foam/lnInclude -I/home/marc/foam/foam-extend-3.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/reflectionAnalysis2DFFT.o
postProcessing/postProcessingWaves/spectralAnalysis/fftBasedMethods/reflectionAnalysis2DFFT/reflectionAnalysis2DFFT.C: In member function ‘void Foam::reflectionAnalysis2DFFT::decomposeAmplitudes(const scalarField&, const Foam::List<Foam::Field<Foam::complex> >&, Foam::Field<Foam::complex>&, Foam::Field<Foam::complex>&, Foam::scalarField&)’:
postProcessing/postProcessingWaves/spectralAnalysis/fftBasedMethods/reflectionAnalysis2DFFT/reflectionAnalysis2DFFT.C:242:52: error: no matching function for call to ‘exp(Foam::complex)’
                         *exp( ii*kj*(X_[q] - X_[0]))
Marc_H is offline   Reply With Quote
error, no matching function, waves2foam
[waves2Foam] stuck in compiling the waves2Foam library for OF-v1712 due to MA41 Ya_Squall2010 OpenFOAM Community Contributions 3 April 16, 2019 08:21
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 11:32
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 22:07
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
