[Other] [cfMesh] Error when creating AMI patches propeller
Old   October 21, 2021, 14:23
Default [cfMesh] Error when creating AMI patches propeller
Gabriel Felix
gabrielfelix is on a distinguished road
Hi folks,
I've been running propeller simulations over the last months, and I had been using snappyHexMesh for meshing the propeller geometry and simulation domain before jumping into cfMesh. My simulation structure is completely based on the pimpleFoam propeller tutorial, except that I modified it to run my geometry in compressible steady-state (rhoSimpleFoam) and using MRF technique.
SHM meshes were never as refined as they should be, specially at the leading-edge and near the blade tips. As reported in this thread:
[snappyHexMesh] Rough leading-edge and trailing-edge after snapping, I spent around 2 months trying to improve the mesh, which I actually did, however not sufficiently as I wanted. SHM fails to refine the surface after a certain surface refinement level and also fails to add boundary layers properly to the surface.
After researching for alternatives I came across cfMesh through this video: How to create your first mesh with cfMesh - tutorial by József Nagy that helped me a lot with the introduction to the mesher. It is a much simpler, more intuitive, increadibly fast, and requires fewer configurations compared to SHM. It really surprised me.
I have started meshing with it and the very first mesh I came out with was better than any mesh I had done before with SHM. Not only the surface refinement was excelent, but it succesfully added layers on the whole propeller/airfoil surface. It also executed the mesh in less than a minute, when compared to 10-30 minutes of SHM. I found cfMesh really great, but I'm having difficulties to integrate the mesh to my simulation structure and to dealing with some AMI patches, which I'm going to further detail next.
My domain is composed by:
- propellerTip: are the prop blades
- propellerSpinner: the prop spinner
- innerCylinderSmall: the "moving" domain
- outerCylinder: an outer cylinder that contains the other patches as well as the farfield upstream and downstream of the propeller
snappyHexMesh
The meshing process that I was using was: create a blockMesh wrapping the whole domain; extract stl file surface with surfaceFeatureExtract, mesh with snappyHexMesh;configure the boundary, inlet and outlet face sets; and finally create AMI, inlet and outlet patches.
blockMesh
snappyHexMesh
topoSet -dict system/createInletOutletSets.topoSetDict
createPatch -overwrite
blockMeshDict:
scale   1;
convertToMeters   1;
vertices
    (-0.65 -0.65 -0.65)
    ( 0.65 -0.65 -0.65)
    ( 0.65  0.65 -0.65)
    (-0.65  0.65 -0.65)
    (-0.65 -0.65  0.65)
    ( 0.65 -0.65  0.65)
    ( 0.65  0.65  0.65)
    (-0.65  0.65  0.65)
blocks
    hex (0 1 2 3 4 5 6 7) (12 20 12) simpleGrading (1 1 1)
edges
boundary
    walls
        type wall;
        faces
            (2 6 5 1)
            (0 3 2 1)
            (0 4 7 3)
            (4 5 6 7)
    inlet
        type patch;
        faces
            (3 7 6 2)
    outlet
        type patch;
        faces
            (1 5 4 0)
snappyHexMeshDict:
castellatedMesh true;
snap            true;
addLayers       true;
geometry
    innerCylinderSmall.stl
		type triSurfaceMesh;
		name innerCylinderSmall;
	outerCylinder.stl
		name outerCylinder;
	propellerTip.stl
		name propellerTip;
    propellerSpinner.stl
		name propellerSpinner;
castellatedMeshControls
    maxLocalCells 1000000;
    maxGlobalCells 15000000;
    minRefinementCells 0;
    maxLoadUnbalance 0.10;
    nCellsBetweenLevels 2;
    features
            file        "innerCylinderSmall.eMesh";
            level       2;
            file        "outerCylinder.eMesh";
            level       0;
            file        "propellerTip.eMesh";
            level       9;
            file        "propellerSpinner.eMesh";
            level       6;
    refinementSurfaces
        innerCylinderSmall
            level       (2 2);
            faceType    boundary;
            cellZone    innerCylinderSmall;
            faceZone    innerCylinderSmall;
            cellZoneInside  inside;
        outerCylinder
            level       (0 0);
        propellerTip
            level       (1 9);
        propellerSpinner
            level       (1 6);
    resolveFeatureAngle 0.1;
    refinementRegions
        innerCylinderSmall
            mode        inside;
            levels      ((1E15 2));
        outerCylinder
            mode        inside;
            levels      ((1E15 1));
    locationInMesh (0.01 -0.125 0.01);
    allowFreeStandingZoneFaces false;
snapControls
    nSmoothPatch 3;
    tolerance 1.0; // 1.0;
    nSolveIter 100;
    nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap true;
        explicitFeatureSnap false;
        multiRegionFeatureSnap true;
addLayersControls
    relativeSizes true;
    layers
		"propellerTip.*"
				nSurfaceLayers 3;
    expansionRatio 1.0;
    finalLayerThickness 0.3;
    minThickness 0.1;
    nGrow 0;
    featureAngle 30;
    nRelaxIter 3;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedialAxisAngle 90;
    nBufferCellsNoExtrude 0;
    nLayerIter 100;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 4;
    maxInternalSkewness 4;
    maxConcave 80;
    minVol 1e-13;
    minTetQuality -1e30; // 1e-30;
    minArea -1;
    minTwist 0.01;
    minDeterminant 0.001;
    minFaceWeight 0.05;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
    relaxed
        maxNonOrtho 75;
mergeTolerance 1e-6;
createInletOutletSets.topoSetDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    boundaryFaces;
        type    faceSet;
        action  new;
        source  patchToFace;
        patch   outerCylinder;
        name    outletFaces;
        type    faceSet;
        action  new;
        source  faceToFace;
        set     boundaryFaces;
        name    inletFaces;
        type    faceSet;
        action  new;
        source  faceToFace;
        set     boundaryFaces;
        name    outletFaces;
        type    faceSet;
        action  subset;
        source  normalToFace;
        normal  (0 -1 0);
        cos     0.3;    // Tolerance (max cos of angle)
        name    inletFaces;
        type    faceSet;
        action  subset;
        normal  (0 1 0);
createPatchDict:
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync false;
// Patches to create.
patches
        //- Master side patch
        name            AMI1;
        patchInfo
            type            cyclicAMI;
            matchTolerance  0.0001;
            neighbourPatch  AMI2;
            transform       noOrdering;
        constructFrom patches;
        patches (innerCylinderSmall);
        //- Slave side patch
        name            AMI2;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  AMI1;
        patches (innerCylinderSmall_slave);
        name inlet;
        patchInfo
            type            patch;
        constructFrom set;
        set inletFaces;
        name outlet;
        patchInfo
            type            patch;
        constructFrom set;
        set outletFaces;
cfMesh
Now, for cfMesh I tried to keep as much of the previous workflow as possible, however, as seen in this post: Problem using AMI post #184, due to cfMesh limitations I had to create two separate meshes: rotor containing innerCylinderSmall, propellerTip, and propellerSpinner; and stator containing outerCylinder. An then I merged them together with mergeMesh.
I created the mesh on both rotor and stator folders as
surfaceFeatureEdges rotor.stl rotor.fms
cartesianMesh
surfaceFeatureEdges stator.stl stator.fms
blockMesh
cartesianMesh
with meshDict.rotor:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "mesh";
    object      meshDict;
surfaceFile "rotorSlave.fms";
minCellSize 0.005;
maxCellSize 0.01;
boundaryCellSize 0.05;
localRefinement
    "propellerTip"
        //cellSize  0.000125;
        additionalRefinementLevels 6;
boundaryLayers
    //nLayers 3;
    thicknessRatio 1.1;
    maxFirstLayerThickness 0.5;
    patchBoundaryLayers
        "propellerTip"
            nLayers 3;
            allowDiscontinuity 0;
meshDict.stator:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "mesh";
    object      meshDict;
surfaceFile "outerCylinder.fms";
minCellSize 0.01;
maxCellSize 0.1;
boundaryCellSize 0.1;
Then I execute:
cd stator
mergeMeshes . ../rotor
However, createPatch fails to create AMI2 patch because the innerCylinderSmall_slave patch, which is created as simrego described on this thread below:
Originally Posted by simrego View Post
Hi!
If I'm correct it is made in the refinementSurfaces/innerCylinderSmall entry where you define the faceType as boundary. So you split the mesh with walls. Then in the createPatch utility you correct it and create the cyclicAMI interface between them.
is not created under cfMesh enveironment.
I tried many and many things that I saw in multiple threads without any success. I need to create the innerCylinderSmall_slave patch, but I dont know how to copy or duplicate the patch innerCylinderSmall.
What do you folks think I should do? But trying to keep as much of the original workflow?
I'll make available both the snappyHexMesh and cfMesh case folder which I mentioned above:
https://drive.google.com/file/d/1uq8...ew?usp=sharing
createPatch log:
Build  : _7bdb509494-20201222 OPENFOAM=2012
Arch   : "LSB;label=32;scalar=64"
Exec   : createPatch -overwrite
Date   : Oct 21 2021
Time   : 15:01:31
Host   : MSI
PID    : 640
I/O    : uncollated
Case   : /mnt/c/Users/Felix/Documents/Mestrado/OpenFOAM/runs/liuPropeller/3liuAs31mscD30implicit/mesh/stator
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Reading "system/createPatchDict"
Adding new patch AMI1 as patch 4 from
    type            cyclicAMI;
Adding new patch AMI2 as patch 5 from
    type            cyclicAMI;
Adding new patch inlet as patch 6 from
    type            patch;
Adding new patch outlet as patch 7 from
    type            patch;
Moving faces from patch innerCylinderSmall to patch 4
--> FOAM Warning :
    From Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 896
    Cannot find any patch or group names matching innerCylinderSmall_slave
Read 5050 faces from faceSet inletFaces
Read 4964 faces from faceSet outletFaces
Doing topology modification to order faces.
Not synchronising points.
Removing patches with no faces in them.
Removing zero-sized patch innerCylinderSmall type wall at position 1
Removing patches.
Writing repatched mesh to 0
End
boundary file with AMI2 with zero faces:
FoamFile
    version     2.0;
    format      binary;
    class       polyBoundaryMesh;
    arch        "LSB;label=32;scalar=64";
    location    "constant/polyMesh";
    object      boundary;
7
    outerCylinder
        type            wall;
        inGroups        1(wall);
        nFaces          18590;
        startFace       16194675;
    propellerSpinner
        type            wall;
        inGroups        1(wall);
        nFaces          14725;
        startFace       16213265;
    propellerTip
        type            wall;
        inGroups        1(wall);
        nFaces          1030388;
        startFace       16227990;
    AMI1
        type            cyclicAMI;
        inGroups        1(cyclicAMI);
        nFaces          9448;
        startFace       17258378;
        AMIMethod       faceAreaWeightAMI;
        restartUncoveredSourceFace 1;
    AMI2
        type            cyclicAMI;
        nFaces          0;
        startFace       17267826;
    inlet
        type            patch;
        nFaces          5050;
        startFace       17267826;
    outlet
        type            patch;
        nFaces          4964;
        startFace       17272876;
Images from the differences of SHM and cfMesh meshes. Left SHM, right cfMesh
gabrielfelix is offline   Reply With Quote
Old   October 27, 2021, 11:38
Default [update]
Gabriel Felix
Hi folks,
I succesfully created the faceSet, cellSet, faceZone and cellZone with the following topoSet script:
|  \\    /   O peration     | Version:  2.1.x                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    innerCylinderSmallCell;
        type    cellSet;
        action  new;
        source  patchToCell;
        sourceInfo
            patch     innerCylinderSmall;
        name    innerCylinderSmallFace;
        type    faceSet;
        action  new;
        source  patchToFace;
        sourceInfo
        name    innerCylinderSmallFaceZone;
        type    faceZoneSet;
        action  new;
        source  setsToFaceZone;
        sourceInfo
            faceSet     innerCylinderSmallFace;
            cellSet     innerCylinderSmallCell;
        name    innerCylinderSmallCellZone;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set    innerCylinderSmallCell;
such as they are created under these snappyHexMeshDict lines:
 refinementSurfaces
        innerCylinderSmall
            level       (2 2);
            faceType    boundary;
However, now I still need to create the AMI patches, for which I tried to create baffles from the faceZone I just created, but I had no success with this code:
|  \\    /   O peration     | Version:  2.3.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createBafflesDict;
internalFacesOnly true;
baffles
    innerCylinderSmall
        type		faceZone;
        zoneName	innerCylinderSmallFaceZone;
    	flip		false;
        patches
            master
                type            patch;
                neighbourPatch  innerCylinderSmall_slave;
            //slave { ${..master} }
            slave
                name            innerCylinderSmall_slave;
                type            patch;
                neighbourPatch  innerCylinderSmall;
Does anyone could help me?
Old   July 5, 2023, 20:54
Gabriel Felix
Hello guys, I finally found a solution to the problem and managed to mesh the propeller case with cfMesh succesfully. I posted the detailed solution in this thread.
[Guide] How to mesh a propeller domain using cfMesh - AMI patch
Case files are also available.
ami, cfmesh, error, patch, propeller
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 07:56
Creating patches in OpenFOAM shahidkhan OpenFOAM 1 February 5, 2020 01:46
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
[mesh manipulation] mirrorMesh and undoing the joining of patches chegdan OpenFOAM Meshing & Mesh Conversion 3 October 21, 2015 08:09
Regarding periodic BC in ICEM generated grid Tarak OpenFOAM 32 April 30, 2013 14:46
