[Other] real gas model implementation for thermophysicalModels library |
January 11, 2023, 01:39 |
#21 | |
Nam Danh Nguyen
Rep Power: 6 |
We referred to this paper for the global strain rate definition. https://www.researchgate.net/publica...ffusion_flames Danh Nam, |
January 11, 2023, 01:45 |
#22 | |
Nam Danh Nguyen
Rep Power: 6 |
Hi Mishra! You are right. When you retrieve the temperature from the enthalpy for real-gas cases, you need to derive dH/dT term (i.e., derivative of departure part w.t. the temperature). The existing code is only applicable for ideal gas problems. Danh Nam, |
March 24, 2023, 03:23 |
#23 | |
Roozbeh
Rep Power: 9 |
I have the same problem of negative CP in FLUENT. There I have the possibility to correct the Peng-Robinson equation. Could you explain this modification a bit more in detail? Thanks in advance |
March 27, 2023, 20:14 |
Fast chemistry
#24 |
Rohit Mishra
I believe one of the ways the chemistry libraries are changed, the chemistry model has to be selected among the different options of real gas EOS. However, can you tell me how would one go about also implementing reduction/tabulation since in classic OF the option was there as one of the entries to chemistryModel. Thanks. |
May 16, 2023, 22:37 |
cannot process ./Allwmake
#25 |
araphi
When I install, the directory ($WM_PROJECT_DIR/wmake/scripts/AllwmakeParseArguments) is missing, the library cannot be installed, blockMesh and other operations cannot be performed. |
June 29, 2023, 02:51 |
#26 |
Ervin Adorean
Rep Power: 17 |
I saw in the tutorials that one is able to generate properties file for a temperature range but for a specific pressure. How this library can be used for a case where one has 100 bar pressure difference between inlet and outlet? Thank you! Ervin |
June 30, 2023, 03:52 |
#27 | |
Nam Danh Nguyen
Rep Power: 6 |
Sorry for my late reply. It's quite complicated. If you are still want to implement it for reduction/tabulation, please contact me via my email (danhnam11@gmail.com). Danh Nam |
June 30, 2023, 03:54 |
#28 |
Nam Danh Nguyen
Rep Power: 6 |
June 30, 2023, 04:03 |
#29 | |
Nam Danh Nguyen
Rep Power: 6 |
Since the test case in the tutorial is designated only for generating thermophysical properties. Theoretically, if you provide p, T, then you can get properties. Actually, I don't know why you need to generate properties at such conditions (i.e., having a pressure difference between the inlet and outlet). If you need properties at 100 bar, just change the pressure in the internal domain to 100 bar. If you want to get the properties for a range of pressure, you can run several times corresponding to different pressures. For your case, I have no idea. It would be better if you provide more information about your case. So that I may help you. Danh Nam, |
June 30, 2023, 05:26 |
#30 |
Ervin Adorean
Rep Power: 17 |
Hello Danh Nam,
If I understand correctly, for a multiphase single component non reacting (CO2) simulation, for example if at time 0 the domain/outlet has 10 bar pressure, one needs to generate properties for 10 bar. And even if the inlet pressure BC is 100 bar, the model is able to get itself the correct properties, or I need to provide multiple .dat files (10,20, ... 100 bar)? For example for interPhaseChangeFoam how should I change the thermophysicalProperties file and how to use the generated tabular properties file OF.p10.CO2.dat? Is there somewhere such an example case, for whatever solver? Thank you! Best regards, Ervin |
July 5, 2023, 05:28 |
#31 |
Ervin Adorean
Rep Power: 17 |
Anyone, please? In Ansys, one can generate 1 real gas properties table for a range of temperatures and pressures. How can this be achieved here? And how can one point the OpenFOAM solvers to use these properties files (OF.p10.CH4.dat, for example) in a case? Thank you! Best regards, Ervin |
July 5, 2023, 23:35 |
#32 | |
Nam Danh Nguyen
Rep Power: 6 |
Hi Ervin!
If you used the model in my library (and solver), it will automatically update your properties regardless your pressure inside the domain is 10 bar or 100 bar. As I sad, if you provide value of p and T, you can get properties. For your case, you cannot use my real-gas library in interPhaseChangeFoam if you don't modify the solver since the interPhaseChangeFoam solver does not use "psiThermo" or "rhoThermo" class. And to develop a new version of "interPhaseChangeFoam" solver to be able used real-gas library is a different story. Best regards, Danh Nam |
July 6, 2023, 09:21 |
Use of the library in twoPhaseEulerFoam
#33 |
riccardo
Rep Power: 3 |
Hi!
Thank you for the library. I am using a in house solver based on twoPhaseEulerFoam that requires Thermophysical models but not any kind of reactions. I am planning to add an equation of state for CH4 and also I would need the data for CH4 in order to calibrate the thermo coefficient to be chosen in a context of two phase liquid-gas non newtonian flow. Would that make sense if I don`t consider reactions (and so also temperature effects)? Thank you. |
July 7, 2023, 02:15 |
#34 | |
Nam Danh Nguyen
Rep Power: 6 |
I've just quickly checked the tutorial test case in "twoPhaseEulerFoam" and I found that this solver uses pureMixture model. Actually, my real-gas library is not applicable for pureMixture model. If you want to implement it, pls contact me. I will let you know. For pureMixture its quite easy, you just copy my source code and do some modification. Danh Nam. |
July 7, 2023, 03:28 |
#35 | |
riccardo
Rep Power: 3 |
Thank you for your answer. Yes, I am interested, I saw you shared your e-mail, I will contact you there. Riccardo |
October 15, 2023, 04:25 |
A problem during the installation
#36 |
Congren Zheng
Hi, the library is very nice. I got a problem during Allwmake.
The error code is like this: In file included from specie/specie.H:155:0, from specie/specie.C:26: specie/specieI.H: In member function ‘void Foam::specie:perator+=(const Foam::specie&)’: specie/specieI.H:108:21: error: ‘small’ was not declared in this scope if (mag(sumY) > small) ^~~~~ specie/specieI.H:108:21: note: suggested alternative: ‘scalbl’ if (mag(sumY) > small) ^~~~~ scalbl specie/specieI.H: In function ‘Foam::specie Foam:perator+(const Foam::specie&, const Foam::specie&)’: specie/specieI.H:127:46: error: ‘small’ was not declared in this scope const scalar sumY = max(st1.Y_ + st2.Y_, small); ^~~~~ specie/specieI.H:127:46: note: suggested alternative: ‘scalbl’ const scalar sumY = max(st1.Y_ + st2.Y_, small); ^~~~~ scalbl specie/specieI.H: In function ‘Foam::specie Foam:perator==(const Foam::specie&, const Foam::specie&)’: specie/specieI.H:157:22: error: ‘small’ was not declared in this scope if (mag(diffY) < small) ^~~~~ specie/specieI.H:157:22: note: suggested alternative: ‘scalbl’ if (mag(diffY) < small) ^~~~~ scalbl specie/specieI.H:165:24: error: ‘great’ was not declared in this scope scalar molWeight = great; ^~~~~ specie/specieI.H:165:24: note: suggested alternative: ‘read’ scalar molWeight = great; ^~~~~ read specie/specieI.H:166:23: error: ‘small’ was not declared in this scope if (mag(diffRW) > small) ^~~~~ specie/specieI.H:166:23: note: suggested alternative: ‘scalbl’ if (mag(diffRW) > small) ^~~~~ scalbl /usr/lib/openfoam/openfoam2306/wmake/rules/General/transform:37: recipe for target 'Make/linux64GccDPInt32Opt/specie/specie.o' failed make: *** [Make/linux64GccDPInt32Opt/specie/specie.o] Error 1 The problem is that there is no definition of variable 'small' |
April 27, 2024, 11:17 |
I'm facing the same problems as you
#37 |
Ryan Cooper
I got the same error for Allwake. And is the real Gas solver configured for openFoam 9 and above?
Compile User-Defined Real Gas Model (UDRGM) | Captain Convergence | Fluent UDF and Scheme Programming | 31 | November 6, 2020 06:30 |
make a new data from external .txt data and save it in a UDM | etedalgara | Fluent UDF and Scheme Programming | 27 | February 26, 2020 03:15 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
view factor | yoollooz | Fluent UDF and Scheme Programming | 0 | March 1, 2013 00:44 |
